I tried turning on the tv one day and it didnt turn on. the screen lights up but thats it. it doesnt say no signal or see any volume control or any menus
  • 27 Answers
Broken
Posted on Nov 19, 2009
My sony tv model, kdl-32m4000. doesnt get power on. tunrned off from runing condition the other day we tried to turn back on, didnt work.
Unplug tv from wall socket for minute, replug back in and turn it On.
Problem still not solved? let me know do you get power indicator light on tv? is it solid or blinking?
Jul 05, 2011 | Sony KDL-32M4000 LCD TV
RCA L26WD12 - for as long as we've had it, it would have problems turning on, being the light would turn green, but the screen would stay black. We'd have to unplug it and plug it back in. Eventually the...
The tv Tuner signal board is the causes and the problems.That the board,where the tv incomming broadcasting signal cable wire plug into it.U can do the basic things like take it aparts and putting it back together again?Yes,Tries websites like Shopjimmy.com,Ebay.com to buy a tv Tuner signal board for the replacement.
Mar 23, 2011 | RCA L26WD12 26 in. LCD TV
I bought this N2635W it wasnt turning on. (So I thought it was the power supply) I bought a new power supply, and still didnt turn on.( So I thought it is the main control board) I bought a usded...
The tv Tuner signal board is the cause and the problems.That the board,where the incomming broadcasting signal cable wire plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Mar 15, 2011 | ViewSonic N2635w 26 in. LCD Television
Turns on and off by itself
If this happens on all inputs and you have disconnected the power and reconnected it and that didnt fix it.
Sounds like a logic board issue problem is LG only warrenties tvs for 1 - 2 yrs.
Jun 16, 2010 | LG 42LC2D 42 in. LCD HDTV
So i went to turn on my hom theater and it didnt trn on i had 2 do it manualy the remote worked fine hours ago not it doesnt
Try replace the batteries with fresh ones and installed correctly,check to see that the LED lights up when you press a button, and that nothing is blocking the signal IR path to the sensor on the TV,and that your not to far away from TV.....hope this was helpful....
Jun 02, 2010 | Samsung TV Remote Control
TOSHIBA FLAT SCREEN TV has black screen but power light is on!?
Try resetting the TV by leaving it unplugged for an hour.
Plug it back in and check to see if it works normally.
If that doesn't work, rule out the Directv box by pressing the reset button near the access card. The box could be putting out a signal that doesn't have video or audio.
If everything fails, have the tech man come back to check everything that he did before you use the warranty on the TV.
Feb 20, 2009 | Toshiba 40RV525U 40 in. LCD TV
LG 37in HD LCD tv not responding to any pressed buttons.
Based on your description, it appears that you have main board issues with your unit since your controls do not work and some inputs are NG.
Apr 24, 2017 | LG 37LP1D 37 in. LCD Television
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Help
sounds to me that the remote control's volume button is wedged in there. try to jimmy it loose with a paperclip. It could also be stuck ont he tv at the bottom. are you wall mounted, stand, or just laying on carpet? the volume is at the bottom of the tv. hope this helps...cheers.
Apr 03, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sounds like you have a jammed / shorted out button on the control panel... Try un-plugging the tv, and then unplug the "button panel" on the front of the tv...see if you can turn the tv on with the remote. Sometimes if one of the buttons gets shorted, it will "lock" the processor from doing ANYTHING else, as it thinks you are holding down the defective button. If this works, simply have the defective switch or control panel replaced, or just leave it unplugged and use the remote only! Hope this helps!
Jan 03, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
