Question about HP Scanjet 5590 Flatbed Scanner
The automatic document feeder keeps grabbing the paper on one side and therefore creasing the paper so that it does not go through
  • 22 Answers
Lift up on the ADF roller cover and look for a piece of paper. Remove the blue guide bar and the end where the paper flips under. If you can't find paper put the blue bar back and close the ADF (automatic document fee) lid. Lift up the flatbed scanner cover and look at the far left side to see a piece of obstruction. Clear that and try making a copy.
Posted on Nov 19, 2009
My Automatic Document Feeder for my HP Photosmart 7520 won't work
Does it grab paper at all? Does the paper jam in the doc feeder? does it scan when place on the glass?
Oct 16, 2014 | HP Photosmart 7520 All-in-One Color Inkjet...
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Thanks
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
An automatic document feeder paper jam has been detected
my scaner icon window show this messege:
an automatic socument feeder paper jam has been detected. clear the jam and try scaning again
Jan 13, 2012 | HP Scanjet 5590 Flatbed Scanner
Mp 530 error code 103.0.0
you will see small levers were the paper passes. check if one of them are not stuck.
Oct 20, 2011 | Canon PIXMA MP530 All-In-One InkJet...
My lexmark x1270 keeps jamming not grabbing on the right side.
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print a document again to verify that the problem is fixed.
Sep 18, 2011 | Lexmark X1270 All-In-One InkJet Printer
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
Printer paper feed
Hi there
This hapens a lot with different printers, best way is to gave your papers a good shake and keep in a worm place then it may work for you.
All The Best Pineworks
Mar 05, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Paper cannot be fed through automatically
Dear sir; there have a cover on the auto feeder, open the cover, you going to see few rollers ,clean all rollers with rubber rejuvenator or rubbing alcohol it will take care the problem otherwise you have to replace document pick up roller, please let me know how does it work out, good luck.
HAVE A HAPPY HOLIDAY !!!
Dec 18, 2008 | Canon imageCLASS D761 Copier
No Paper in Document Feeder
I just upgrated my Vista system as recomanded, and after that I am not able to scan documents, getting the messGE " NO PAPER IN THE DOCUMENT FEEDER " on my all in one laiser jet 3050
May 23, 2008 | HP LaserJet 3055 All-In-One Printer
Jam in the document feeder
I think I found my answer. You don't have to un do any screws. Lift up the cover to the automatic feeder. You will see a spring on the side of the mechanism towards the front; remove the spring; that will allow you to lift up the little arm the spring was attached to and remove the roller or bar and the light blue/green plate just under it. Then you will be able to see the jammed paper, which which I was able to carefully pull out with a pair of tweezers. Some was under rubber rollers, but when I pulled the paper sideways it slipped out. Now it works!
Jan 23, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP Scanjet 5590 Flatbed Scanner Logo
472 people viewed this question
Seeker5211
Seeker5211
