Question about HP Computers & Internet
I am trying to replace the ac powerjack, due to itbeing damaged. However there is a small piece of one of the legs from the old jack still in the board, desoldering or soldering will not get it out. Any suggestions?
  • Luke Stewart Nov 20, 2009
    Thanks for the tip, I am going to go try this now!
  • HP Master
  • 19,396 Answers
Hi.
You need to use a squeeze bulb or a pump (DESOLDERING PUMP) to remove the leg.
You may need to pull the leg using 5.5" Longnose Pliers while you use the soldering Iron.
You may ask somebody else to use the pump.
Regards.
Posted on Nov 19, 2009
Laptop power cable
Has the AC jack been damaged due to pulling on the cord? Most likely the connection or the AC jack to the Mobo has been damaged. Depending on the AC jack it may need replacing or re-soldering.
Jan 28, 2013 | Acer Aspire Computers & Internet
Asus x83v wont turn on at all
Try another AC outlet, Try another Cord/charger with the EXACT same power specs. If the AC jack has been damaged due to pulling on the AC cord, you may have to replace the AC jack. Most likely, there is no in-line fuse in a laptop.
Jan 16, 2013 | ASUS X83Vm-X1 Notebook
How to fix a no power globe broadband bm662 wimax
Try another cord. Has the AC jack been damaged due to a pull on the cord? At the AC jack on the device wiggle the plug, do you see any LED's blink? Replace device if all else fails
Dec 24, 2012 | Option Wireless Technology Option...
Have a old dell b120 laptop, I just got a new ac charger, the 3rd green light will come on steady, but the laptop will not turn on. if I move the laptop, the 3rd (light from left will slowly blink green,...
HI There,
"move the laptop" is pretty much a dead giveaway that it's the DC Powerjack, just as you suspect. Even though it may not seem loose, its interior connection on the board is probably just enough compromised to cause the lack of power supply.
I used to solder these myself but now send them out to several different vendors on eBay without problems. Of course, your issue will be whether to spring for the 80 to 100 bucks for the jack replacement or move to a newer rig.
Best of luck to you.
Sep 11, 2010 | Dell Inspiron B120 Notebook
Help with toshiba ac problem
oh.. This problem occurs due to the damaged power jack(The port where you plug in the AC adapter). It is very easy to unsolder and resolder the old one. A replacement jack can be obtained from toshiba. I even found a jack for my friend at a local electronic store but a genuine replacement is always advisable. You will find the power jack under the keypad of your laptop.
Let me know if you need more help.
Regards,
Sai.
Sep 25, 2008 | Toshiba Satellite P35-S611 Notebook
Power suppy
Seeing how the AC Power Cord Plug Snapped, It probably loosened the pins on the DC Power Jack (located on the motherboard...)....and you are shorting out from loose contacts on the DC Jack...
The DC PowerJack Will either have to be desoldered and cleaned then Resoldered.....
Or Purchase a New DC Jack and Replace With Old By Desoldering and soldering New in Place....
And of course.. get yourself a new charging cord, or go to radio shack and buy a new plug tip and reattach it to your Power Charger Cord End....
Hope that helps..
http://www.wnycomputerpro.com
Jun 13, 2008 | HP Compaq Presario C500t Notebook
My Satellite P35-S611 will not run on ac power nor will it charge the battery
this happened to me also after window update ..i think it was updating with sp3
Feb 02, 2008 | Toshiba Satellite P35-S611 Notebook
My satellite P35-S611 will not run on AC power nor will it charge the battery
I have just fixed the same problem on my Toshiba p35 s611.
The power jack inside the laptop had been damaged. To reach the problem you must take apart the entire laptop (there are a few guides for doing this online). Next I simply found the positive connection coming from the jack (it is the wire coming out of the back of the jack) and followed it to where it enters the motherboard. I simply flipped it around and re-soldered that one spot. Other sites recommended I remove the jack but I couldn't melt the solder enough to do so, however just trying and adding some fresh solder was enough to fix the problem. I no longer need to jiggle the power connector to the right angle just to get power.
Computers & Internet Logo
24 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
