Computer is on disc drive has not light and wont respond to button push or icon selection
  • 47 Answers
Could you give me more information as to where you are with this?
Posted on Nov 19, 2009
I have a cd I put in, but do not know how to remove it from my computer need help
1. Open the Computer window on your PC: Either double-click the Computer icon on the desktop, or open the Start menu and choose Computer.
2. Click the DVD drive icon: Clicking the icon selects that drive.
3. Right click on it and choose 'Eject' from the drop-down list.
OR
Try the following only if the above steps didn't work or in times of urgency, such as when the computer is locked up (or turned off), you can manually eject a disc/cd by pushing a straightened paper clip into the tiny hole (the "beauty mark") on the front of the DVD drive.
f90a6593-7fec-4205-a633-379cc4b71e53.jpg8572a8b8-67cd-4c33-bbf8-d5d51bfdd48d.jpg8681c4da-0608-43dc-b4b8-cee760b38e11.jpg
Nov 28, 2013 | Computers & Internet
Why wont my cd drive work
see this and fix it. God bless you
Turn on your computer and open the CD drive by pressing a small button on the front of the drive. Use a can of compressed air to clean the lens by spraying a few squirts of the air into the drive. This will fix disc skipping if there was dust on the lens.
  • 2 Place a CD drive cleaner into the disc drive. This is a disc that is specifically designed to clean CD drives. Allow it to run for a few minutes, and then extract the disc from the optical drive.
  • 3 Click the "Start" button and then click on the "All Programs" option. Click on the "Windows Update" icon and then click the "Check for Updates" button on the left side of the screen. Click the "Install Updates" button at the bottom of the screen to update the drivers for your CD drive. Restart your computer for the driver changes to take effect.
  • 4 Unplug the power cable from your computer and use a screwdriver to open the tower door. Locate the CD drive cables inside the computer. Make sure that the CD drive cables have not loosened. If the cables are loose, then the drive will not operate properly.
  • Sep 27, 2012 | Acer Computers & Internet
    Disc Drive
    If the eject button is not working, assuming this is a Windows based computer, click on start icon, your start menu will display, on right side under your user icon you should see Computer or My Computer, click on it.
    You will now see all drives in your computer. Right click on your dvd(optical) drive. You should see an eject option.
    If this dosen't work, close to the eject button on the drive is a tiny hole that will accept a paper clip, carefully push clip into hole until drive ejects.
    Feb 13, 2012 | HP Computers & Internet
    Disc drive wont open. i pressed the eject button on my keyboard but it makes a clunk sounds but wont open.
    This wil show you how to take it apart if that becomes necessary. But try this instead. First hold the eject button down for 5 seconds. I that fails look for a tiny hole near the disc slot. Use a straightened paper clip and push it in the hole firmly. This should eject the disc. Another option is to use firmware to eject the disc. Follow these directions: To eject a disc with Open Firmware commands, follow these steps:
    1. Restart the computer.
    2. Immediately after the startup sound, press and hold the key combination Command-Option-O-F.
      Note: The Command key has the Apple and (commandkeysymbol.gif) icons on it.
    3. Release the keys when you see a white screen that says "Welcome to Open Firmware."
    4. At the prompt, type: eject cd
    5. Press Return, then wait a few seconds. The disc drive should eject any disc that is present, and "ok" appears behind your command when the action is complete.
    6. Type: mac-boot
    7. Press Return.
    8. Your computer should now start up normally.
    9. Instructions curtorsey eh.mac.ca
    Aug 16, 2010 | Apple iMac G4 Desktop
    A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
    The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
    If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
    ht3007_1.gifFigure 1 Manual eject button
    Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
    Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
    DONT FORGET TO VOTE
    Oct 10, 2009 | Apple iMac G4 Desktop
    Why cant I write onto my blank DVD disk I have windows XP and DVD R in my DELL writable drive.Im trying to copy about 1 gig of JPEGS onto the disk. The disc is MAXELL 4.75 GB DVD R. Im using windows XP....
    It doesn't matter what name or brand the disc is. All it matters that it is a writable disc. If you had aldready written previous files on that DVD disc and then it was compiled, it wont write again. When the computer requests to compile a disc, say no, otherwise you wont be able to write more data on the same disc. The same goes if you have selected a CD to burn. There are 3 ways to do so. Try copy and paste, drag and drop the file to the DVD icon or CD icon, or right click on the file to be burned and select 'Send to...' choose the DVD drive, (D:), see what happens.
    Sep 18, 2009 | Dell Computers & Internet
    Can't get the disc out...
    is the light flashing on the drive ? .... be that as it may you will note a small hole on the face of it.... put a small round object in there and push... that should open the door.
    Mar 08, 2009 | LG GCE 8523BB (GCE-8523BB-10PK) CD-RW...
    Memorex external usb floppy disk-drive does not appear or functio
    As I understand it the computer recognizes the floppy drive.
    Can you read other discs, write to them etc? If not drive is bad
    If you can read other discs then your floppy disk is bad
    Jan 23, 2009 | Memorex Computers & Internet
    CD Drive on Presario V2135US
    Was that light flash when you press Open button? Can you do this - goto My Computer and right click on you CD drive's icon select Eject - to see if the CD is respond.
    Dec 29, 2007 | Compaq StorageWorks TLZ10 DAT Tape Drive
    CD tray does not open when Button Pressed
    does the tray open when you right click on the drive icon in "My Computer" and select "eject"?
    Oct 25, 2006 | Sony DRU-810A DVD RW Dual Layer Burner
    Computers & Internet Logo
    12 people viewed this question
    David Payne
    David Payne
