Question about Refrigerators
I have a Frigidaire refrigerator top freezer model # FRT8B5HBO serial # BA80212978. It leaks from the bottom front in the morning. What do you think the problem is. Exactly where is the pan located that catches the water? What does the pan look like? It is in a rental unit so maybe it is missing? Can you e-mail a picture of what the pan looks like and location to rtmeeker@cox.net? What do you suggest?
  • 4,070 Answers
It's not the pan that's the problem, it's the drain line to the pan.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Nov 19, 2009
Testimonial: "Thanks so much, you were right on and my husband was able to fix the refrigerator. God Bless you and Merry Christmas. Thanks again, Theresa Meeker"
Why isn't my frigidaire ice maker working?
Hello Lynn, thank you for your post!
I understand that your Frigidaire refrigerator is not making ice and items inside of the freezer are thawing out. This could be an issue with your control panel or sealed system, is there anything being displaying on the front of your refrigerator? May I also have your model number? You can locate your serial tag (which lists your model number) on the right hand wall of the fresh food side. With that information I would be able to assist you further. -Matt
Apr 19, 2016 | Frigidaire Refrigerators
Ireland
Hey friend, thank you for the post!
From my understanding you have water leaking out of the freezer of your Frigidaire refrigerator and onto the floor. I would like to ask you a couple of additional questions. First, do you see where the water is coming from? Secondly, what is the model number of your appliance? You can locate your serial tag (which lists your model number) on the inside cabinet of the fresh food compartment normally on the left side in a top mount. But on a side by side it can be found on the right hand side. I look forward to hearing back from you. -Matt
Jul 17, 2014 | Frigidaire 20.6 cu. ft. Top Freezer...
Water dispenser does not shut off
That is most likely a dual water control valve stuck open on back of refrigerator near floor. One side feeds ice maker and other side feeds the water dispenser. If the ice maker side began to leak slowly it would create quite a mess of ice flowing over ice maker and freeze every place it could inside the freezer. Part and Model Search If helpful Please Rate this solution, Thank You, Sea Breeze
sea_breeze_260.jpg Refrigerators
Freezers
Washers and Dryers
Oct 18, 2011 | Frigidaire Refrigerators
FRT16CRH Top Freezer Frigidaire Water leaking underneath refrigerator front bottom right hand side
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 04, 2010 | Frigidaire Refrigerators
Frigidaire leaking water out the bottom
it comes from freezer. remove back cover of freezer and unclog hole where water collects
Feb 13, 2010 | Frigidaire GLRS234ZA Side by Side...
Freezer leaking
your drain is probably plugged with something take tha back off of the freezer and find the drain .... let me know what you find out...
Jun 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire refrigerator is warm on top of frig and freezer but fine on the bottom of both.
i suspect the fan is not working. take the back panel off inside the freezer and check that the fan is free to rotate, check for continuity thro the fan motor and check you have power to the fan
Oct 15, 2008 | Frigidaire FRS26H5AS Side by Side...
Water leaking underneath refrigerator/water freezing in bottom of freezer
I'm dealing with the same problem right now with the same refrigerator. The cold water tank (for the front dispenser) has a hole in it that leaks every time someone dispenses water from the front door. You will find the water tank behind the top slide-out drawer in the fridge. The leaked water flows down one of the water tubes through a hole in the bottom of the fridge and onto the floor. I'll bet you have the same problem. Good Luck.
Jun 14, 2008 | Maytag MSD2758G Side by Side Refrigerator
Frigidaire Model #FRS22WRC Side by Side leaking
Check the bottom of the freezer side is there a sheet of ice???
May 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
