Question about Poulan Bp406 45.4cc Backpack Leaf Blower
There is a connector or something missing from the fuel overflow line from the carburetor back to the fuel tank
  • 430 Answers
There is no such thing as a fuel overflow line.
If the unit has a primer bulb then there will be 2 lines in the tank ( 1 is a main fuel line distinguishable by the length of line that extends into the tank with a fuel filter on the end of it, the other is a return line from the primer bulb that terminates just inside the tank usually with a male to male conector.) The main fuel line will go to the carb and another line from the carb will go to the primer bulb. If any of these lines are discolered, fragile or broken then they should be replaced. Generally the smaller diameter line is the main fuel delivery line and the larger diameter line is the primer system.
Posted on Nov 20, 2009
The fuel system on a X speed 50 R i'm not getting fuel to carburetor it's past the fuel filter but not to the carburetor
Hi, Sam always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
2. Fuel cap or fuel tank not venting properly.
3. Fuel filter clogged with rust or dirt.
4. Vacuum line to fuel valve clogged, cracked, pinched, bent, broken, or missing*
5. Faulty vacuum line switch/relay
6. Petcock clogged or diaphragm cracked, cut or torn*
6. Fuel line from the fuel valve/petcock to the carburetor clogged, cracked, pinched, bent, broken, or missing.
7. Vacuum lines to the mechanical fuel pump clogged, cracked, pinched, bent, broken or missing*
8. Faulty electric fuel pump and or wiring*
9. Fuel line from the fuel pump to the carburetor clogged, cracked, pinched, bent, broken, or missing*
10. Carburetor inlet fitting clogged.
11. Carburetor float and or needle and seat stuck.
12. Carburetor overflow line clogged, pinched, or bent.
13. Vacuum line from carburetor deacceleration valve not zipped tied*
* If equipped or applicable.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.49ccscoot.com/manuals/Yamaha_BWS_Zuma_50_2T_Service_Manual.pdf
50CC 2 STROKE PARTS
http://www.yamaha-motor.com/assets/service/manuals/2008/zuma_lit-11626-21-15_1548.pdf
Nov 23, 2016 | Motorcycles
Can't seem to get fuel delivery from fuel tank to inlet valve
Hi, Richard always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
4. Fuel valve/petcock not in the on or reserve position.
5. Vacuum line to fuel valve cracked, broken, pinched, or missing*
6. Fuel valve/petcock clogged or diaphragm cracked, cut or torn*
7. Fuel line from the fuel valve to the carburetor or fuel pump clogged, cracked, pinched, bent, broken, or missing.
8. Fuel pump not working*
9. Fuel line touching cylinder or head causing fuel to boil and vapor lock, repair by rerouting and wrapping line with convoluted tubing.
10. Carburetor inlet clogged.
11. Carburetor float or needle and seat stuck.
12. Carburetor not venting properly overflow line or bowl fitting clogged, pinched, or bent.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Gas Tank Question
How to Diagnose Motorcycle Fuel System Problems
Nov 04, 2016 | Motorcycles
How do i fix my motorcycle honda wave dash fuel gas not continous flowing if i fixed the gas cover
Hi, Danilo always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
Scooter Troubleshooting Scooter won run All about Scooters
http://www.scootertherapy.com/startinghints.html
My chinese scooter wont idle or start Check the fuel petcock
http://part-centre.boonsiewhonda.com.my/pdf/catalog/wave%20dash_new.PDF
Honda Wave 110i User Manual
Aug 31, 2016 | Honda Motorcycles
Scooter not getting gas to carb.
Silly question, but are you sure you are getting gas through the line? Could the line from the tank be plugged? How about the tank port?
Is there a fuel shutoff?
May 10, 2016 | Motorcycles
Fuel cant reach carburetor yp yamaha majesty
Hi, Escend always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
Need help with my scooter
2005 Yamaha Majesty Fuel pump replacement
Yamaha 2004 YP400 Service Manual
OEM parts for Yamaha
YAMAHA MAJESTY 400 Owner Manual
Apr 15, 2013 | 2005 Yamaha Majesty 400
2001 Suzuki GSX 750 F (Katana) carburetors not getting fuel
Hi, Larae always check the fuel flow origin first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
4. Fuel valve not in the on or reserve position.
5. Vacuum line to fuel valve cracked, broken, pinched, or missing.
6. Fuel valve/petcock clogged or diaphragm cracked, cut or torn.
8. Fuel pump not working.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
ISSUE engine not getting fuel Suzuki GSX Motorcycle Forums Gixxer com
Fuel supply valve on Suzuki GSX750F Katana
Suzuki 85 GSX R750 Service Repair Manual
https://www.partsfish.com/page/oem-parts-for-suzuki
http://mybikemanuals.com/suzuki/suzuki-gsx-owners-manuals
Oct 30, 2017 | 2001 Suzuki GSX 750 F (Katana)
1970 yamaha u5 keeps running out of fuel tank is full
Hi, Anonymous always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a wonderful day.
Letting tank get low risks more than just running out of gas
Scooter shuts off when stopping red lights stop signs waiting to turn etc...
1965 Yamaha 50 5 Mate Riders Manual
Yamaha U5 owners manual 3920
Sep 25, 2012 | Yamaha Motorcycles
Yamaha Cygnus has petrol problem Has spark fuel not getting to carburetor
Hi, Aaronslocks always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
Fuel not getting in carb
https://traxxas.com/forums/showthread.php?366591-Fuel-not-getting-to-carb
Yamaha XC125 Service Manual
YAMAHA CYGNUS XC125 Owner Manual
Mar 16, 2012 | 2006 Yamaha CygnusX
No fuel getting to carb 2007 Yamaha yW 100 Beewee 100
Hi, Paul always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
Yamaha BWS 100 2 Stroke Scooter Problem
ScooterCommunity
YAMAHA BWS YW100E Owner Manual
Jan 12, 2012 | 2007 Yamaha yW 100 Beewee 100
Its a 1985 Yamaha xj700 maxim that has a problem with the fuel and vacuum line, from the fuel tank to carburetors and drain line diagrams
Hi, Sevensons7 always check fuel flow first to isolate the problem area otherwise the usual suspects are:
1. Fuel tank empty.
Yamaha XJ 700 Fuel and vacuum line diagram Google Search
petcock fuel yamaha maxim xj700
Yamaha XJ700N Service Manual
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Apr 02, 2011 | 1985 Yamaha XJ 700 X Maxim
Poulan Bp406 45.4cc Backpack Leaf Blower Logo
160 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
