Question about Keurig B60 Coffee Maker
The water container needs cleaning. I don't want to start pulling at it, does it come off? I can't find my manual.
    Champion:
  • 213 Answers
Yep, just lift it straight up! Hope this helps you!
Posted on Jun 14, 2010
Miele CVA5065 coffee machine- the manual states : "fill the big plastic container to the max level". What is the volume to the max level?
Filling The Water And Coffee Bean Containers - Miele CVA ...
www.manualslib.com > ... > Coffee Maker > PW 5065 > User manual
Miele CVA 5065 Manual Online: Filling The Water And Coffee Bean Containers. Thecoffee machine must be cleaned thoroughly (see ''Cleaning and care'') before you... ...up to the "Max." mark. A valve at the front of the water. container will ...
[PDF]Operating and installation instructions Built-in coffee ...
Nov 25, 2015 | Miele Coffee Makers & Espresso Machines
Pulls water at wrong time
Make certain the Filer is good and the ports are clean. You may have to flush the system and use the vinegar cleaning method described in the manual. Hard water deposits can cause this to happen as well as particles floating in the water container.
Jan 22, 2014 | Keurig B70 Coffee Maker
Not sure of the model number, but we have a built in GE dishwasher with SmartDispense that is about a year old. This morning, my girlfriend accidentally poured the wrong detergent into the...
if you have a cold wash, you can try that, don't use oil, you'll have a huge mess. cold water tends to break up the detergent, not expand it as hot or warm water will. Run several cycles to ensure a well cleared system. Turn the heat off as well. you could also try to use a sprayer if it will reach into the machine with cold water to diffuse the suds. then run the rinse cycle, which will drain the machine
Hope this helps
Joe
Aug 30, 2011 | Dishwashers
Needs descaling, I don't have the manual, what is the procedure??
Hi Auto descale: To automatically descale your machine, press the scoop or menu button and hold it down until you enter the menu. Use the arrows on the to scroll up until you come to "Descale". Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and close the open the steam knob again. Let it quit on its own. Refill tank again and prime the machine and your ready. Exit "Descale mode and scroll down to "Reset descale", press the enter button and chose "Yes", then exit and your ready for the next time.
Jul 21, 2011 | Saeco Royal Professional Espresso Machine
Water is leaking from under the refrigerator. I don't see drain pan. The black container is full of water. What do I do?
It is leaking because the container is full, remove it and if you look closer inside the fridge you will see a drain tube there. It may already clogged, so you need to declogged it by using a solid wire. Put outside the things in refrigerator and insert the wire on the drain tube slowly. If you cannot do it ask someone to help or assist you. Once the clogged is clear, rinse it with clean water. Clean also the inside of the refrigerator with a baking soda soak to water.
Good luck.
Jun 23, 2011 | Refrigerators
Cappucinatore won't pull milk through the tube
Hi
There should be a small pin on the top of the Cappuccinator. When it starts, twist the pin slowly until the milk flows up the tube. Then leave it where it is and it will work all the time.
Jul 09, 2009 | Saeco Royal Professional Espresso Machine
Rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Jul 22, 2008 | Rowenta Commercial Garment Steamer - White
Bosch tumble dryer
I've sorted mine this morning. First, disconnect from the mains - VERY important! Pull out the metal condenser unit at the bottom, and behind it, there's a small hatch in the bottom to the reservoir. This can get gunked up with water, and is very difficult to clean - HOWEVER - I've found a really easy way of cleaning it. I've got a VAX carpet washer with a hose attachment, and I simply sucked all the water out using that. If you don't own a carpet cleaner maybe borrow one. I did this this morning, and my tumble-dryer's still running happily after an hour! It is possible to clean it out without vacuum, but it takes a LOT longer, and the vacuum of the cleaner pulls out gunk that is hard to access. Another place where gunk collects is behind that hatch right at the back - there's a tube up to the right. I pulled out quite a long chunk of lint. However, that wasn't the solution on it's own, I still had to clean out the reservoir as above.
Jul 03, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Keurig B60 Coffee Maker Logo
47 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
