Question about Canon FAXPHONE L170 Plain Paper Laser
Strange whistling like noise coming from the toner area when printing. Prints are fine, worried about noise.
  • 231 Answers
Could be a noisy toner cartridge.
Open the door, remove the toner cartridge, and close the door again. If the machine does a few seconds of motor running with no noise, then that is the cause.
Not usually a major problem, just nuisance value.
Posted on Dec 07, 2009
Hp M551 laserjet printer makes whistling noise when printing
Some times the toner has a clear plastic tape that is inside the toner, the tip is on the short side of the toner cartridge. if you do not remove that plastic then it would make that whistling nosies.
Jun 05, 2012 | HP LASERJET ENTERPRISE 500 COLOR M551DN
Strange clicking noise OKI C5600
it is not the toner it is the drum. just replace the drum and it will be fine. you may of noticed your printer has been printing a little streaky. i have had this problem with my c5600 and after i replaced the k drum (the noisy drum) it was fixed intill 4 months later when the blasted thing broke again
Jun 02, 2010 | OKI C5400 Laser Printer
Streaks & Smears after changing toner cartridge.
Remove all of your toners and clean them off. Replace each one and make sure they are well setted in the unit before going to the next one. Make sure the carosel turns smoothly and nothing is hanging up on the sides. Reboot the whole printer and let it settle for 5 mins before printing. toners come lose sometimes when you turn carosel around. Hope this helps you these printers are a ***** to deal with ,but when they are right there great.
Sep 08, 2009 | Konica Minolta magicolor 2430 DL Laser...
Hp2820 noise when printing
Try substituting a new imaging drum. The problem may be a bad bearing.
Oct 09, 2008 | HP LaserJet 2820 Printer
HP LaserJet 2100tn prints ok but with 3 lines of strange characters over image
Is your transfer roller clean?
How does the drum look on the toner cart?
Is the fuser getting bad?
Would you consider this an old image that is ghosting?
Jun 24, 2008 | HP LaserJet 2100 Printer
Page is black
NO Try to remove the toner and insert it again and make sure the door is locked properly
Apr 22, 2008 | HP LaserJet 2840 Printer
Patchy Prints
I believe that the Heat roller in the Fuser has a build up of toner on it(in some areas) and as a result is not fully fusing the toner into the paper. when you use a thick setting you are actually slowing the speed down to allow more heat to the toner. the thicker paper causes more pressure allowing the toner to fuse properly. I would say you need a new Heat roller and possibley a pressure roller. You could try running 20 copies of a blank white page. Sometimes this will help. Poor fusing can also cause a previous image to come up on the next page or repeat itself down the page. A service call is in order if this does not work.
Hope this helps
Dave T
Mar 29, 2008 | Ricoh 6513 Copier
Makes grinding sounds & usually prints blank
Try new toner cartridge, or even the old one if you still have it. Check if the grinding noises go away.
Jul 06, 2007 | Brother MFC 6800 All-In-One Laser Printer
Canon FAXPHONE L170 Plain Paper Laser Logo
712 people viewed this question
old marine
old marine
