Question about Craftsman 4 Cycle Blower/Vac
CRAFTMAN LEAF BLOWER WONT START
WONT START...CHANGED SPARK PLUG,,GETTING SPARK BUT WONT FIRE...CHECKED AIR FILTER AND MUFFLER...ANY IDEAS
  • 486 Answers
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 19, 2009
Won't start
Are you getting spark on plug? Check to make sure wire is connected to plug, if still not starting. Is fuel getting to plug? Remove plug an see if its wet. If its wet it could be flooded. If not fuel lines are common on saws, tank in is a major problem it cracks an need replacing. Have you checked the on off switch? If it still wont start, carb is more than likely the problem. Remove it an get a rebuilt kit, they are cheap, carefully remove all parts clean out all orifices even small ones with a piece of brass or steel bristle from a brush, use carb cleaner to clean the parts, carefully put it all back together an it should start. That is about all there is.
Mar 25, 2014 | Husqvarna 130bt 130 Bt Gas Powered...
Echo pb251 blower wont start
remove the muffler and try it carbon plugs up the screen inside if runs good with out the muffler open the muffler and clean the screen
Jun 18, 2012 | Troy-Bilt Garden
Ran last year, won't start this year. Changed fuel and replaced spark plug. Checked spark and attempted to start with battery and tried with pull cord but no start. pulled plug and it had fuel on it so...
It might have tipped over on its side. Look at the air filter, if you see oil or gas on the filter then you might have to remove and clean the carburetor. I would start by cleaning/replacing the air filter and trying it again. If its getting fuel and the spark plug works then the only other side of the fire triangle is air.
Jun 05, 2011 | Ryobi Backpack Blower 25.4cc
I have an echo pb400e backpack blower. it wont start. getting fire but wont crank.
is your spark plug getting wet from fuel? try take air snorkel off carb and give it a shot of carb cleaner if it fires you have a fuel problem if it doesent fire , and plug is wet pull plug and rollover and get excess fuel out of cylinder, and try carb cleaner again, if no luck check compression, then if good go to flywheel and see if loose
Apr 12, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
Unable to start my 155BT blower. Have changed
Is the new spark plug wet? If not, the machine is not getting fuel (fuel filter, carb, etc.) If the plug is wet, you may not be getting spark (bad ignition module, short in switch/harness, bad plug (yes it does happen with even new plugs)), or flooding due to incorrect starting procedure or clogged airfilter. Stale fuel can also cause an engine not to start as it lacks volatility. If in doubt, take it to your local dealer.
Oct 22, 2009 | Husqvarna 155bt Gas Backpack Leaf Blower
Craftman gas leaf blower stopped working suddenly. I changed the spark plugs but it still won't start
first check for spark, if you have spark gap plug at .030. turn mixture screws completelin give a short squirt of carb cleaner directly into throat of carb and try to start if unit starts then dies ,carb needs to be rebuilt and also change fuel filter in the gastank. gas mixture 40:1
Sep 05, 2009 | Garden
Homelite ut o8107 blower 25cc will only idle
Hello:
Have you Removed the Muffler and Checked the Exhaust Port and Muffler for Carbin Restriction?
Remove the Muffler and Start the Unit. If the Operates Correctly, then the Spark Arrestor Screen is Clogged and the Muffler/Screen Requires Replacing.
Make Sure the Exhaust Port is Not Restricted Also.
Hope this Helps.
Good Luck
Respectfully
John
May 09, 2009 | Homelite 'Yard Broom' Leaf Blower
Craftman leaf blower,not starting,fresh gas,new
How long has it been sitting with gas in it ,did you have gas stableizer in it ,if not disassemble carb and reinstall it will start right up...lou
Apr 22, 2009 | Craftsman Blower Attachment
Motor not accelerate past idle, bogs down...
yes,check your spark arrestor screen in the muffler
Apr 22, 2009 | ECHO, Inc. Shred n Vac
Craftsman 4 Cycle Blower/Vac Logo
594 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
