Question about Lenovo ThinkPad Z61t 9443-XAU PC Notebook
Even when install the cd the same screen appears showing windowssystem32c_1252.nls i also f8 and tried safe mode and last time windows worked what else can i do
  • 92 Answers
Windows system 32 is the main frame for the operating system. Sorry to say your only choice may be a complete reinstall. Have a look here and it may help...
http://www.techspot.com/vb/topic73084.html
http://support.microsoft.com/kb/830088
http://www.smartcomputing.com/TECHSUPPORT/detail.aspx?guid=&ErrorID=21778
Please let me no how you get on...
Posted on Nov 19, 2009
Nls error
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 21, 2013 | Acer Aspire One PC Notebook
I want to remove win7 from my compaq cq57 laptop (intel core) and replace it with xp pro
In your case try the RAM part 1st.
Blue Screen Of Death
  • You may need to roll back system with System Restore (press F8 during boot and choose safe mode).
  • Uninstall last program(s) that was installed, again in safe mode.
  • Re-install Windows. Clean install works best.
  • Test one DIMM at time. One slot at a time. To eliminate possible bad RAM.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 01, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Computer wont bootup windows xp error loading operating system drive 1 not found please help me
1.Restart your computer. Immediately after the screen goes blank for the first time, press the F8 key repeatedly. The Windows Advanced Options menu appears. If the menu does not appear, restart your computer and try again. Use the cursor keys on your keyboard (your mouse will not work) to select Last Known Good Configuration, and then press ENTER. Windows XP attempts to start.
If you recently installed new hardware, shut down your computer and disconnect the hardware. Then, restart Windows XP and troubleshoot your hardware to get it working properly.
3.
Restart your computer and press F8 again. This time, choose Safe Mode and press ENTER. Windows XP attempts to start in Safe Mode, which does not automatically start programs and hardware, and displays very primitive graphics. If Windows XP starts successfully in Safe Mode, you can remove any programs or updates you have recently installed. Then, restart your computer normally.
Performing a repair installation of Windows XP can fix many serious startup problems. While you should not lose any of your important documents, you might lose settings, and you will need to reinstall many updates.
Before performing a repair installation of Windows XP, you should have both your Windows XP CD and your product key available.
To perform a repair installation of Windows XP
1.
Insert your Windows XP CD into your computer.
2.
Restart your computer. If prompted, press a key to start from the CD-ROM.
When the Welcome to Setup page appears, press ENTER on your keyboard.
On the Windows XP Licensing Agreement page, read the licensing agreement. Press the PAGE DOWN key to scroll to the bottom of the agreement. Then, press F8.
When prompted, press R to have Windows XP attempt to repair Windows by reinstalling important Windows components.
The repair and reinstallation process might take more than an hour. Eventually, Setup prompts you to answer questions just as if you were installing Windows XP for the first time. For detailed instructions, read Install Windows XP.
Oct 26, 2010 | Computers & Internet
Umm... can't boot to windows at all so the program that was provided wont work, can't reinstall windows automatic disk eject on startup!
And Thanks.
Mar 19, 2010 | Microsoft Windows XP Professional With...
When i turn on my computer it shows loading screen than restarts and keeps doing that over and over
try to press F8 before the loading screen appears. You'll get a menu where you can choose different options. if you installed a driver or software the last time before you restarted and the pc worked fine, then choose "last known good configuration" if this doesn't help, try safe mode, and uninstall software driver you installed before this problem appeared
good luck
Dec 25, 2009 | Dell Dimension 2400 PC Desktop
Unable to start up laptop
fristly you have to restart your computer after that press F8 key and then take your syster on last know good configuration. it will be start . if any problem occured tha press again F8 then run is safe mode if problem is continue the restart your computer press delete key,F9,F12 and key may be for boot menu the see your configurat press F9 for default configuration then restart your compute by F8 key in last know configuration it will be start
Sep 25, 2009 | Compaq Presario C700T Notebook
OS does not work in pc
The Windows 98 option seems to be DOS-only. You could try typing WIN or WINDOWS at that C:\> prompt.
For Windows XP, you can try a few things:
1. Boot into Windows XP, but hit F8 BEFORE the splash screen (with the scrolling bar) appears. You will get a menu. Try Start with last known good configuration. See if it boots. If not, repeat, but choose Safe Mode. If it will not boot in Safe Mode, you have a more serious problem. Continue to 2....
2. Insert your Windows XP CD in the CD-ROM drive (you need to have your BIOS set to boot from CD first, or look at the POST screen for an option that lets you select boot device). If it asks, press a key to boot from CD. Let it load. First off, try pressing R to go into the recovery console. Follow the instructions. When it asks you which Windows you want to log on to, choose the appropriate one. When it asks for a password, try just pressing Enter (return). If that works, you will get a prompt similar to the Windows 98 screen. Here, try the following:
CHKDSK /r
(this will take a while - just leave it. Note that you may see it restart the % count up to 5 times. You'll get a report the prompt again when it is finished. Hopefully it says it repaired one or more errors)
FIXBOOT
(say Y to the question)
Now reboot. If you get the menu screen again, don't choose safe mode or last good configuration, choose Start Windows normally.
If this doesn't work, you either have a badly damaged Windows install or a hardware fault. You could try booting into the Windows CD and doing a repair install. Where you pressed R before, press ENTER. Follow the on-screen instructions - you want to do a repair install.
Apr 20, 2009 | Computers & Internet
WHEN I START MY HP LAPTOP AFTERTHE WINDOWS XP APPEAR IT JUST STOP
It's not booting to the OS I take it. THen you need to do a recovery it you have one. First try F8 key when you turn laptop on try safe mode see if that boots. If it does restart F8 again try last know see if that one work that would be your last start up backup if that works you should be ok. If not then go to setup do boot from CD install your Windows CD restart your laptop and try doing a windows repair if that does not work then you will have to do a complete reinstall.
Good luck
Mar 20, 2009 | HP OmniBook XE3 Notebook
My think pad 600 will not start up
Will it boot into safe mode to access system restore? Other than that you should use another OS disc and try a repair install if offered. If not then a full reinstall and download the drivers from the web site
Dec 15, 2008 | Computers & Internet
Windows startup error
I lost my password on windows xp, how can I get back on the administrator screen instead of guest screen.
Feb 17, 2008 | Computers & Internet
Lenovo ThinkPad Z61t 9443-XAU PC Notebook Logo
29 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
