Question about Amana PTH123B25AJ Heat Pump Air Conditioner
Error code F1 ? - Amana PTH123B25AJ Heat Pump Air Conditioner
  • 4 Answers
Indoor ambient thernistor (black) may need replaced.
Posted on May 07, 2010
  • Nick Patel Mar 19, 2013
    where do i get this part?
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    Tip
    Troubleshooting KitchenAid oven, range and microwave error codes
    Here list of Kitchen Aid range and oven codes.
    F1 - E0 EEPROM communication error
    F1 - E1 EEPROM checksum error
    F1 - E2 UL A/D error
    F1 - E4 Model ID error
    F1 - E5 Calibration shifted
    F1 - E6 Latch signal mismatch error
    F1 - E9 Stack overflow
    F1 - E3 Wiring harness cavity size does not match stored value
    F2 - E0 Shorted touch pad
    F2 - E1 Keypad cable connection error
    F2 - E5 Cancel key drive line open
    F2 - E6 Cancel key drive line open
    F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
    F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
    F3 - E2 Oven temperature is too high (Cook mode)
    F3 - E3 Oven temperature is too high (Clean mode)
    F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
    F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
    F3 - E6 Drawer sensor open
    F3 - E7 Warming drawer sensor shorted
    F4 - E1 Meat probe malfunction - shorted
    F5 - E0 Door Switch
    F5 - E1 Self clean latch will not lock
    F5 - E2 Latch during CLEAN error
    F5 - E5 Self clean temperature not reached within 45 minutes.
    F5 - E6 Door is open, but latch is locked
    F5 - E7 Self clean latch will not unlock
    F6 - E0 Return line not connected
    F7 - E1 Common switch wire defective
    Two digit codes:
    F0 ERC Board failure
    F1 ERC Board failure
    F2 Oven temperature is too high
    F3 Oven temperature sensor open
    F4 Oven temperature sensor shorted
    F5 ERC Board failure
    F7 Function key stuck on ERC
    F8 ERC Board failure
    F9 Oven door lock failure
    Microwave and Microwave combo error codes:
    F1 - E3 or F1 - E4 Electronic control malfunction
    F2 - E0 or F2 - E1 Keypad connection error
    F2 - E3 Keypad held down too long, or keypad is shorted.
    If you get an error code, try first resetting the code:
    1. Disconnect power for about two minutes.
    2. Connect back power.
    3. If code re-appears, test and eventually replace faulty part.
    on Apr 24, 2015 | Kitchen Ranges
    Tip
    F5 - E0 Door Switch
    Two digit codes:
    Regards.
    on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
    What is the error mean f1 E1 on my may tag front loader washing machine
    Barbara, F1 E1 error is your washer doesn't think the drain pump is working properly.bad CCU or pump.
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    have E1 and F1 error code fleshing and wate Sears PartsDirect
    http://forum.appliancepartspros.com/washer-repair/443358-f1-e1-error-fault-code.html
    Appliance Repair Forums
    Error code F1E1 null ShopYourWay
    Central Control Unit CCU Maytag MHW6000XW Washer
    Mar 07, 2016 | Washing Machines
    Fix f5 e 1
    F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
    2. Re-apply power and observe for at least one minute.
    3. If code re-appears, replace control board (also called ERC or clock).
    Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
    Jun 05, 2015 | KitchenAid Architect II Superba EQ Series...
    What causes error code F1 in my Electrolux convection microwave EI303BM60MS?
    Thank you for your inquiry, Leanne!
    From the information you have provided your Electrolux microwave is displaying an error code of "F1". I am showing that an "F1" error code is not valid. I would recommend resetting your microwave and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue and you continue to experience an "F1" code please reconnect. -Matt
    Apr 27, 2015 | Electrolux Microwave Ovens
    What does F1 fault code mean?
    Whirlpool Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
    Jan 08, 2010 | Kitchen Ranges
    66993 pizza oven microwave oven combo pizza oven not heating error code f1 microwave part works
    Hello, please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
    KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
    F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
    KENMORE - 911 Series (General Electric/Roper)
    F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
    KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
    F1-E0 EPROM Error - Electronic Range Control (ERC).
    F1-E1 EPROM Error - Electronic Range Control (ERC).
    F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
    F1-E3 Fuel Type Fail
    Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
    “9” for gas-If code changes again-replace Electronic Range Control (ERC).
    KENMORE - 790 Series Electronic Oven Control (Frigidaire)
    F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
    Runaway Temp = Replace Electronic Oven Control (EOC).
    Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
    Thanks
    Jul 20, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
    KitchenAid KESS907 Electric Range E1 F1 Error Code
    F1 E1, replace Electronic Range Control.
    In other words, the controller board has failed.
    Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
    Amana PTH123B25AJ Heat Pump Air Conditioner Logo
    388 people viewed this question
    Top Amana Heating & Cooling Experts
    Dan Webster
    Dan Webster
    Donni Steen
    Bill Long
    Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
