Question about Engel Freezer 22 Qt. Fridge/Freezer
My saxo 1.6 vtr sounds like the bottom end is on its way out is it worth tryin to do it my self or how much would it cost me to do
    Problem Solver:
  • 14 Answers
Herd this so many times now the best and cheapest option is a 2nd hand engine from a breakers as they only pull 100-150 max and theres no shortage of engines for them as they get wrote off near on every day
Posted on Jan 14, 2010
Set at the coldest setting the top two shelves won't freeze water, the bottom two shelves will and the thermometer reads -5. Is this worth getting fixed? Cost?
Your coils are frosted over. Want let the fan push cold air around. I am having that issue right now. Turns out it is the control board is not telling the fridge to auto defrost or what to do and when to do it.
May 26, 2015 | Freezers
How do I fix freezer drain in Kenmore Elite french door refridgerator
Hello John;
My name is Peter. I am a retired field service refrigeration technician.
A frozen or blocked drain may not be the problem, or it may.
You have one of two problems. Regardless of which problem it is you need to remove the back wall panel in your freezer. This is not a easy task. You must remove the freezer door, the ice maker, the side guide rails. There are two clips on the back wall air distribution center section using a screw driver to depress and then some. You need to install a hot wire from the bottom of the defrost heater to the drain. Do not attempt this, you may damage some of the components if you do not have the experience.
Ok, lets check out the frozen drain the easy way. Your unit goes through a defrost cycle every 8-10 hours. This is where everything shuts down for 20-30 minutes with the exception of your lights. Your defrost heater turns on during this time.
1.) Check the Drain:
a.) Pull your unit out from the wall to where you can get behind it. You may have to raise up the leveling jack screws in the front to do this. Remove the bottom toe plate. There are two Philips head screws holding it on. Turn the jack screws counter clockwise to raise.
b.) Having pulled the unit out from the wall, unplug the unit. Remove the bottom back cover. There are several hex head screws holding the cover on.
Pull the drain tube out. It just Pops in and out. If there is a black rubber grommet at the discharge end, remove it and throw it away. The initial intent was to keep warm air from getting into the freezer. However, over time they dry up and prevents the condensate from draining.
c.) Insert a wire up into the drain hole, such as a coat hanger, to check for blockage. If it is blocked with ice, you must unplug your unit for 24 hours to completely clear the ice.
2.) Obstruction or Refrigerant Leak:
Recently, I believed my friend had a frozen drain in the same unit that you have. Upon pulling the back cover I discovered a block of ice build-up at the refrigerant and capillary tube connection. The capillary tube is about 1/16" in diameter with a small needle size hole running through it. This tube can easily become plugged, which is common. This block of ice will continuously drip. A repair of this nature is about $450.00 - $550.00. The rule of thumb is: "If the cost of repair is 1/3 or more of the original cost of the unit, then replace the unit. You can get some good deals at a Sears Outlet (Scratch & Dent) Store.
Jan 19, 2015 | Kenmore 25 cu. ft. TRIO French Door Bottom...
Ice keeps forming on the bottom of my freezer
Your kemore self defrost is not working. 1. clean the ice and look for the heater element and your lemi switch.
Sep 01, 2012 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Water/Ice pooling in bottom of freezer
check out the drainage hole if it is properly closed.
Feb 20, 2010 | Amana Freezer DeepFreeze AFU2067BW 19.6...
Got zanussi whirpool upright freezer afg8080/1x temperature gone to high is it worth getting repaired or buy a new one? freezer has been making a cliking noise and food is starting to defrost
if the freezer is over 5 years old,buy a new one under counter freezers not built in are fairly inexpensive and will cost less to run.fault sounds like temp sensor....
cheap part/labour intensive.....
Feb 13, 2010 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Kenmore chest freezer - why is there a 1/2 inch of ice in bottom
Hello. If your freezer is not a self defroster, you must have had a power failure for a few hours that caused a melt with water ending up on the floor of the freezer and then refreezing. IF you have a self-defrost model, your defrost cycle produces some water which should make it's way down to the evaporator tray just above the floor... in your case, the small hole in the floor is plugged and the water is accumulating on the floor rather than making it's way to the evaporator tray. The fix is to clean the evaporator tray, defrost the ice with a blow dryer, locate the hole and clean it out with a couple of pipe cleaners or cotton swabs. Regards, Joe
PS please rate my answer. thank you.
Jan 28, 2010 | Freezers
Frigidaire Ultrafreeze upright just stopped working
It sounds as if your compressor it's running. This could be a bad compressor, bad capacitor, bad thermostat. See that there are no fans or defrost, it is one of the other. I would start with checking the capacitor. You can replace it with a Supco 3 in 1. It cost around $30.00. Anything else is going to start costing $100.00 and more. If you need a freezer that big, I would have it fixed unless it ends up being the compressor.
Please rate solution
Sep 04, 2009 | Frigidaire 12 cu. ft. / 340 liter Upright...
Compressor very hot. the temp. will not go below 52 degrees.
one of two reasons restricted freon line (cap tube) or low on freon either way with the cost of a service call and a new one depends of the size but if you start spending more then 1/2 of what its worth then say better money New One jmho.. Tom
Jul 03, 2009 | Freezers
Freezer malfunction
unfortunetly it sounds like your freezer has lost refrigerant. as the refrigerant level drops so does the capasity of the freezer. the unit is not worth repair. unless it is a comercial unit .In that case you will nead to phone a local repairman.
Oct 18, 2008 | Whirlpool Freezers
Upright Freezer self defrosting
THE (SUCKING AIR) OCCURS WHEN THE TEMP IS VERY LOW IN THE FREEZER AND YOU LET WARM AIR IN BY OPENING THE DOOR. WHEN THE DOOR IS CLOSED, THE WARM AIR IS COOLED CAUSING A VACUUM IN THE FREEZER. IF THE DOOR SEAL HAS A LEAK AROUND IT, THE SUCKING SOUND WILL NOT TAKE PLACE. CHECK THE DOOR SEAL FOR A GAP AT ONE OF THE CORNERS OR ALONG THE SIDES,BACK, BOTTOM, OR TOP.IF THE SEAL IS O.K., HOW IS THE TEMP? IF THE TEMP SEEMS WARM, YOU MAY NEED TO CHECK THE SEALED SYSTEM. LOOK AT THE FROST PATTERN ON THE EVAPORATOR. IS IT COMPLETE AND UNIFORM? IS ONLY PART OF THE EVAPORATOR FROSTED BACK? IF THE ENTIRE EVAPORATOR IS FROSTED BACK UNIFORMLY, THE SEALED SYSTEM IS O.K.
Apr 01, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Engel Freezer 22 Qt. Fridge/Freezer Logo
67 people viewed this question
Top Engel Freezers Experts
AJMAL KHAN
Victor Nwachukwu
Victor Nwachukwu
John Tripp
John Tripp
Are you an Engel Freezer Expert? Answer questions, earn points and help others
