Question about Singer 1725
Just bought s Singer 1725. Tried a straight stitch. The thread keeps bunching up under the fabric and around the bobbin shuttle. How can this be corrected?
  • jsexton42 Nov 19, 2009
    Found the answer myself. It is called"Birdnesting."
    "Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin
    thread. This is easily corrected by rethreading the machine, following
    the threading path carefully and making sure the thread is fully
    engaged in the tension mechanism.
  • jsexton42 May 11, 2010
    The machine wasn't threaded properly. The thread wasn't inserted into the tension slot. Also tightened the tension screw on the bobbin and problem was solved.
  • 139 Answers
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Posted on Apr 16, 2010
Brother LS-2125 bunches bobbin thread then won't sew.
Check your stitch sample. Dollars to donuts it's the top thread bird nesting (also called thread nesting) under the fabric. Issues appearing under the fabric is usually top thread related. Problems appearing on the top of the fabric is usually bobbin thread related.
Remove the top thread from your machine.
Be sure to start with a brand new needle.
ALWAYS RAISE the presser foot and rethread the top.
Jan 13, 2018 | Brother Sewing Machines
I need elp with tension on singer cg550
You didn't explain the symptoms. Is the thread bunching, looping, knotting under the fabric? Is the bobbin thread rising to the top of the fabric?
If it is bunching under the fabric, it is probably what is called thread nesting or bird nesting. There are several fixes, sometimes more than one fix is required to resolve the issue.
Be sure to clean under the needle plate, around the bobbin, and the feed dogs. If the machine has instructions for oiling, follow the directions using a fresh, good quality sewing machine oil and apply only 1-2 drops each spot.
Install a brand new needle. Make sure you are using a needle compatible with the thread and fabric being used. All About Needles
Best practice is to use the same thread in both the upper and bobbin. Also, avoid old or bargain bin thread. Spend an extra couple of dollars to reduce frustration and increase success with your machine. If you wish, you may use two different colors of thread to test so you can easily determine what is happening with the tension.
Remove the thread from the machine. RAISE the presser foot and rethread from the beginning--the thread needs to be seated firmly in the tension disk. Verify that the correct thread path is followed (consult the owner's manual).
Set the upper tension to the midway point between high & low numbers (this is the factory standard and is a good place to start, but every machine is different and may need adjustment).
Confirm that the bobbin is installed in the bobbin case (turning the correct direction) and that the bobbin case is threaded properly.
Before beginning to stitch, hand rotate the handwheel one rotation and pull the bobbin thread to the top of the fabric. Then, gently hold the thread tails in the left hand and slowly begin to stitch.
Test.
If thread is bunching, looping under the fabric, the upper tension is too loose. Tighten it and retest. On most machines, the lower the tension number, the looser the tension.
If the bobbin thread is rising to the top of the fabric, the upper tension is too tight. Loosen the upper tension and retest.
Keep adjusting and testing until it is where you want it. Generally, tension is correct when both threads (upper & bobbin) meet in the middle of the fabric. FWIW, tension is static and should be tested and readjusted every time a new project is begun. The needle, thread, and fabric will affect the tension, so it is important to get comfortable adjusting the tension.
Also found the following reviews. Appears that some users have had tension issues with their CG550.
Amazon com Customer Reviews Singer CG 550 10 Stitch Commercial Grade...
Mar 17, 2016 | Singer CG550 Mechanical Sewing Machine
Shuttle action not working, doesnt catch the down thread, bunches up thread and breaks needle.
Hi. I did not have this exact problem with my Featherweight. My machine was not stitching properly (top stitch looked so-so, but lots of thread bunching on underneath side of fabric). I took it to repair shop and learned that I was threading the needle thread on the wrong side of the metal plate which is part of the take-up arm (I do not think that the threading instructions make this distinction). After the repairman pointed out the problem & threaded the machine, it made a proper stitch.
My suggestion for this issue: check the bobbin threading. My bobbin has to be inserted so that it turns counterclockwise in order to catch the down thread.
May 27, 2014 | Singer Featherweight II 117
Bobbin thread bunching on underside on every stitch setting except manual straight setting and auto tension. i have tried cleaning and oiling my machine, as well as swapping out my bobbin, thread and...
Most likely, it's because the top thread is not seated fully in the tension disk.
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
FWIW, problems appearing under the fabric is usually a top thread issue. Problems appearing on top of the fabric is usually a bobbin thread issue.
Jan 02, 2018 | Singer Sewing Machines
Top thread bunches
try changing the needle--use a needle according to the fabric
being sewed
if thin fabric is being sewed try using a stablizer
rethread the machine top and bobbin--use every thread guide
make sure the bobbin is inserted correctly and turned correctly
in the bobbin case
also try adjusting the top thread tension just a little
Oct 23, 2012 | Singer 2950 Mechanical Sewing Machine
The thread is bunching under the fabric even though the stitch looks perfectly find from the top
Change needle-flat side to the back of the machine
Clean under needle plate where feed dogs are for lint
Clean bobbin area for lint or loose threads
Rethread machine top thread make sure to get every thread guide
& make sure bobbin is wound correctly & that it is inserted correctly in the bobbin case or shuttle
Check tension 3 or 4 is usually good
with some machines the thread comes off the thread take up lever
Nov 24, 2010 | Singer Sewing Machines
Thread jamming under fabric
bobbins in backwards
flip it over
Dec 18, 2009 | Kenmore Sewing Machines
Singer Inspiration 4205... doesn't work!
Check the position of the bottom piece that holds the bobbin carrier to the left so it rides smoothly on the rotating hook that carries the upper thread around the bobbin. I found my wife"s machine loose so the bobbin carrier was out of position and not riding on the ledge of the rotating part. loosen two screws and push it to the left and tighten.
If upper thread bunches below the material it needs more tension so it pulls back up through the material.
If the old singers were fords this is a yugo
(been fixing and adjusting her machines for years. ))
Dec 13, 2007 | Sewing Machines
I have a Singer 2950. The thread keeps getting bunched up on the reserve side of the fabric, and does not stitch. It is driving me crazy. I think I have the bobbin threaded correctly, as well as the machine. I have tried everything! Please help!
Oct 22, 2007 | Sewing Machines
Singer 1725 Logo
553 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
