Question about VeriFone Omni 3700
Omni 3750 prints too light to read
I have a Veriphone OMNI 3750. The thermal printing is getting lighter and harder to read.
I have an Omni 3750 that I bought from a provider. I have since switched providers and now my Omni 3750 reads "download needed no *go variable". My previous provider gave me several passwords...
Here's Some that you can Try: 1, 0000, 1234, 1701, 1739, 000000, 12345, 998877, 123456, 752036, 23378463, 45803155, 53664337, 1[Alpha][Alpha]66831, 6[Alpha]78727[Alpha][Alpha], Hope this help if not call us @ 775- 358-2922 : - )
Jan 19, 2011 | VeriFone Omni 3700
I have an omni 3750 verifone that the thermal printing is lighter, could it be the papper or the terminal?
I am not an expert, but in my experience, the printer door is the problem. Try applying pressure while it is printing. If it prints better, it may need to be replaced.
Oct 20, 2010 | VeriFone Omni 3700
Omni 3750 is only partially printing the recipts.
You either have bad paper or you printer head is going out. Firs, replace the paper. Thermal paper goes bad over time.
Jul 19, 2010 | VeriFone Omni 3700
The print out is so light that it's very hard to read on my Omni 3750
Could be old paper
Could be the printer head is going bad
Could be the paper cover is not pushing the paper firmly against th paper roll, Put a rubber band around the paper cover and see if that helps
May 04, 2010 | VeriFone Omni 3700
My Omni 3730/3730LE VeriFone printer does not print on the paper
Ensure thermal paper is being fed from underneath the roll, as it will only print on one side of the paper. hope this help
Jan 16, 2010 | VeriFone Omni 3700
Will a veriphone 3750 work with Digital phone service? I keep getting a no dial tone error.
No, sorry, you will have communication problems on any digital or VOIP (voice over internet phone) lines. Analog phone providers is the only phone system that will take care of this problem.
Oct 20, 2009 | VeriFone Omni 3700
OMNI 3200 OUT OF INK
a lot of times there are issues with the paper cup lid not closing all the way. Try to apply preasure to the lid of paper cup and re-print a receipt and/or report. If still not printing.. Check the paper... make sure its thermal. To test you paper if it thermal... use your thumb nail and run it across the backside of the paper. If it thermal it will leave a faint gray mark the "shinny" side of the paper.
Jul 23, 2009 | VeriFone OMNI 3200 (P092-101-10) Printer
Replaced paper in Omni 3750, now it feeds but doesn't print
Make sure you are using thermal paper and it is feeding from the bottom of the roll. If not press down on the lid when the paper is printing sometmes the tension springs were defective.
Feb 19, 2009 | VeriFone OMNI 3200 (P092-101-10) Printer
Light Printing Problem
Call for a replacement unit. The printer prints by heating up the paper in a tiny dot. If it is not heating up enough, the printing is very light.
Jun 18, 2008 | VeriFone Omni 3700
Retail Supplies Logo
406 people viewed this question
Top VeriFone Retail Supplies Experts
danielle yancer
danielle yancer
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
