Question about Maytag Washing Machines
We get a P4 error and the dryer no longer works. To reset it and finish the cycle we must turn off the breaker and reset the machine.
  • 1 more comment
  • mtfink Nov 19, 2009
    Maytag Model # SG1000, Series 01. The error on the unit shows P4. It will not continue its cycle and electric must be disconnected to have the machine finish its cycle.
    Any thoughts yet?
    tHANKS. i WILL ORDER THE PART LOCALLY. yOU HAVE BEEN VERY HELPFUL.
    Top Expert:
  • Maytag Master
  • 76,070 Answers
In order to make use of this error code please confirm again the code you are showing and then suply the make and model and model number of the unit, these codes are not generic, each machine has it's own difinition..
Posted on Nov 19, 2009
  • yadayada
    yadayada Nov 19, 2009
    I am going to look into this error give me some time please.
  • yadayada
    this error code is not listed in my Maytag repair manual, I suggest you contact the repairclinic.com for definition of this code, but based on your symptoms you are going to need a CCU, this is the main circuit board that controls the washers functions. here is a part number, a picture and a price of part source of is part:
    http://www.partselect.com/PartDetail.asp...
    partselect #: Control panel
    PS2029830
    $139.00 $US
Leq1442eso
Good Afternoon Terry, thank you for your post!
Often constant beeping is an indication that the unit is experiencing a possible error. I under you have tried resetting the dryer by flipping the breaker. It is important to wait roughly ten minutes before turning on the unit. If the beeping continues, then the appliance could be experiencing a communication issue with the control board or a potential wiring failure. I would recommend connecting with a qualified appliance repairman to proceed further.
Aug 29, 2013 | Frigidaire FEQ1442ES Electric Dryer
Brand new Frigidaire FFLG2022MWO Washer/Dryer Laundry Center. After a wash cycle is finished, the washer will start again after a few minutes. A truly never ending cycle. Please help.
Good Afternoon Mauricio, thank you for your question! Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the appliance. Select a normal cycle and verify if the washer continues to run after ending cycle. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the control board, timer or could have a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
Aug 19, 2013 | Frigidaire FFLE2022MW Electric...
Whirlpool GU2300 Dishwasher. The machine stops for long periods during the cycle. All lights go out. If the machine is opened before the cycle finishes, it will not resume. If I try to restart, the normal...
Hi
Door latch.
Open and close the door to make sure the door latch is securely fastened.
Check the dishwasher wiring for a possible loose connection where it connects to the house wiring.
Fuses or circuit breakers.
Check your house fuses or circuit breakers to make sure you have power to the dishwasher.
Thanks for contacting fixya.com
Oct 24, 2009 | Dishwashers
Dryers stopped working during cycle
My dryer stopped working during a cycle last night and won't start again. The light is no longer coming on either. The first thing I checked was the circuit breaker which was fine. Can anyone tell me other possibilities? What is the anser
Jul 17, 2009 | Magic Chef CYE4000AWW Electric Dryer
Aeq6000es2 dryer getting error message PF
power failure...reset breaker for dryer restart cycle then it should be g00d!!!!!!
Mar 31, 2009 | Frigidaire AEQ6000ES Electric Dryer
Washing Machine trips circuit breaker when Drying
This will be the dryer heating element needs replacing.
Hope this helps.
Jan 21, 2009 | Zanussi WDA1055W Front Load Washer / Dryer
Dryer not heating
Answer Did you select an Air Only cycle or Air Only temperature option?
The Air Only cycle or Air Only temperature does not add heat to the dryer. Expect loads dried with the Air Only cycle or Air Only temperature to take longer to dry. Air Only cycle or Air Only temperature can be found on the control knob or button with the other temperature selections.
Has a household fuse blown or has a circuit breaker tripped?
The drum may be turning, but you may not have heat. Electric dryers use 2 household fuses or circuit breakers. Replace the fuses or reset the circuit breakers. If the problem continues, call an electrician.
Did you recently install a power supply cord on the dryer?
The power supply cord may be incorrectly installed. Review the Installation Instructions to make sure that the power supply cord is properly installed.
Dec 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Euro tech front load washing machine
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, after load finished door did not automatically open.
How old is the washer?
Treat it like an error code.
This can reset the system.
Turn the breaker off to cut the power for 5 minutes.
Then restart the breaker and try the range.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
If this does not remedy the problem, then the switch itself is bad.
Let me know how it works out.
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | EuroTech EWC177 Front Load Washer / Dryer
Tromm washing machine, front load from LG
Peace,
ngafm at your service!
Lets try this first!
Did you try to open the door when the breaker was off or only when you turned it back on??
I'm here all night if you want to write me back!
Bless You,
Please leave me a good rating in this site before you sign off!
Sep 03, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Both broken?
sounds like an electrical issue for sure, too coincidental that both would stop functioning at asime time, they are independent units and should work separately . i would check your breakers, perhaps it has partially tripped
Apr 12, 2008 | GE WSM2780W Stacked Washer / Dryer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
