Question about Motorola Talkabout FR50 (14 Channels) 2-Way Radio
Fr50 beep How do you stop the fr50 from beeping every time you press a button?
  • rsm61344 Oct 28, 2008
    I have the roger beep after I press the call or transmit button. I have 2 of these and only 1 does it. I can not figure out how to fix it. I seem to think that you turn it off, hold down some button and turn it back on but am not sure. Please advise.
    Brigadier General:
  • 6,966 Answers
Sorry but on this model, you cannot.
Kind regards.
Posted on Jan 11, 2008
How do I stop the sensor alarm from beeping? I have pressed the button many times but the beeping won't stop
figure out why it beeps first , fix whatever it is and then perhaps the beep will quit.
Nov 19, 2015 | Refrigerators
Stop beeping hour?
According to the directions: Press B - bottom left button,to go into Alarm Mode. Press D - upper right button - to activate the alarm and press again to activate the Chime, which shows on bottom left as a bell. To activate these press D. To DEACTIVATE them press D again. Press B 3 times to return to Time Telling Mode. It took a few tries, but D and B are the keys to stopping that annoying chime!
Oct 18, 2013 | Armitron All Sport Digital watch
Frigidaire microwave has annoying beep, can it be turned off? model no. FFMV162LQA
Hold the 2 button and Stop button at the same time. To restore hold 2 button and Start button at the same time for 30 seconds.
Aug 19, 2012 | Kenmore 80809 Microwave Oven
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Annoying Beep on Adidas Watch
try holding down one or more of the buttons at once, you should hear a short beep indicating that the beep is off
Jun 18, 2009 | Adidas Candy Digital watch
Beeping watch
When in the 'TIME' mode, Press the button top-right of the face - the bell should disappear, and the hourly beep, and the buttonpress beep.
Jim
Mar 13, 2009 | Nike Imara Run WR0075-014 Wrist Watch
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
My dryer keeps beeping after 30seconds of turning it on. I have pressed the 'LOCK' key to unlock & even then it still does the beeping thing! Could this be the motherboard packing up?
I had the same problem. My wife was about to take an axe to the darn thing. The frustrating thing was that it was beeping 3 times and the status lights were flashing. The manual only described 4 beeps (Dryer ran too long) or 6 beeps (Push button does not function). It finally dawned on me that it was beeping two sets of three beeps (i.e 6 beeps). The corrective action was to press buttons lightly and release. I pressed on every button first lightly then heavily with no success. I pounded on the instrument panel; still no luck. Finally I pressed the Options button and the Select button simultaneously for a second and heard a click. After that, no more beeping. According to the manual this activates a "LOCK' feature if you hold them down long enough. But in my case, the lock light flashed but didn't engage and after the beeping stopped, I left well enough alone.
Hope this helps.
Jun 22, 2008 | Dryers
Fr50 beep
Hello mtnrvr,
The Motorola TalkAbout radios, especially the FR50 and FR60, are notorious for making a variety of beeps when you push buttons and activate various functions of the radio.
The beeps can be helpful when you are trying to operate the radio in low-light situations. But they can also be mildly irritating.
Sadly most models of TalkAbout do not provide any way to disable the beeps. I'd suggest not using this particular radio for covert surveillance missions.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Apr 12, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
Motorola Talkabout FR50 (14 Channels) 2-Way Radio Logo
145 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
