Question about Compaq Evo N610C Notebook
LCD Panel Dying....Inverter Issue? CCFL Lamp Burning out?
Hi there.... I picked up my EVO N-610c a few months ago... Everything was running great...
Im Running windows 2000.
Lately after the System has been on for 1 Hour + The bottom right ( and in fact the entire right fifth ) of the screen looses a slight amount of brightness, which is replaced by a faint red glow... The Screen is usable, but as time passes the glow becomes more pronounced and the said portion of the display less luminated... I Originally thought it was disturbance from my CRT monitors, but ive tested the laptop out in the open, and the same thing happens...
Im thinking it Might be the CCFL Lamp... Could anybody Confirm.
Thanks in Advance :)
    Scholar:
  • 94 Answers
The problem is not the inverter. The problem is with the backlight. Being similar to a flourescent tube, it is glowing pink, because the gas inside the tube is getting weak. You will need to replace the backlight, or the whole screen if no one in your area is qualified. It is the width of a large pencil lead, and just a
fragile. So if you have to handle it yourself, replace the LCD. Easier, but more expensive.
Inverter issues are usually ON/OFF screen. Either it works or not
Posted on Jan 11, 2008
Screen occasionally, randomly, 'blacks out' for a few seconds.
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Nov 29, 2009 | Toshiba Satellite A105-S4004 Notebook
Evo N600C, display is 'dim' and mainly 'red'
There is one CCFL lamp on the bottom edge of the LCD screen.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 04, 2009 | HP Compaq Evo Notebook N600c
Dell Inspirion Laptop Screen Randomly Flickers, Then Blacks Out
If this laptop is only a few monthe old, then it should be still under warranty. I suggest you return it to the supplier for repair or replacement under warranty. If you try to repair it, most likely you wil void your warranty.
If you don't have this choice then read the following info.
You most likely have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Aug 06, 2009 | Dell Inspiron 1100 Notebook
The screen on my Compaq Evo N610c is dim
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jul 11, 2009 | Compaq Presario Notebook
Evo n1020v screen problem
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display or appear black.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
May 21, 2009 | Compaq Evo N1020V Notebook
Screen turns blank all of sudden and works normal after switching of the system for 1 hr or so.
You could have a defective screen - a defective inverter or a CCFL lamp.
May 12, 2009 | HP Compaq dx2250 Microtower - Get 3...
Problem with my screen
May 11, 2009 | Compaq Presario R3000 Notebook
Laptop screen illumination
The fault could be a faulty CCFL lamp or inverter.
Check out
www.lcdparts.net
Nov 03, 2008 | Gateway SL9550-30165318 Notebook
Replace CCFL lamp
You may not need to replace the ccfl lamps, usually the problem is the inverter that supplies the voltage to the lamps
Apr 11, 2008 | Compaq Evo N600c Notebook
Flickeing like a dying fluorescent light bulb
Actually this is a 'warning' signal from your lcd monitor. The problem is your lcd ccfl lamp are near to their life, need to change. The ccfl lamp like our home fluorescent lamp, when the lamp need to dead, the lamp will flickering first, after some time, will totally off(dead). So, this is a signal for you. Some lcd monitor, when their inverter board are using fairchild inverter ic(oz series), will easily shutdown your monitor when they detected some flickering on your screen (ccfl lamp). If you need more information on repair your lcd monitor please visit http://www.fastrepairguide.com . Thanks.
Jan 17, 2008 | Samsung SyncMaster 710N 17" LCD Monitor
Compaq Evo N610C Notebook Logo
243 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
