What cables do i use to connect to the tv...the vcr has yellow and white areas to connect and the antenna....it tapes, but i do not get a picture when i play it
  • 45 Answers
First off, you need to hook up audio and video by using either an A/V cable or a coaxial to connect the VCR player to the TV, for the A/V cable, the yellow, white and red jacks are coded, match the jacks up with the wires, put one end of the A/V cable to the VCR player OUTPUT jacks and the other end to the INPUT jacks in back of TV. For the coaxial cable, connect the OUT TO TV or OUTPUT jack of the VCR to the ANT. IN or INPUT JACK of the TV. Connect the power cables of both units to wall outlets, and then you're set. Good luck to you!
Posted on Dec 13, 2009
When I play the vcr tape the picture is fine but no sound and the tv volume is turned up. Why?
you may have the vcr connected via a video cable from vcr av out to tv av in. If this is the case you should have an rca type audio out on the VCR and a audio in on the TV the plugs are Red and White color coded. THe video is usually yellow color coded. You may have an rf out on the vcr you need a tv cable from this to the TV antenna in port
if using this connection with a video cable instead of a 75 Ohm tv cable. the impedance is different and this could be another cause of your problem. The cables look identical but are different electrically.
Oct 13, 2014 | Televison & Video
Put vhs tape in vcr push play. Screen is blank but i have sound
You may want to make sure the yellow video cable is plugged in to both the TV and the VCR if you are using the red, white, and yellow cables to connect your VCR. If you are using a coaxial cable, then there could be a problem with your TV. Can it display other pictures from other sources? Also, VHS tapes can deteriorate over time. Maybe it's just old.
May 16, 2011 | Computers & Internet
Have no sound from VCR, cable hooked up properly, picture is great. TV is brand new.
Connect RCA cables yellow, white and red from VCR to TV. White and red are sound. Select TV input where VCR cables are connected using TV remote. Try different tapes. Turn up volume on TV.
Aug 12, 2010 | Toshiba M755 VCR
Don't know how to connect my vcr to my tv
You can either plug RCA cables from the audio and video, audio is red and white for stereo or just one of them for mono, the video is yellow, from the "outputs" on the VCR to the matching colors on the tvs "inputs". You can also connect the antenna output on the VCR to the antenna input on the tv and put the tv on channel 3 or 4, if done this way connect the antenna/cable to the VCR antenna in and connect a cable from the antenna out to the tv.
May 27, 2009 | Televison & Video
LXI VHS - No Video on TV
Hi Carol!
I'm assuming the box you have this connected to is a cable converter box. If this is true, it won't have inputs for video and audio; those RCA jacks are outputs to a TV or other device that can take that kind of input. Connecting your VCR outputs to those jacks does nothing.
The simplest way to connect the VCR to the TV is using the VCR's RF output (channel 4 in your case) from the connector that says "out to TV" or "antenna out". Just remember that outputs connect to inputs. Connect the cable box output (the one marked "out to TV") to the VCR's antenna input. Then connect the VCR's antenna output back to the TV. You will need to pick up another connecting cable with F-connectors if you don't have one. Then you just put the TV on channel 4 to watch tapes. Just leave the VCR turned off for normal TV viewing.
This connection scheme also allows you to record a program from the cable box. The only thing you have to remember is that the VCR must always be set to record on the cable box output channel (channel 4, you've said). The cable box selects a channel from the cable system, but it's always sending channel 4 to the TV. (If you're confused, you're not alone. This is the part most people have trouble getting a handle on.) One thing you can't do is record and watch different channels at one time, though.
If the TV has an AV input available, it will have the three color-coded RCA jacks on the back for the audio and video from the VCR. Connect the VCR to those inputs and switch the set to the AV input to watch tapes. (If the TV isn't a stereo model, it will have only one audio input jack - white - and you'll need to get a Y-adapter at Radio Shack to join the right and left audio into one plug for the TV.) You'll get a better-quality picture and sound connecting the VCR this way.
May 25, 2009 | Rio Go Video DDV9475 Dual Deck VCR
There appears to be no 'menu' button on the remote
First make sure the cables are truly in the right places. The antenna or cable goes to the VCR's antenna input connector, and there should be a cable from the output connector to the TV's antenna input. Sometimes people get the input and output cables reversed.
The VCR's output to the TV will either be on channel 3 or 4. Those are the only choices, so you should be getting the signal on one of them. On some Sanyo models there is a switch on the back near the "out to TV" connector to select the channel. On others you need the remote to select through the VCR setup menu. Check the remote for a button labeled "TV/VCR" and press that while a tape is playing. That button controls whether the signal from the VCR goes to the TV, or if it just passes the antenna signal through to the TV. Try both channels 3 and 4 on the TV.
If you are never able to get a picture from the VCR on either channel, its RF output section may be bad. This can happen. You can get around this if your TV has a/v inputs available. Connect the red and white audio (red is right channel and white is the left) output jacks and yellow video output jack on the VCR to the corresponding inputs on the TV. Then switch the TV to the a/v input to watch the VCR.
Apr 12, 2009 | Sanyo Televison & Video
Cannot connect zenith vcr to zenith tv thru cable box
Hello mcgillicu390,
From your VCR you should have an (RF OUT) and an (RF IN) Connector (these also might be marked as ANT IN and ANT OUT, or CABLE IN and CABLE OUT).
The same goes for your TV (RF IN), (ANT IN) or (CABLE IN).
Now, take your Coaxial Cable (Cable with screw on or Push on connector with a wire in the center of it) and connect it to the TV (RF IN), take the other end of the same cable and connect it to the VCR (RF OUT).
Then connect your cable TV set top box or antenna to the (RF IN) of the VCR.
If you are using a cable box set your VCR and TV to Channel 3 or 4 (depending on your area)
If you are just using the VCR and an antenna set your TV to channel 3 or (depending on your area).
That should do it for coaxial connectivity.
If you are using the composite video and Audio cables to connect to your TV here are the directions for that.
Looking at the back of your TV you will see Three RCA type connectors colored as Yellow, White, and Red. Yellow is Video, White is your Left Audio, and Red is your Right Audio. They should be marked as (Video IN), (R Audio IN), and (L Audio IN). *note these markings may not be exactly like what is written, however the indicators should be close to what you are seeing.
Now look at your VCR, you may see a lot of RCA Connectors (up to 6 of these connectors) don't worry, you are only looking for the ones that say (Video OUT) (R Audio OUT), and (L Audio OUT).
Once you find the connectors on both pieces of equipment, take the Yellow, Red, and White tipped cables and plug the in their respective jacks Yellow tipped cable connects VCR (Video OUT) to TV(Video IN). Red tipped cable connects VCR (R Audio OUT) to TV (R Audio IN), and finally White tipped cable connects VCR (L Audio OUT) to TV (L Audio IN),
Once the cables are connected you will be able to use the composite selection on your remote to view the images from your VCR, the VCR in this case will be acting as the tuner for your TV with out you having to set the TV to channel 3 or 4, you will just have to use the AUX or whatever setting on you remote that allows the composite video to display.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 27, 2009 | Zenith B27A11Z 27" TV
Different sound to picture
When connecting VCR to TV. Verify all connections. First if the connection is with coaxial cable make sure you signal from outside is screwed to the cable input on VCR. Then the VCR/TV output has the cable running to TV input. If hooking up with RCA cables , which is the yellow, red, and white cables. Hook one side up to VCR output. Yellow for Video, while red/white to audio output matching the colors. The same is done to the Television input. yellow for video, red/white for audio. Do a test recording. Use a blank tape, not one already recorded on. Record about 5 minutes Stop recording , rewind and playback. You should see the difference.
Oct 13, 2008 | Televison & Video
Troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Aug 14, 2008 | Televison & Video
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Televison & Video Logo
118 people viewed this question
Top Televison & Video Experts
