Question about Beko 24 in. D3421F Free-standing Dishwasher
Water pump blocked - Beko 24 in. D3421F Free-standing Dishwasher
  • Ginko
    Ginko May 11, 2010
    Hi.
    You will need to disconnect appliance from power, to access the pump hose located in the lower side of the tub, and to undo the pump hose, so to remove eventual blockage.
    If there is no blockage, then the impeller pump may need replacement.
    Spares for most appliances available here:
    Appliance Parts
    Regards.
  • Beko Master
  • 19,396 Answers
Hi.
Spares for most appliances available here: Appliance Parts
Regards.
Posted on Dec 02, 2009
1995 Altima 2.4L How to reassemble water pump to the water pump body(or water pump cover or water pump housing ) to engine block.
There's a YouTube video at the link below showing replacement of the water pump and thermostat. It's lengthy, but at 29:40 and 30:18, it shows the cover bolted to the block. It should give you a pretty good idea of the orientation of the cover and the water pump.
According to information I found elsewhere, 1993-2001 is all the same.
1999 Nissan Altima Replacing The Water Pump And Thermostat
Dec 11, 2016 | 1995 Nissan Altima
Water pump stops pumping at ho water pump stops pumping at high RPMs
check for blocked radiator cores
check that if the thermostat is at the bottom hose in the block that it is operational ( opening)
check that the bottom radiator hose is not collapsing at high rpms water pumps very seldom stop pumping unless they cannot get water to the vanes from thermostat is not opening ( too cold or faulty)
radiator is blocked
air lock in system
bottom hose is too soft and collapsing under suction
Aug 07, 2015 | Cars & Trucks
Why is there no water flow through on pressure washer?
Sounds like a pump failure. Does yours freeze in winter? Need to winterize like cabin plumbing.
Repair/replacement of pump could be close to new unit.
Aug 19, 2014 | Powerboss 2600 PSI Gas - Cold Water...
NEED HELP, ANYBODY , I DROP A BOLT FROM THE WATER PUMP INSIDE THE ENGINE COOLING BLOCK WHEN I WAS CLEANING THE BLOCK TO INSTALL A NEW WATER PUMP IN A 1994 FORD RANGER, CAN I JUST LEAVE IT INSIDE THE BLOCK...
You probably can, and here's why.
See if this is true on your Ranger.
Most cars and trucks have the water pump connected to the lower radiator hose.
The way it works, the pump pulls (sucks) the water from the bottom of the radiator and pushes it throughout the moter, where it returns in the top hose to be cooled in the radiator.
The flow is from top to bottom in the radiator.
Unless that bolt is so small it eventually winds up blocking your thermostat, it should probably stay in the water jacket.
If it blocks the thermostat some day, it may be retreivable in the thermostat hole.
Blessings to you.
Jan 21, 2013 | Cars & Trucks
How do you change water pump on a olds 98 regency
first pop the hood and locate the water pump pulley. drain the coolant into a suitable container. there will be alot of it so get a big container.use the correct size socket and loosen the four small bolts on the pulley.DO NOT TAKE THEM ALL THE WAY OUT YET. find the tensioner pulley and put a socket on the bolt and lift the pulley to release the pressure on the fan belt and slip it off the water pump pulley.now remove the bolts from the water pump pulley. now all you have to do is remove the bolts that attach the pump to the engine block. remove the pump and clean the surface of the the engine block where the pump connects to the block. don't scratch the matting surface of the block.oh disconnect the coolant hoses that attach to the water pump.BE CAREFUL THE COOLANT WILL DRAIN OUT OF THE BLOCK AND HOSES. DOGS AND CATS ARE ATTRACTED TO THE COOLANT, IT WILL KILL THEM IF THEY DRINK IT.have fun
Jun 11, 2012 | Oldsmobile Regency Cars & Trucks
How to replace water pump 2003 alero. 3400 engine.
Removal & Installation 2.2L Engine To Remove:
  1. Disconnect the battery ground cable.
  2. If equipped with an automatic transmission, remove the exhaust manifold..
  3. Drain the cooling system.
  4. Raise and safely support the vehicle.
  5. Remove or disconnect the following:
    • Right front wheel and tire assembly.
    • Access plate on the water pump sprocket from the timing cover.
  6. Install J 43651 water pump sprocket holder or equivalent to the water pump sprocket.
  7. Use the access plate bolts to attach J43651 to the engine front cover.
  8. Remove or disconnect the following:
    • Bolts that secure the sprocket to the water pump.
    • Bolt that secures the engine block to the water pump.
    • Bolt that secures the engine front cover to the water pump.
    • Feed pipe that joins the thermostat housing to the water pump. chevy_cav_02-04_wp.gif
    • 2 Bolts that secure the water pump to the engine block.
    • Water pump.
To Install:
  1. Use a threaded stud in the hub to align the water pump sprocket.
  2. Install or connect the following:
    • Water pump.
    • 2 bolts that secure the water pump to the engine block.
    • Front cover bolt and the bolt that secures the engine block to the water pump. Tighten the bolts to 15 ft lbs (20 Nm).
    • 2 of the bolts that secure the water pump sprocket to the water pump.
  3. Remove the threaded stud.
  4. Install the last bolt.
    • Tighten the bolts to 89 in lbs (10 Nm).
  5. Remove J 43651.
  6. Install the access plate on the water pump sprocket to the timing cover.
  7. Install the access plate bolts.
    • Tighten the bolts to 18 in lbs (10 Nm).
  8. Install the front fender liner.
  9. Install the right front tire and wheel.
  10. If equipped with an automatic transmission, install the exhaust manifold.
  11. Fill the cooling system.
  12. Connect the battery ground cable.
2.4L Engine To Remove:
  1. Disconnect the negative battery cable
  2. Drain the engine coolant.
  3. Remove the exhaust manifold.
  4. Remove the coolant intake pipe as follows:
    1. Remove the coolant inlet pipe bolts.
    2. Remove the wheel and tire assembly.
    3. Remove the engine splash shield.
    4. Remove the bolts from the transaxle-to-engine block brace and remove the brace.
    5. Remove the radiator hose from the coolant inlet pipe.
    6. Remove the coolant inlet pipe to oil pan bolt.
    7. Remove the coolant inlet pipe, thermostat and seal.
  5. Lower the vehicle.
  6. Disconnect the heater hose quick connect from the heater outlet pipe.
  7. Remove the front timing chain cover and the chain tensioner.
  8. Unfasten the water pump-to-cylinder block bolts.
  9. Remove the water pump-to-timing chain housing nuts.
  10. Remove the water pump and cover mounting bolts and nuts.
  11. Remove the water pump and cover as an assembly. Separate the two pieces after removal.
  12. Clean the mating surfaces.
To Install:
  1. Install the water pump cover to the water pump assembly.
  2. Install and hand tighten the pump cover mounting bolts.
  3. Install water pump cover assembly.
  4. Install and hand tighten the cover-to-block mounting bolts.
  5. Install and hand tighten the water pump-to-timing chain housing nuts.
    • Tighten the water pump-to-timing chain housing mounting nuts to 19 ft lb (26 Nm).
    • Tighten the water pump cover-to-water pump mounting bolts to 124 in lb (14 Nm).
    • Tighten the water pump cover-to-engine block bolts starting with the bottom bolt first to 19 ft lb (26 Nm).
  6. Install the heater hose to the water pump pipe.
  7. Using new gaskets, install the exhaust manifold.
  8. Install the oil level indicator and tube.
  9. Connect the brake vacuum tube to the cam housing.
  10. Raise and safely support the vehicle.
  11. Install the catalytic converter.
  12. Install the coolant inlet pipe.
    • Tighten the inlet pipe-to-oil pan bolt to 19 ft lb (26 Nm). Tighten the coolant inlet pipe bolt to 124 in lb (14 Nm).
  13. Install the timing chain and tensioner.
  14. Lower the vehicle.
  15. Connect the oxygen sensor.
  16. Fill cooling system and check the system for leaks.
3.4L Engine To Remove:
  2. Drain the cooling system.
  3. Loosen the water pump pulley bolts.
  4. Remove or disconnect the following:
    • Drive belt.
    • Water pump pulley bolts and pulley.
    • Water pump bolts, pump and gasket.
    • Clean the water pump mating surfaces.
To Install:
  1. Install or connect the following:
    • Water pump gasket and pump.
    • Water pump bolts.
      1. Tighten the water pump bolts to 89 in lbs (10 Nm).
    • Water pump pulley and bolt until snug.
    • Drive belt.
  2. Tighten the water pump pulley bolts to 18 ft. lbs (25 Nm).
  3. Fill the cooling system.
  4. Check for leaks.
  5. Connect the battery ground cable.
Aug 31, 2010 | 2003 Oldsmobile Alero
How to replace the water pump on a 1992 geo tracker 1.6 liter engine
Water Pump - REMOVAL & INSTALLATION
During these procedures, identify all components removed from the engine so that they may be reinstalled in their original positions. If discarding the old components so that new components can be installed, identifying the old items is not necessary.
1.3L and 1.6L Engines
  1. Remove the timing belt cover, timing belt, tensioner, plate and spring.
  2. Remove the water pump mounting bolts.
  3. Remove the one (1.6L MFI engines) or two (1.3L and 1.6L TFI engines) small rubber seals from between the water pump and the oil pump, and the water pump and the cylinder head.
  4. If necessary for clearance, remove the oil level dipstick tube retaining bolt from the engine block and the alternator adjusting brace.
Fig. 1: Exploded view of the water pump mounting
WARNING Do NOT use a prybar between the water pump housing and the engine block to separate the two components; this can cause scratches and/or gouges, which can prevent proper sealing.
  1. Pull the water pump off of the engine block. If the water pump is difficult to remove from the engine block, use a soft-faced mallet to tap the water pump housing until it loosens.
Do not disassemble the water pump; if the water pump is damaged or defective, the entire unit is replaced.
  1. Thoroughly clean the water pump gasket mating surfaces of old gasket material and corrosion.
To install:
  1. Along with a new gasket, install the water pump on the engine block. Tighten the water pump mounting bolts to 88-115 inch lbs. (10-13 Nm).
  2. On 1.3L and TFI 1.6L engines, install two new rubber seals: one between the water pump and oil pump, and the other between the water pump and the cylinder head. The MFI 1.6L engines only use one rubber seal, located between the water and oil pumps.
  1. If removed, install the alternator adjusting brace and the oil level dipstick retaining bolt.
  2. Install the timing belt, tensioner, plate, spring and cover.
Hope helps (remember comment and rated this).
Jul 19, 2010 | 1991 Geo Storm
For pressure washer Model WP-2402-SWHB, SN 10132043: With Honda engine running, or no engine running, no water will pass through the pump.
Hi If no water is passing through your pump on mains water pressure and not sucking from a barrel then it will be either a blocked nozzle,blocked unloader on the side of the pump or a blocked water filter.
Dec 11, 2009 | Garden
I just replaced the water pump on my 1990 f150
You have to take the water pump back off and the peice between the water pump and the block and take it too and clean the surface off good with a metal scraper or sharp regular screw driver and put a new gasket on or if you cant get a gasket some high temp.rtv on the surface between the block and the adaptor to the water pump.
Sep 02, 2009 | 1990 Ford F150
Beko 24 in. D3421F Free-standing Dishwasher Logo
387 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
