Plasma TV keeps turning off and blinks 5 times
I've had this plamsa for about 2 years now. It worked fine until a couple of months ago. I would be watching TV and it would just turn off by itself and the red light would blink 5 times and repeat.
The only way to get it working again is to turn it off at the power point and wait awhile. Sometimes it would work again for a few hours, other times it would just turn off as soon as I switch it on.
Does any one have the service manual or know what could be the issue?
Thank you
  • clareJ Jan 11, 2008
    Product: Panasonic Plasma TH-42PV30
  • shaz73 Apr 04, 2009
    my 50 inch plasma is also doing this. had it in the workshop for 6 weeks but they couldnt find the fault. tv was only 13 months old and after checking the software, they said that there had been an error code but on checking the manual the engineer said he still didnt know what the fault was. he done a few adjustments but after only a week back, the same thing has happened again. it turns itself off and the standby red light flashes about 5-7 times. the only difference was I didnt give him my power supply as he had one so that is the only thing I could think of as to why it didnt turn itself off with him. though he said that it wouldnt be the power supply i have my doubts. regards sharon
    Sergeant:
  • 257 Answers
Bad capacitors on the power board. If they look swollen or enlarged then they are most likely not holding enough charge.
Posted on May 17, 2017
6ya staff
SOURCE:
Anonymous
SOURCE: Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Posted on Apr 21, 2009
Anonymous
  • 11 Answers
SOURCE: 50 inch Plasma panasonic TH-50PZ80U.
if you have a warranty let them check it out before opening the panels, it may void it.... may be an internal power short.
Posted on May 14, 2009
Anonymous
  • 16 Answers
SOURCE: Picture & sound suddenly shut off. power light blinks red 5X...5X
http://www.sonya20tvclassaction.com/main/home.sfx MAKE SONY FIX IT
Posted on Dec 03, 2009
SOURCE: samsung fpt5884 plasma TV power issues
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
Remember there are leathl Voltages inside TV's, and generally these days don't contain any "User Servicable parts" like in the "Old" days, instead Board Replacment is all that is generally done.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Posted on Jan 24, 2010
freetek
Steve Allison
  • 5569 Answers
SOURCE: Hello "experts", My Panasonic Viera TH-50PV600
That's a fairly common indication that a component in the main power supply called an 'electrolytic capacitor' is fading away. These are used as filters and in feedback paths in switched mode power supplies and one of the parts on which mfr.'s safe a nickel or two. If these parts are not rated for the type of service they perform (higher frequencies and ripple current) they chemically break down and lose value until they no longer can serve their purpose.
If you open the back of the set after allowing a number of hours (overnight is better) with the plug pulled, look for a smaller circuit board with larger than average parts. Some of these will be blocks (transformers and chokes) and it will have cylindrical 'cans' that are mounted 90 degrees to the board. Look for a part number which may be on a sticker. If you can find this, contact Panasonic service in your area and ask about repair or replacement cost of this board. If either causes a faint heart, check on the site below to see if they happen to have this board on hand, it may save some money:
Jimmy's Parts
Subassemblies are normally plugged in and won't require soldering to replace.
Posted on Mar 19, 2010
I purchased a Panasonic TC-P50s30 50" Plasma TV
You did a good thing; really!! Keep that TV aside you always.
Jul 11, 2017 | Panasonic 50 in. Plasma TV
Hi, Approximately eighteen months ago, I purchased a 42 inch plasma Panasonic television model number: TH-42pz77u) but Saturday night, the television turn off and have five blinking red lights. Then we...
The 5 blinks on the LED means that the main logic D board is defective and will need to be replace to fix the TV.
Check this site to find replacement parts to fix your plasma if you intend to DIY.
Let me know if you need further assistance.
Jan 15, 2011 | Panasonic Viera TH-42PX80U Plasma TV
42hp66 plasma tv turns off and red light goes out
Most likely the "Y sustain" board is about to give out.
Oct 09, 2009 | Televison & Video
42PF7220A/37 Blinking red led (7 times)
sounds like your tv in shut down mode why lamp needs 2 be replaced nominal cost 120 200$
Jul 25, 2009 | Philips 42PF7220A 42 in. Plasma Television
Sanyo 50 inch plamsa just quit!
the power supply of the tv is too sensitive. you need to have a good spike guard for this.
Jan 10, 2009 | Sanyo DP42746 42 in. Plasma Television
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Dec 12, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
3 months ago Led blinks 7 times now Led blinks 6 times
Sorry to hear that. You could fix it with Best Buy or the warranty service repairman recommended by Panasonic.com
I have a client that had used one of the panasonic repairman to fix the same problem that you have about a year ago,the TV is good ever seen.
I am in the A/V installation business, my recommendation(Pioneer Kuro Plasma TV or Sharp LCD.)Very good track records from my clients.
solutiondoct
Nov 03, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Vizio, Model P4, manufactured in 2003 -- worked fine until 5 minutes ago
I have the same tv and the same problem. The power switch in the front flashes a bunch of times, but nothing else happens. Have you had any success in getting yours fixed?
Sep 08, 2008 | V, Inc. Vizio P4 Plasma Television
Televison & Video Logo
1,924 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
