Question about Insignia Digital-to-Analog Converter for Analog TVs
What is the codes for a sanyo tv that will connect to a rca/dta800 converter box. I have lost my manual and need to the codes for a Sanyo television.
    Problem Solver:
  • 12 Answers
Not for sure but try 007, i have a different brand converter box hooked to a sanyo tv and it's code is 007, i will try and find out more if i do i will post it
Posted on Nov 27, 2009
I have a RCA converter box and switched to a new TV and can't find the book so I need all the program codes for my RCA converter box to all Sanyo TV sets to reprogram it accordingly
go to this place and download the codes and instruction manual www.fitness.manualsonline.com or www. retrevo.com or www.remotecodelist.com
God bless you
May 25, 2012 | Sanyo Televison & Video
I have a RCA Converter box. ATSC mfg Dec 2010. I need the access code for the tv I am hooking up this converter box too. Sanyo Television. Thank you
Hello
Try these links.
tv.manualsonline.com/.../rca/...converter-box/remote-instuctions-213
Try these codes too:
037, 082, 083, 124, 198, 268, 274
http://www.dataentryjobs.us/67948.html
Feb 08, 2012 | Televison & Video
I have a sanyo television which i lost the remote to and i want to use a one for all remote instead .. how do i get the code for it because i have lost the manual to it
If you have the universal remote for it,you can google the remote brand name(say RCA) remote control codes for Sanyo TV's.
Good luck! Greg
Aug 08, 2010 | Sanyo Televison & Video
Need to program rca univ remote for sanyo tv & i lost the manual
Get your Sanyo TV codes and one by one program the into you RCA universal until you can turn the TV on and off. Find codes at Sanyo.com, the manual, Sat Manual, Vcr Manual etc.
Sep 19, 2009 | RCA Universal Remote Control
RCA remote codes lost
Codes For Model RCR311B
Code 1004 for Sanyo TV Code 1048 for Sanyo TV Code 1049 for Sanyo TV Code 1073 for Sanyo TV Code 1080 for Sanyo TV Code 1162 for Sanyo TV Code 1169 for Sanyo TV Code 1180 for Sanyo TV
Codes found here: http://remotefinder.rca.com/default.aspx?site=rca
RCR311B manual (PDF): http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
May 26, 2009 | RCA RCR311B Remote Control
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
I have a ILO TV and need the codes for a RCA DTA800 converter
Already found solution with codes from Orian that worked.
Thanks
Jan 04, 2009 | Hitachi 57F510 57" Rear Projection...
Need sanyo tv code to connect rca/dta800 converter box
sanyo 037,082.083.124.198,268.274 Press program, three number combo, ok, check volume control for function
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Need a progam code for rca dta800
I just tried their web site and it worked! They have the codes. www.1800customersupport.com/rca
or here is the direct link: http://www.1800customersupport.com/productdocuments/DTA800B1_Program_Codes.pdf
Hope this helps others who have had the same problem. Mine did not even come with these codes!!!
Jul 07, 2008 | Hitachi 57F510 57" Rear Projection...
Insignia Digital-to-Analog Converter for Analog TVs Logo
216 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
