Question about Poulan Garden
Why is the gas cap very hard to remove and put on?
  • jd_one Nov 19, 2009
    the saw is a pp4218avx and I use gas that does not contain ethanol (at least the pump says no ethanol). A friend with a 18' poulan wildthing has the same problem.I called Poulan and they said the is no recall or report of this being a widespread problem but after posting my ? I looked more online and it appears to be a very common problem. Cheap materials maybe? Gonna save up and buy a real saw, a Stihl!
  • 3 Answers
The cap does absorb the gas and it does swell. You might want to try putting the cap in the freezer for 5 or 10 minutes. It worked for me and the cap went on real easy. no problems
Posted on Sep 28, 2010
I literally **** my pants trying to take the cap off my poulan p4018wtl,, not once but twice
Posted on Mar 31, 2010
    President:
  • 2,220 Answers
Are you storing it with fuel in the tank? You don't provide a model number. I suspect she is a little long of tooth. The vented fuel cap didn't have to deal with the ethanol added to most fuels today. My Pioneer fuel cap swelled when I put her away wet, now I grunt a little removing it. A new fuel cap may only solve this problem for a short while. Isn't ethanol wonderful? Fuel line replacement is next. HTH
Lou
Posted on Nov 19, 2009
  • dontbother10
    dontbother10 Nov 19, 2009
    No problem with my Husky, 2 Macs, Poulan 1800 (Craftsman). or Remington Yardmaster; only the 2 Pioneers. Some Poulans are better values than some low end Stihls IMO. I've been using 100LL Av-Gas for a while... guarantee no ethanol! Lou
  • dontbother10
    dontbother10 Nov 20, 2009
    If you are serious about a professional grade chainsaw I think Dolmar is the most saw for the least money. At least in the size I prefer. Every manufacturer makes some turds, some average and some great saws. Buy the great ones that fit your needs. Heavy, underpowered, and over priced (most homeowner grades) aren't great saws. You might do some reading here:
    ArboristSite.com Chainsaw thread (free to join)
    http://www.arboristsite.com/forumdisplay...
    Read the rabid brand backers inputs critically. I considered a Stihl 361... I just couldn't scrape up $700.00. Lou
    Scholar:
  • 58 Answers
I have a Jonsered with the same problem, I think it's the ethanol. A friend says his Stihl cap swelled tight too, I also have 2 Husqvarna saws ]one is 25 years old] ,but no problem with them. I removed the rubber seal from the Jonserred cap
and lightly brushed the threads with a Nyalox wheel [abrasive inpregnated nylon].
It worked fine for a while, but has swelled up again. I noticed the interior of the fuel tank is developing cracks also. I think I'll brush it again, remove the fuel filter and line, degrease everything and try to seal the tank and the cap with something that isn't affected by gasoline or alcohol.
They have been putting ethanol in gasoline long enough that the chainsaw manufacturers should have corrected the problems, and offering new caps for their saws.
I suspect we will find out that they are putting profit before doing what is right for the people who purchase their products.
To cut down on the other problems ethanol causes, I started using StarTron Enzyme Fuel treatment. The manufacturer Starbright, says if the carb is gummed -up their product will even clean that out. If anyone is interested in more information their web address is www.starbright.com.
Posted on Nov 14, 2011
How to replace gas cap
Step 1 - Determine Your Type of Gas Cap Before acquiring a new one, think about whether you need a gas cap that locks to prevent a gas thief from stealing your gas. But keep in mind, if you put one of these caps on your car, your spouse or children who put gas in your car will need the gas cap key.
Step 2 - Remove the Cap Retention Ring When you actually replace your gas cap, you may need to remove a retention ring that keeps the cap attached to your car. If you do, you can remove it simply by using a pair of needle-nose pliers. Just slip one tip of those pliers under the ring edge; then close the pliers and pull the ring off the old cap and slip it over the new cap.
Step 3 - Check the Warning Sensor Light Your car may have a sensor light that will illuminate when you change your cap. If so, drive your car a few miles to see if the light goes off. If it doesn't, see your repair mechanic to fix the problem
Aug 17, 2015 | 2002 GMC Envoy
Removal of locking gas cap on 2005 cts cadillac
OK keep in mind child proof caps. Push down on gas cap and turn. If this doesn't work grab the outer rim of the cap tightly squeezing hard and turning. Now if this fails, you would have to pry off the top of the cap and then you will be able to remove the lower end of the cap with a pair of pliers or similar tool. GOOD LUCK FRIEND.
Sep 16, 2014 | 2005 Cadillac CTS 2.8
Gas cap
Carolyn
You may need to press down and twist the gas cap at the same time..similar to a "child safe" bottle of asprin or medicine. Usually you remove it counterclockwise
Then when you put gas cap back on press down and turn it clockwise to seall the vacuum in the gas tank.
Many newer cars have this gas cap feature
Mar 31, 2014 | 2004 Pontiac Grand Prix
How do I know if my distributer cap is bad or fuel pump
If it a cracked cap it's always going to run badly. First put some gas treatment to remove water from gas. if it still runs bad inspect the cap for cracks. even I small crack will be hard to see. Mark the wire location B4 pulling off the cap. in a dark place put a light in cap and block around the bottom to inspect sides for crack. I would try gas/water separator first.
Sep 11, 2013 | 2003 Chevrolet Silverado 3500
Hard to start after putting gas in tank
Gas cap bad they should help equalize the pressure in the tank
Mar 19, 2013 | Emission System for Chevrolet Cruze
I can't get gas to go in my bmw 323i convertible, help? The gas cap is very hard to get off now and the pump won't suction on when I try to put gas in.
1. Unlock the gas cap. Slip the key into the slot on the center of the cap with the teeth toward the outer circle. 2. Turn the key clockwise. The lock cylinder gives and allows the key to move. 3. Turn the gas cap counterclockwise. Unscrew the cap...------------------------------------------------------------------------------
Best R270 BMW CAS4 BDM Programmer
Feb 26, 2013 | 1998 BMW 3 Series
Light on my dashboard
ford taurus's are well known for this. the seal on the gas cap goes bad. before you replace the gas cap make sure when you close the gas cap you are turning it at least 5 clicks. if light stays on get a new gas cap. they are easy to install all you need to do is remove the gas cap.remove the gas cap strap. put ******** the new cap, close cap and turn 5 clicks. not clicking 5 time can set a p400 or p401 evap code causing the check enging /ses light to come on.
Apr 19, 2009 | Ford Taurus Cars & Trucks
Garden Logo
1,027 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
