Question about Vizio VX37L Television
I HAVE A VX37L HDTV 10A WHEN YOU TURN THE POWER ON,THE SCREEN GETS LIGHTER BUT NOTHING ELSE WORKS. NOT EVEN THE ON OFF FUNCTION. I REPLACED THE POWER SUPPLY, (PART #0500-0507-0250) BUT STILL HAVE THE SAME PROBLEM. DO YOU HAVE ANY OTHER SUGGESTIONS? IS THERE A WAY TO TEST THE POWER SUPPLY TO MAKE SURE THE ONE I GOT IS GOOD?
  • bigdaddypj69 Nov 22, 2009
    I HAVE TESTED THE COMPONENTS ON THE POWER SUPPLY BOARD AND EVERYTHING SEEMS TO CHECK OUT OK. IS THER SOMTHINGELSE I CAN LOOK FOR?
    President:
  • 1,515 Answers
Hi, I would take the power supply back and exchange it for another one. That's if it hasn't been that long. Even though it is new from the factory, doesn't mean it is good.I see this in the field daily, and have to take the part back for a new one or get credit for it. Try this, could solve you're problem. Best of Luck,
Shastalaker7
PS This is the way to test it.
Posted on Nov 23, 2009
  • Robert Horton
    Robert Horton Nov 23, 2009
    Hi, On the Vizio Model# VX37L -10A, there are so many component's that could cause the problem you are having, it would be very hard to trouble shoot this on-line.With the TFT active matrix LCD panel, could be problematic also.If you haven't repaired it by now, let me no where you stand with this unit.Sincerely,
    Shastalaker7
  • 3,741 Answers
There is a inbuit fuse on power supply check out if its blown or not.many times fuse blows out and this stops power supply to work.on power supply board there are many electrical components called capacitors and ic .you will have to check out those with multyimeter to locate the faulty.also you can get the required parts from www.partstore.com also you can get new replaCEment power supply board.this clears the problem completely.
you can get the required board and components at ----- www.partstore.com -------- or from ------ www.radioshack.com ----
if you are not familiar with doing this you can get it done by local tv repair technician familiar with this model tv.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 19, 2009
  • charlymonty Nov 23, 2009
    it can be the problem in the digital board of the tv only if the power supply board is working.
    you can directly cal vizio service center for more help.(888) 849-4623 www.VIZIO.com
    thanks for keeping updated. please do rate the solution positively .thank you for using fixya.
Vizio base stand model vx37l
You can get replacement Vizio remotes from Walmart, $10. As far as the pedestal, I can't locate one either. I would suggest checking Ebay frequently. I recycle LCD sets and come across rare pedestals. If you would like, visit our website, click on Contact US and leave your contact info. I will put you down on our Wish List and contact you if we get the pedestal in stock.
www.back2lifeelectronics.com
Jan 10, 2013 | Vizio VX37L Television
I have a Vizio VX37L HDTV........just yesterday....the tv started showing "no signal" when turned on....and powered off within 5 to 10 seconds. Any ideas?
POWER BOARD MALFUCTION.
POSSIBLITY, A $300-$400 REPAIR.
OR, YOU MAY BE LUCKY AND IT IS FAULTY CAPACITORS.
PLEASE LET ME KNOW WHAT THE PROBLEM WAS.
Jun 06, 2011 | Vizio VX37L Television
Tv Vizio VX37L HDTV 10A
Normally new screens run about 100.00 less than a new tv costs and then you have to get it installed! There is now easy way around it. You would be better off just to get a new one>
Jul 19, 2010 | Vizio VX37L Television
Have a Vizio VX37L that when it is turned the
HERE'S THE FIX: I just went through this with my Vizio VX37L. TV is stuck in RGB input. This is the fix.... TV is stuck in RGB input.
(option 1) Power on TV, and press the INPUT button repeatedly and rapidly until you can change to a different input, such as AV.
If that doesn't work, try:
(option 2) With the TV off, press and hold the INPUT button on the side of the TV for about 5 seconds. The TV should power on and the input list will appear. The TV will no longer be locked, and the INPUT button should function properly after that.
Option 2 worked for me!
Jan 24, 2010 | Vizio VX37L Television
Vizio VX37L HDTV black rectangle in lower right corner
Turn off or modify CLOSED CAPTIONING settings
When you turn on unit screen gets lighter, but ther is no picture the menu will not show, and will not turn off with remote or power button
You need to replace the power supply part # 0500-0507-0250. Mine did the same thing, its about 100 bucks after shipping
Oct 16, 2009 | Vizio VX37L Television
Cigarette lighter fuse
Here is the fuse relay diagram:
MKIV FUSE LIST
1. Washer nozzle heaters, glove compartment light, memory seat control module (10A).
2. Turn signal lights (10A).
3. Fog light relay, instrument panel light dimmer switch (5A).
4. License plate light (5A).
5. Comfort system, cruise control, Climatronic, A/C, heated seat control modules, automatic day/night interior mirror, control module for multi-function steering wheel, control unit in steering wheel (7.5A).
6. Central locking system (5A).
7. Back-up lights, speedometer vehicle speed sensor (VSS) (10A).
8. Open
9. Anti-lock brake system (ABS) (5A).
10. Engine control module (ECM): gasoline engine (10A); diesel engine, Model Year 2000 > (5A).
11. Instrument cluster, shift lock solenoid (5A).
12. Data Link Connector (DLC) power supply (7.5A).
13. Brake tail lights (10A).
14. Interior lights, central locking system (10A).
15. Instrument cluster, transmission control module (TCM) (5A).
16. A/C clutch, after-run coolant pump (10A).
17. Open.
18. Headlight high beam, right (10A).
19. Headlight high beam, left (10A).
20. Headlight low beam, right (15A).
21. Headlight low beam, left (15A).
22. Parking lights right, side marker right (5A).
23. Parking lights left, side marker left (5A).
24. Windshield and rear window washer pump, windshield wiper motor (20A).
25. Fresh air blower, Climatronic, A/C (25A).
26. Rear window defogger (25A).
27. Motor for rear windshield wiper (15A).
28. Fuel pump (FP) (15A).
29. Engine control module (ECM) gasoline engine (15A); diesel engine (10A).
30. Power sunroof control module (20A).
31. Transmission control module (TCM) (20A).
32. Injectors: gasoline engine (10A); diesel engine (15A).
33. Headlight washer system (20A).
34. Engine control elements (10A).
35. 12 V power outlet (in luggage compartment) (30A).
36. Fog lights (15A).
37. Terminal (86S) on radio, Instrument cluster (10A).
38. Central locking system (with power windows), luggage compartment light, remote/fuel tank door, motor to unlock rear lid (15A).
39. Emergency flashers (15A).
40. Dual tone horn (20A).
41. Cigarette lighter (15A).
42. Radio (25A).
43. Engine control elements (10A).
44. Heated seats (15A).
Fuse arangements in fuse bracket/battery:
S162. Glow plugs (coolant) (50A).
S163. Fuel pump (FP) relay/glow plug relay (50A).
S164. Coolant fan control (FC) control module/coolant fan (40A).
S176. Relays panel interior (110A).
S177. Generator (GEN) (90 Amp.) (110A).
Generator (GEN) (120 Amp.) (150A).
S178. ABS (hydraulic pump) (30A).
S179. ABS (30A).
S180. Coolant fan (30A). Source(s): http://forums.tdiclub.com/showthread.php?t=122606 fame !
Jul 07, 2009 | 1999 Volkswagen GTI
Lincoln LS 2001 3.0
Fuse/Relay
Location
Fuse Amp
Rating
Passenger Compartment
Fuse Panel Description
9 10A Right Front Low Beam
10 5A Left Front Turn, Left Front Repeater, Left
Front Sidemarker, Left Front Park Lamps
11 10A Left Front High Beam
12 — Not Used
13 5A Cluster
14 10A RCM, DATC
15 5A Not Used (Spare)
16 5A E/C Mirror, Heated Seat Controls, RSM
(Rain Sensor Module)
17 5A RCM, Alternator Warning Lamp
18 20A Radio, CIA
19 15A Tilt/Tele Motors
20 10A FEM, DATC, Cluster, Brake Shift Interlock,
REM
21 10A Power Folding Mirrors
22 10A DDM
23 10A Right Front High Beam
24 5A PATS
25 10A Left Front Low Beam
26 10A Wiper Relay, Windshield Washer
27 10A Radio, Cellphone
28 5A Security Horn
29 5A Trailer Tow Ignition Sense, VEMS, FEM
30 5A FEM
31 — Not Used
32 20A Cigar Lighter
33 10A Switch Backlighting
34 10A Not Used (Spare)
35 5A Stop Lamp Signal
Oct 23, 2008 | 2001 Lincoln LS
Vizio VX37L Television Logo
65 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
