Question about Whirlpool Dryers
DRYER RUNS, THERMOSTATS ARE OKAY, JUST WILL NOT HEAT---HOW DO YOU TAKE THE BACK OFF OF MODEL #LE5790XS/
  • Whirlpool Master
  • 2,180 Answers
Take the screws out of the back panel and remove vent line
Posted on Nov 19, 2009
  • Sal DeAngelo Nov 22, 2009
    you need to go from the back if filter is on top of dryer,
GE profile dryer,Runs fine but no heat
need to have the heat element checked with a multimeter and visually if u can and look for burns and corrosion and breaking of the wire connections. Also have the thermostats checked, Im assuming its electric and not gas? the thermal cut off may be bad and the hi-lo thermostat, these can shut heat off from the dryer. Ive replaced the element on my G.E profile and it wasn't all that hard rather simple.
Sep 13, 2014 | GE Profile Gas Dryer Model Dpsb513gb0ww
Dryer will not produce heat. Dryer turns on and drum turns. Runs quiet but no heat. Clothes do not dry.
It is possible you need to replace your heater element or your thermostats .. depending on your model which you did not list. Your element and thermostats will cause it not to heat ... when you get your model go to www.sears.com/parts and you can possibly view your schematic if sears had ever sold it... get an ohm meter there cheap Lowe's home depot sears test for power on each of the three. clean the venting also..
May 25, 2010 | GE Dryers
Dryer ran for hours and did not stop automatically, now runs but wont heat?
Good day,
If set to automatic and there is no heat it will run continually run without shutting off. You'll need to trouble shoot the heating problem.
A lot of the problems are due to limit fuses and limit thermostats located in the back. Beyond that you'll need to supply the model and whether its gas or electric.
May 14, 2010 | Kenmore 500 6952 Dryer
Dryer will not get hot. All the vents are clean.
Check for burnt out heating element and electrical connections to element and thermostats. If okay check all thermostats, operating and high limit, with an ohm meter. All must be in closed position. If element,thermostats,and electrical connections good then check timer.
Mar 21, 2010 | Whirlpool LER4634J Electric Dryer
The dryer runs but does not heat
Sounds like you have a problem with the heating coil or thermostats.
Remove the back of the dryer and look for the air tube from the blower to the drum. The heating coil and thermostats are normally located inside of the tube.
I hope this helps
Oct 03, 2009 | LG Dryers
NO HEAT
Sounds like your no heat problem is a faulty heating coil or thermostats.
Remove the back of the dryer and locate the air tube that runs from the blower to the drum.
The heating coil and thermostats are normally located inside of it.
I hope this helps
Oct 03, 2009 | Kenmore Dryers
Kenmore electric dryer, 600 series, runs but does not heat.
check you're thermostats for continuity, they are normally 3 thermostats, reset stats have a button on them please press, if not thermostat its your heating element
Jun 20, 2009 | Dryers
Whrirlpool dryer not heating
Normal 0 Hi, Not sure this is the right model but, try this. UNPLUG the dryer! Remove the rear panel of the dryer and locate the element on the right hand side. Plug the dryer back in and test to see if there is 240V going to the element posts. If there is voltage, but no heat, change the element. If it does not, you need to test the thermostats for continuity. If any of the thermostats are open, replace it. If this is not the right model, please give me the model# and I can help. I hope this helps you.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Jun 13, 2009 | Dryers
Whirlpool duet dryer runs but will not heat.
do you have 240 at the terminal block on the back of the dryer if so check for continuity on the thermostats , thermal fuse and heating element
Dec 29, 2008 | Whirlpool GEW9250 Electric Dryer
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
