Question about HP LaserJet 2550L Printer
Imaging drum light is on, did open the front door and did press the delite butten and then the warnig light is on...i can not print
  • 58 Answers
Yea, these printers will not print if it detects the imaging drum needs replacing. I had the same problem on my printer and it wouldn't work until I actually replaced the drum.
Posted on Nov 19, 2009
Testimonial: "ok"
I have a brother HL_2140 laser printer I just changed the ink cartage and now the Drum light is flashing on and off and it wont print?
That means you drum will finish soon, once the drum light become on you can not print, start looking for the new drum price and get it, once the drum light become on open the front door, take out the toner and drum, with the front door open press go button and keep it down until the 4 lights of the printer become on, release the button and install the new drum with the cartridge.
Aug 06, 2013 | Brother HL 2140 Laser Printer
Will not print the error light and the drum light flash. Replaced drum but still will not print and error light and the drum lights still flash.
The drum counter will have to be reset, Use the following steps.
1. Open the front door.
2. Press and hold the cancel button (x button) until all the lights flash in in order.
3. Then close the front cover.
This will reset the drum counter so that you can continue to print.
Jun 23, 2010 | Dell 1720dn Laser Printer
Black text only printing dark on right side of page. I jsut put in a new black toner cartridge
My solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
Feb 04, 2010 | Samsung CLP 300 Laser Printer
I've recently installed a new Brother toner, but the drum light is flashing and the Brother hl 5140 printer won't print
DRUM UNIT "spent"
It can be reset if the printing quality is good
To reset the drum follow the instructions below:
Press the cover release button and then open the front cover of the printer.
Press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the Go button.
Close the front cover.
Make sure that the Drum LED is now off.
Caution: Reset the drum counter only when you replaced the drum unit with a new one.
Oct 09, 2009 | Brother HL 5140 Laser Printer
I have a Brother HL-5250, drum light on, not printing
When the drum light is on solid, it's time for a new drum, if you have a new drum, just open the front door and hold the go button til all lights flash and the drum is reset. Press the go button 3 times and it will print a sheet showing the drum status.
Sep 15, 2009 | Brother HL 5250DN Laser Printer
Resetting the Drum counter on a Brother HL-2040
Hi.
Have you recently replaced the drum?
  • The Drum LED blinks if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
  • The Drum LED continues to blink if the drum counter was not reset when you replaced the drum. To reset the drum follow the instructions below:
  1. Open the front cover of the printer.
  2. Press and hold down Go button for about 4 seconds until al the LEDs light up. Once all 4 LEDs are lit, release the Go button.
  3. Close the front cover.
Aug 03, 2009 | Brother HL-2040 Laser Printer
How do I get our Imaging Drum light to go off?
Follow the four simple steps below to reset the internal drum counter.
1.)    Open the front door.
2.)    Press and hold the “Cancel” button; until all of the lights flash.
3.)    Release the “cancel” button.
4.)    Shut the front door.
P.S.
Here is a Link to the Dell 1720/1720DN online users guide.
http://support.dell.com/support/edocs/systems/prn1720/en/index.htm
And here is a direct link to Replacing the photoconductor.
http://support.dell.com/support/edocs/systems/prn1720/en/1720_en/en/d0e4183.html#replacing-the-imaging-drum
-Hope this helps
Apr 07, 2009 | Dell 1700 Laser Printer
Drum light on after installing new drum
As posted by Songdancer - this solution worked for my HL-1440 to reset the drum light
"Brother's webpage says to reset the drum counter. On some models this is done by opening up the front door, pressing the GO button until all 4 lights are lit, then releasing the GO button"
Apr 30, 2008 | Brother HL 1440 Laser Printer
Toner lite will not go out or print
A couple of suggestions
1) Open door and remove drum and toner. Hold Go button down until all lights are on. Put drum and toner back in and shut door.
Another is.
1. Switch off printer
2. Switch on printer
3. Open front door
4. Remove toner/drum unit
5. With the door still open hold down the go button for 1 second
6. Put the toner/drum unit back in
7. With the door still open hold down the go button for 1 second
8. Close the door and press go to test
Apr 25, 2008 | Brother HL-5240 Laser Printer
Change Image Drum light blinking
You have to reset the drum counter. Leave the front cover open Press and hold the "cancel" button until all the lights flash in sequence Close the front cover You should be good fro another 30 - 40 thousand copies. Hope it helps Ed
May 22, 2007 | Dell 1710n Laser Printer
HP LaserJet 2550L Printer Logo
222 people viewed this question
Seeker5211
Seeker5211
