Question about Samsung Jet S8000 Cell Phone
I can't ring out sometimes , help? - Samsung Jet S8000 Cell Phone
2002 grand am leaking transmission fluid from transmission sensor
I think its a rubber o ring on the end of the sensor.
Feb 15, 2015 | 2002 Pontiac Grand Am
When somebody rings sometimes it only rings once then goes silent
Go to Settings > Sounds > Change the settings to Ring+Vibrate or Ring Only or Vibrate Only
I guess you have by mistake changed the settings right now to Ring Only Once and hence it rings just once and then vibrates. If there is not settings icon and no sounds option you can check if you have Profile as option as you can change it accordingly in the profile you are using. Hope this helps. Good Luck
Mar 08, 2013 | Motorola Mobility Defy Cell Phone
When callers ring our number they are unable to make a connection. Sometimes the phone will ring once and then disconnect
On our side of the pond, this often means there is water in the line somewhere. High dampness coupled with insulation that has degraded can cause low resistance paths. This usually doesn't cause any problem when you place a call, although it can sometimes cause crackling or other noise. But when someone rings your line, a high voltage is sent to operate the ringer. The low resistance then makes the telephone equipment think you've answered, but since your phone is still hung up it then disconnects the call. Sometimes the phone may not even ring, sometimes it gives a little peep or even a whole ring.
This problem may be due to damage to a telephone jack in your home. I've seen it caused by water when someone was cleaning the floor, and also when a jack near a window was soaked during a storm. The trouble may also be in the outside wiring, which should make it the responsibility of BT to repair. It's also possible, although rare, for a dodgy phone to cause this if there's a problem in its ringer circuit.
Hope this gives you some help in locating the cause and fixing it. Thanks for using Fixya!
Nov 21, 2010 | British Telecom Lands Phones
I'm preparing to remove front right axle shaft (Cv half shaft) in a 1998 ford Escort zx2 with ABS and Auto trans. Is it held in the transmission by a spring ring or a snap ring?
It is held in by a spring ring. You need a good strong pry bar and you position it between the hub of the axel and the case of the trans and **** hard pulling it out. It sometimes is seated well, but keep trying. It will fight you sometimes.
Hope this helps.
Sep 15, 2009 | 1998 Ford Escort
Would like more than 4 rings until machine answers
TS is the Toll Saver Option.Sometimes this will let it ring many times, before answering.
4 rings is the maximum setting. You might try the TS, then try calling to see if that helps.
Apr 28, 2009 | Lands Phones
Our fax will not pickup incoming faxes
The mode is correct. You can check the rings to answer setting. Default is 4 rings. If your phone line is just for the fax try setting rings to 1. Sometimes sending fax machines go into redial before the 4th ring.
Also, sometimes unplugging the power for 10 seconds will clear any memory that may have locked up the machine.
Hope this helps.
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Shared telephone ling malfunctions sometimes
It looks like you have a distinctive ring service from your phone company. Change the ring pattern of your fax to its assigned ring pattern (double or triple ring). It could be assigned to 'all rings' right now, that's why your fax is picking up your landline calls as well.
Mar 06, 2009 | Office Equipment & Supplies
Model # TGA931T
Try to unplug all power cords, this will reset the phones.
Try to swap the two phones.
If you still cannot fix it , then one of the phones is faulty.
Sep 07, 2008 | Lands Phones
Message alerts v3
I have this problem I can't access the loud setting but I can the soft I'm not yet sure why but you may need to update the software on your phone to fix this bug. Sometimes I take off the back and take out my battery and put it back in and then sometimes i can access also when you select your ring tone to change just push left or right instead of using the menu that drops down that also sometimes works for me hope one of the helps.
Feb 24, 2007 | Motorola Mobility RAZR V3
Samsung Jet S8000  Cell Phone Logo
29 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
