Question about Lexmark All-in-One Printer with PictBridge
I change the color ink an now it keep saying i have a aligment problems an its not the paper an when i aligment it the black ink dont show up on the paper
    Genius:
  • 1,018 Answers
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Nov 19, 2009
Installed new black ink cartridge in HP PSC 2110 color printer, scanner, copier. Followed instructions to align cartridges. Printer printed paper that had additional instructions. Placed second printed...
hello, machine will need to finish calibration so it will not come back, so if machine failes it could be that the color cartridge is not printing, because this machine uses yellow to calibrate with.
Oct 06, 2010 | HP PSC 2110 Color Printer
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
Changed out black ink screen says insert
It will be a hardware printing problem mostly. Try cleaning the parts with alcogol or/and elastic rubber. Also try to increase the force of contact with a sticky tape or like that.
Aug 09, 2009 | Lexmark P6250 All-In-One InkJet Photo...
Wont print black because it doesnt have color ink
So for now, you can change the print settings to only print in black.
Change the print properties/ colour to grayscale.
May 11, 2009 | HP PSC 1610 All-In-One InkJet Printer
Alram light
Did you replace the Black ink cartridge or the Color cartridge, or did you replace both?
Facing the front of the Canon Pixma MX310, did you install the Black ink cartridge to the left side, and the Color cartridge to the right side?
Do Not reverse how the ink cartridges go. Do Not install a Black ink cartridge, in the Color cartridge holder.
If the Alarm light came on, check to see if you have an error message in the LCD. (Not trying to insult your intelligence. The LCD is the little rectangular Liquid Crystal Display on your Pixma MX310 Operation Panel, to the left of the numeric buttons)
Do you have the Pixma MX310 On-screen manual?
Start>Hover on All Programs>Canon>Pixma MX310>On-screen manual
Click on the Troubleshooting heading.
If you have an error message code, click on the heading ->
An Error Message is Displayed on the LCD.
Also suggest you click on the heading -> Problems Sending Faxes.
See if the information provided has a solution to your problem.
Apr 22, 2009 | Canon PIXMA MX310 All-In-One Printer
HP C6280 says out of black ink
Something is wrong with your Blach carrier or connections. Use a bit of alcohol and clean the array of gold contacts where the Ink cartridge plugs in. Most of the pins are shutter and piezo control (get the ink on paper) but a few do other stuff like check ink level, # of hours runtime, etc. This is very common problem with inkjet printers. Hope this helps.
Also... rub the contacts on the printhead with a pencil eraser to make them shiny and bright.
Cheers!
Mar 26, 2009 | HP Photosmart C7280 Printer
PAPER JAM
I have 4 hp printers. And usually a paper jam tell me I need to open the back of the printer to check is something is there. What is the substance of the paper you are using?
Oct 25, 2008 | HP Officejet 6310 All-In-One InkJet...
Print Cartridge Problems
i have an mp170 all in one and when you fill the cartriges they dont show up as full cannon put a chip in the cartridge to con people into buying new ones try siting the cartridges in warm water for a few hours then blot the cartridge with tisue paper if it dont blot out the ink the cartride is finnished and you need a new one .To align the cartridge you flick through the menu on the printer not pc screen look for alignment page print this off then you have to pick the dark boxes on the sheet shade the bit next to it and put on your scan bed and click ok it should scan the sheet and reset the alignment
Jul 19, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Cartridge problems
Ref: our live chat - Definitely worth replacing the colour one with a new one - some other people had identical problem and that cured it - they really don't survive not being used very well. :)
Apr 21, 2007 | HP OfficeJet k60 All-In-One InkJet Printer
Lexmark All-in-One Printer with PictBridge Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
