Question about HP DeskJet F380 All-In-One Printer
INK LIGHT ON, PAPER JAM LIGHT ON, AND THE NUMBER OF PAGES HAS BACKWARD 3
WHAT DO I DO TO TROUBLE SHOOT THIS PROBLEM?
  • meererimage Mar 06, 2008
    I got the same warning after i replaced the ink cartridges. Exchanged the cartridges tried to reset, uninstalled and re-installed software.
    Master:
  • 619 Answers
Hi , the printer need to reset . visit the web site for download of reseter .
Posted on Jan 19, 2008
6ya staff
SOURCE:
HP 5610 printer won't print
Unplug this beast. Take the old ink cartridge out and re-insert. Also, check for any other jammed papers that need to be removed. Then turn this beast back on. See if that does anything old chap.
Feb 04, 2010 | HP Officejet 5610 All-In-One InkJet...
Amber light is blinking, error message when printing
Generally means that you're out of ink in your ink cartridge. Note that the NUMBER of times it flashes is significant: if it's 2 or 3 flashes at a time, then it's a paper problem (jam, out of paper, etc.), otherwise it's an ink problem (replace the cartridge).
Oct 14, 2009 | Canon PIXMA iP1600 Printer
EPSON tx100 refuses to print - ink light on
ink light on? Check status monitor. Usually after jammed paper, printer trouble to recognized ink. Do change ink tank procedure, unplug and plug again ink tank.
Jun 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
HP Photosmart C6280 paper jam--won't print (of course), message reads 'add paper to main tray'
Please try this to clear the paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | HP Photosmart C6280 Printer
Paper jam ,no paper jam found Dell 1815dn
give this a try
alternative :
Jun 01, 2009 | Dell 1815dn All-In-One Laser Printer
I am getting an error on my cannon mp160 all in one of a backward
MP150/160 resetting errors
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5 times Orange Destination setting
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD over current error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Apr 08, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Paper Jam error message
try this
alternative :
Apr 02, 2008 | Dell 942 All-In-One InkJet Printer
HP DeskJet F380 All-In-One Printer Logo
394 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
