Question about HP Pavilion dv6000z Notebook
When I go to burn a CD the drive doesn't work. The drive works with playing CD/DVDs etc.. but when I go to burn a disc it tries to work, but it doesn't quite get there, What do I do? Frustrated!
  • John Sparozich May 11, 2010
    Hi, First you need to make sure that the drive is cable of burning CD's. Look for the letters RW, if it is a writer, you will need software like Nero or Roxio. Hope this helps. Have a good day.
    Problem Solver:
  • 15 Answers
Try to see if there is any updated drivers you can install for your cd/dvd burner. and make sure it is a cd/dvd burner. To find drivers for your laptop you can usually go to hp.com and download them there.
Posted on Nov 20, 2009
LG HL-DT-ST DVD RAM GSA -H55N ATA dvd drive not detecting any dvds, while the cds are detected very well ????
built in 06 or 07 , it has reached the end of it's life expectancy , and need replaced
Oct 23, 2015 | LG Computers & Internet
Dvd driver does not play or burn blank dvds compaq r4000 but it will play dvds & cd its got dvdrw/r rw dvd+r dl n the driver
Try another DVD-RW drive because it sounds like the laser is going bad. Burning requires alot of power from the laser. Playing DVD or playing cd's doesn't require much so thats why it would play those.
Feb 06, 2012 | HP Compaq Presario R4000 Notebook
Does it play cd and dvds
You can only play CDs of all kinds (CD +/- R, cdrw, etc.) but you will not be able to play any DVDs. It will not detect any DVD disc.
Jun 23, 2010 | LG CRD 8400B (CRD-8400) Internal 40x...
The drive plays DVDs and can read doc files, but
This problem is normal and exists with many CD/DVD drives.
On some of the drives, if you put in blank discs and try to open the disc in My Computer or Windows Explorer, Windows displays no contents or a blank disc. Whereas on other drives, you get the error message that you mentioned about incorrect function.
What software are you using to burn CDs or DVDs? Are you able to burn CDs but not DVDs or you can't burn both the discs? Did you try a CDs with a different make/manufacturer? Some drives refuse on some disc makes. Try another disc and another writing speed, or try the lowest writing speed available with your software.
Hope that helps,
Regards,
Raspal
Mar 22, 2010 | ASUS SDRW-08D1S-U USB 2.0 Slim External...
MY BOSS BV7970 DO NOT PLAY ANY BURN CDRW OR DVDS
Some players are picky with certain cdrw/dvdrw discs. You might have to experiment with different brands/types for your discs. I used to have a cd player (teac) which would just refuse certain brands cd-r discs but play others just fine. I know it sounds odd, but once I noticed which ones work and which ones don't I never looked back.
Also, have the "problematic" discs been recorded on just one recorder? Have you tried playing discs recorded on a different recorder?
Also - I'm sure you've already tried it-it's always a good idea to clean the laser just in case.
Hope this helps+
Good luck,
Raf
Nov 13, 2009 | Boss BV7970 CD Player
My dvd drive in my computer won't play dvds
1. Completely remove any dvd/cd player/burner softwares (i.e. Nero, Power DVD, etc.).
2. Go to device manager and remove your DVD/CD device from the device list
3. Restart you laptop
4. Windows will then try to reinstall the device drivers again for the DVD drive.
5. After another restart, then reinstall your dvd softwares again.
Nov 15, 2008 | Toshiba Satellite A135-S4527 Notebook
Burning problem
Try different brand. Your Drive is a sensitive type and it only accepts some DVD-R brands. Also try DVD-RW disc. I had the same problem but not specifically the exact problem. My drive is cd writer only. Same problem, I just used diff CD-R brand like Imation and Philips and the burning works like a charm.
Jul 26, 2008 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
LG HL-DT-ST DVDRAM T10N ATA DRIVE
Various issues can cause drives to occasionally balk at writing optical discs. These run the gamut of physical, hardware, and software troubles.
Inappropriate or dirty media may be to blame. Make sure to match the type of recordable disc to the drive, and check each disc for fingerprints or other contaminants. If a disc is dirty, wipe it with a clean, soft cloth in a straight line from the center hole outward. Try a quality optical drive cleaning disc if you suspect dust contamination on the drive’s laser lens.
Some discs don’t perform well with certain drives, even within their rated speeds. Try recording at a slower speed and then with a different brand of disc. Also, on PCs, verify that the temporary file storage area on the hard drive used by the burning software has enough free, defragmented space. Allocate at least 5GB for a DVD (9GB for a double-layer [DL] disc) and about 1GB for CD burning.
Feb 28, 2008 | HP Pavilion dv6000z Notebook
Playing PC DVD roms problem
Dvd drives can read from both DVD and CD however due to technological limitations most DVD-ROM or RAM read up to slightly higher speeds for CDs than DVDs.
When burning DVDs professional companies that make prerecorded disks burn their disk at low speeds in an effort to achieve both compatibility and low errors, that is the reason their DVDs play on most DVD-ROMs. However DVDs me and you burn at home and work at high speeds are prone to errors and incompatibility with low reading speed drives.
As a result if your DVD-ROM has a low maximum reading speed then it can only read those prerecorded DVDs and only DVDs recorded at low speeds provided thre are not scratched.
I believe you managed to read those DVD movies if they were pre recorded.
Nov 29, 2007 | LG (GCC-4522BI) CD-RW/DVD-ROM (Combo)...
Wont burn cds , files , etc
well it could be many reasons why it wont write your burner but first what software you are using for burning. it happens to me before using media player when i try to burn music. the reason was i haven't configure my media player to use my dvd burner for burning because i have dvd burner and a cd burner installed. Now maybe you try to reinstall it using your dvd driver the one which with your dvd burner when you first bought it.
Nov 20, 2007 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
52 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
