Question about Sony Playstation 3 (PS3) Console
I just replaced my HD because of the failure fault
I just replaced my PS 3 HD because of the failure fault to recognize the dics and it will still not work any suggestions?
    President:
  • 2,653 Answers
Blu-ray is dead.
replace the laser
local 100-120
through Sony 150
Yourself -70+ depending if you've got tools and patience ;)
Let me know if you have any specific questions and I'll provide details.
Posted on Nov 20, 2009
Engine hunting under accelaration
It sounds like your 9-3 is in Limp-Home mode. In which case, you are right - it is hitting a temporary limiter. The most typical of the causes I see are from an aging Direct Ignition Cassette (DIC). When there is a fault detected in the DIC module, the throttle body lets the throttle spring kick down to what is known as Limp-Home mode. Although it can be ratcheted back to the normal position, if the DIC misfire is detected again, the same will happen. I'd have a shop take an OBD-II reare to it and confirm. If it is the DIC, replace it, and have them reset the error code and the throttle body.
I hope this get you back on the road quickly with your Saab! (I drive one, too)
Jan 04, 2014 | 2000 Saab 9-3
Problem with Samsung G2 HM641JX 640Gb
You want to check if a the drive is recognized by windows, initialized and has a partition. Watch the video.
Dec 24, 2012 | Samsung S2 Portable HX MU010EA 1 TB...
After a power supply failure I installed a new PS. The system (a windows 98 machine) failed to recognize the existance of the DVD. I installed a new Samsung DVD drive. Now the system recognizes the DVB but...
Page fault is a core level issue, Really it is time to consider hardware and OS upgrades. Windows 98 support in 2006, because the issues were redsigned in newer OS. and now you are about 4 upgrades behind.
Look at the error logs in Windows and I presume that you will see tons of issues. UPGRADE.
Feb 19, 2011 | Samsung Televison & Video
Keyless entry remote programming
Hello here is the instructions for programming the key fobs
This procedure will add, replace, or invalidate all key fobs. This procedure requires that you have a known good key fob available, a new/replacement key fob, the vehicles mechanical key, and a scan tool.
Method 1 is also used for the initial programming of fobs to a new replacement RCDLR. In this instance, the new RCDLR comes ready to learn the first key fobs introduced. Perform the learn procedure as outlined, with the exception that the new RCDLR does not require a known good key fob be placed within the interior of the vehicle.
Note: This procedure is not available when the maximum number of fobs (4) have been programmed. If 4 key fobs are programmed to this RCDLR and this method is attempted, the driver information center (DIC) will display MAX FOBS LEARNED and the programming procedure will exit. Methods 2 or 3 must be used in this instance.
  1. The vehicle must be OFF.
  2. Place a known key fob and any new/replacement key fob(s) to be programmed in the cupholder inside the vehicle. DO NOT place any fobs in the console fob pocket at this time.
  3. Insert the vehicle key in the driver door lock cylinder located in the driver door handle and cycle the key 5 times within 5 seconds.
  4. The DIC will display a message: READY FOR FOB X (X = fob 2, 3, or 4). → If the DIC displays: OFF/ACC TO LEARN, the known fob has not been recognized. At this time, programming will revert to Method 2.
  5. If the DIC is displaying the correct fob number that needs to be programmed, skip ahead to step 9.
  6. If the DIC is not displaying the correct fob number that needs to be changed (i.e., the DIC is displaying: READY FOR FOB 3, and you wish to program FOB 1), use the scan tool to access the following: • Vehicle Control Systems • Computer/Integrating Systems • Module Setup • Remote Control Door Lock Receiver • Program Key Fobs
  7. Select the fob position you wish to program: Note: Selecting Invalidate All Fobs will erase any known fobs and will cause the DIC to prompt READY FOR FOB 1, requiring all fobs to be relearned to the vehicle.
    • Invalidate All Fobs • Program Fob 1 • Program Fob 2 • Program Fob 3 • Program Fob 4
  8. With the fob position selected, press the PROGRAM soft key on the scan tool. The DIC should display: READY FOR FOB X (X = fob 1, 2, 3 or 4, depending on the selected position)
  9. With the DIC displaying the correct fob position that is to be programmed, place the new/replacement key fob in the console fob pocket with the buttons facing forward.
  10. A beep will occur once the fob has been learned.
  11. If programming additional key fobs and there is no DIC prompt that indicates READY FOR FOB X, repeat steps 7 and 8.
  12. Exit programming mode by pushing the OFF/ACC portion of the ignition switch. Note: Failure to exit programming mode (press OFF/ACC) prior to pressing the UNLOCK button of each key fob programmed will result in that fob being inoperative. Pressing the UNLOCK button completes the programming sequence and is require to ensure transmitter operation.
  13. Press the UNLOCK button on each key fob that was programmed to finalize the programming and confirm system operation.
Nov 03, 2010 | 2006 Cadillac STS
1995 saab 900 turbo
Two most common problems for this are the DIC and the fuel pump. Can also be the CPS. First check the code. You can try this first before going to a code reader: 1.With the car already off, switch on the ignition without starting the engine. 2. After approx. 6 seconds, the 'Check Engine' light goes out for an instant before lighting up again for 3 seconds. This 3 second flash is a warning that the actual flashing code is about to start. 3. The flashing code consists of a number of short flashes lasting 0.4 seconds. The 'Check Engine' light goes out for 2 seconds between each new flashing code (if there is more than one fault). 4. After the last flashing code, the 'Check Engine' light goes out for 3 seconds before lighting up again for 3 seconds, after which the flashing codes are repeated. Readout continues in this way as many times as you wish. Number of flashes / Function 2 / Manifold absolute pressure sensor 3 / Temperature sensor, manifold 4 / Temperature sensor, coolant 5 / Throttle position sensor 6 / Oxygen sensor 7 / Adaptation 8 / Purge valve (EVAP valve) 9 / ECM, internal fault If no flashing codes display, the problem is something else (other than those nine listed above) and must be determined using a generic code reader that supports OBD 1, or using the GM/Saab Tech II code reader and programmer. My money is on the DIC as it is a very common failure component and fuel pump failures rarely throw a code. The DICs are good generally to 100,000 to 150,000 miles, but this varies wildly, especially if the car is run with overgapped plugs for any length of time. The plug gap should be 1 mm and no more. Cars that are scrupulously maintained vis-a-vis the plug gapping can see DICs last over 200,000 miles.
Jun 09, 2009 | 1996 Saab 900
Play Station 3 Issues
Hello. This is a very common problem. Since your PS3 is under 1yr old, Sony will fix or replace it for free including shipping!!
Nov 26, 2008 | Video Game Consoles & Games
Did you fix your PS3?
Yes,you must connect sony with SONY tv ( hd ready or full hd) and change in PS setings out signal to 720 i or 720 p.When you do this tv will recognize signal and then you can change in setings full resolution
Jun 24, 2008 | Sony Playstation 3 (PS3) Console
HDMI output not working
when the ps3 is off and the red light is on hold the power button down for 5-10 sec youl hear a second beep then let off wait just a moment and it should find your components
Apr 13, 2008 | Sony Playstation 3 (PS3) Console
Realtek HD Driver Instllation failure
Please explain more the position:
1. Is the hard drive properly connected in the computer?
2. have you booted the computer to recognize HD in BIOS?
3. Have you inserted bootabe Windows CD to attempt loading the operating system?
4. Has the Operating system loaded and failed?
Note: hard Drives are made in Standard Industry specs. If its good and connected properly it should work. If it is a second or third hard drive you are connecting, it may be connected wrong in data cables.
Feb 17, 2008 | Computers & Internet
Sony Playstation 3 (PS3) Console Logo
22 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
