Question about Microsoft Xbox 360 Console
My xbox light comes on when i press it,but there is no noises.
My xbox light comes on when i press it,but there is no sound from the disc drive or the fan to say it is on.It has 3 red light but i have changed the paste.It Just wont start.I bought it as faulty to fix the simple lights but to no avail
Most likely since the 3 red lights mean hardware failure it may be your cpu since it is an extremely vital component and overheats very easily. unless you know how to fix it you may not want to try anything. or it is simply not reacting because it does not want to hurt the x-box even more
Posted on Nov 19, 2009
    Problem Solver:
  • 14 Answers
You have the infamous RROD. The Red Ring Of Death. Three flashin red lights that indicate a serious hardware failure. You can check online for several different RROD "do it yourself fixes" or simply pay microsoft to have the unit repaired. There are good chances they may repair it for free, IF the console hasn't been opened. If you have opened t, they will charge you full for repair.
Posted on Nov 20, 2009
One day when i went to play my xbox i turned it on. It made a weird noise it had never made before. Then i realized my TV had no picture or sound, my controller won't connect and the usb ports are also...
It could be a couple different things , the cpu/vga fan , or the dvd drive are the two most common . If you can tell wich is causing the noise that helps a lot . If it's the fan , I would get a can of compressed air A.S.A.P. , more than likely if this fixes it , it will only be temporary . In the case of the fan making noise it's normally about to die or has some sort of blockage ( either way you don't want to even risk running your system without having it repaired / replaced ) . If you have to open up the Xbox 360 it's not a bad idea to put Arctic Silver #5 on both the CPU / VGA then replace the Heatsinks ( minus the horrible X-Clamps , check http://www.dcemu.co.uk for a full tutorial ) . If the sound is coming from the dvd drive you can easily test by swapping out discs , running a disc drive cleaning device / kit , disconnecting the dvd drive & booting your system without it or with a compatible replacement .
One last thing , take note of any blinking lights ( RROD , E74 , Etc.. ) as this could be causing your noise issue or just a symptom .
Apr 15, 2011 | Microsoft Xbox 360 Console
Grinding noises and wont accept disc
your dvd rom drive is gone you can get this replaced by someone that knows how to do it but if its still under warranty send it to Microsoft
Nov 30, 2009 | Microsoft Xbox 360 Console
Xbox 360 disc drive is not reading discs, comes up with
time for a new reader only around 15 pound or 28 or so dollors on ebay and see you tube on how to replace drive its not to hard to do
Nov 20, 2009 | Microsoft Xbox 360 Console
My xbox 360 disk tray will not open it wont even open a little some one help me
have you tried to open the drive using the xbox dashboard, when you press the eject button does the power light flash? is there any noises coming from the drive when you try to eject.
It could be a faulty drive and the only way to get into the drive is by opening the console up and this could void your warranty. if your hearing noises (motor spinning) from the drive it could be the drive belt has snapped (like a small elastic band) you could have dirt in the gears and cogs jamming the drive. so you wouldnt hear noises (except the disc spinning if there is a disc in it).
if the power light flashes when you press eject more than likely it is the drive belt or dirt in gears.
Oct 31, 2009 | Microsoft Xbox 360 Console
Inserted disc press play grinding sound and disc left scrapped
If your xbox box it's new I would take it back and get another one, becase you do probable have problems with your dvd drive and it will keep scratching the games. the laser on the drive doesn't work as hard when playing a music cd than when it plays a game or a dvd.
If you don't want to take it back, then play a couple dvds and if it reads then fine then you could try again. it shiudn't take more than ten second to read a game so if its taking longer just get it out.
Dec 27, 2008 | Microsoft Xbox 360 Console
UNABLE TO PLAY GAMES
sound like the wormgear motor
is sliping or failing ether way
you may need a new drive with
a pc board swap .cost 40.00 D.I.Y.
May 03, 2008 | Microsoft Xbox 360 Console
Loud noise from unit
From what i understand, the dvd drive can spin wonky allowing the disks to foul and cause large scratches
details can be found here.
http://www.llamma.com/xbox360/repair/Refurbishing-the-HL-Xbox-360-DVD-Drive.htm
Mar 10, 2008 | Microsoft Xbox 360 Console
Loud noises
Depending on the age of the system, replace or ignore.
Its your DVD drive, unfortunatly most drives are noisy -FACT- so sometimes you have to just live with it- check the back ,if manfactured in 2005 ( a lot of bad drives from this year) might be worth ringing microsoft to see if an exchange is possible.-
But if its not showing any loss of play/loading or scratching the discs - or showing error- please place disc in a xbox 360 console...You may just have to put up with it.
Jan 24, 2008 | Microsoft Xbox 360 Console
Disc tray
Not entirely sure but maybe the disk drive bricked, though I wouldn't replace it without looking into it more.  But it would make sense consider the noises.  Was there anything attached to the disc or was the disc damaged after this incident?
Oct 12, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
63 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
