Question about Mitsubishi HS-U445 VHS VCR
E2 error Hi - I have a HS-851 VHS, and have submitted on this model as though it was the closest. I have an E2 error code flashing and was wondering what this is and if it is significant/fatal prob. I see another post with a flashing 2 light, which seemed to be tape ejection related. My partner had trouble removing a tape and finally got it out via repeated use of the eject button. Some force was required by her to retrieve the tape once it became partly available. It is a relatively old Nicam VHS but has been really great (I love the ability to skip adverts). Will probably buy a HDD recorder, but want to be able to play existing videos - so any help is appreciated. Mitsubishi HS U445 I have a flashing E2 error...have unplugged and done everything imaginable..but the manual doesn't even mention L1 L2 OR E2 errors...I love my recorder..and hate to get rid of it due to this problem..In the past a repairman just told me over the phone the solution..but I don't remember what it was..and he is no longer working at that shop..If you have any suggestions..I would so appreciate it. thank you......lcreech@charter.net
  • 1 more comment
  • crazlyne Jan 20, 2008
    I have an HSU-445 vcr..and the E2 flashes continuously, when the vcr is turned off....and without a tape in it....
  • lucky19 Feb 14, 2008
    e2 error
  • northernont Feb 20, 2008
    E2 flashes when power is on, tapes that have been stopped in the middle will not play or rewind. tried a head cleaner, didn't work.
Just had the same E2 come up on my HSU-445. The only thing we could figure out was to try a different tape than the one that was in there when the error came up. That seemed to do the trick. Not sure how long that will work. Good luck.
Posted on Jan 17, 2008
Need help. Flashing E2 and 61 codes. The paper is not jammed and it has a new carterage.
Canon PC-920 Black and White Copier E2 error - Questions ...
www.fixya.com > ... > Canon > Canon PC-920 Black and White Copier .. error code e7 & e2 Cannon pixma mp145 printer error code e7 & e2 E2: Reload the paper correctly and press [Black] or [Color]. E7: The cartridges are not ..
Jul 21, 2015 | Canon PC-920 Black and White Copier
Kelvinator beverage cooler E2 error code
Temperature sensor error code.
Login'Contact Us Appliance Appliance Repair Questions? Ask a Technician for Answers ASAP
Ask an Expert Home Improvement Questions Appliance Technician
How JustAnswer Works:
  • Ask an Expert
  • Get a Professional Answer
  • 100% Satisfaction Guarantee
Ask Daniel Your Own Question
Daniel, Home Appliance Technician
Category: Appliance
Satisfied Customers: 16124
Experience: 20+ yrs. experience in white goods repair. NVQ Level 2 electronics manufacturers training courses. Type Your Appliance Question Here... Daniel is online now Hi, I have a BWE40 Wine Cooler and an E2 Error Message.
Resolved Question:
Hi, I have a BWE40 Wine Cooler and an E2 Error Message. What does this mean please?
Submitted: 3 years ago.
Category: Appliance Share this conversation
Expert: Daniel replied 3 years ago.
Hi
E2 error code is a temperature sensor error code.
Remove the plastic black cover on the back and you will see the control board.
On the board you will see a wiring block with 4 thin wires going to it.
Test the 2 wires on the left and the 2 wires on the right with a multi meter. The reading in Kohms (kiloohms) should be the same.
If any are faulty then they will need to be replaced.
If the readings are the same, replace a faulty control board to be rid of the E2 error and your problem.
Feb 12, 2014 | Marvel 61AR Compact Refrigerator
Technofit TS500i treadmill error code?? ( E1 & E2) please help!!!!!!!!!
Dear Sir:
The error code E1or E2 coming from this reasons.
1) Adjust the speed sensor, see the diagram attached, clean, and tight the connector wires.
2) Test the main motor input voltages coming from the output from the main motor board.
3) The main motor or motor board can be faulty or need repair.
See my personal TIPS for HELP and guide you.
sincerely. God bless you
Apr 23, 2012 | Exercise & Fitness
Dryer will not start display works, when i push the start button it just beeps and does nothing, shows a E01 code.
Hi, this is what the error code means,
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Hope it helps.
Jan 19, 2011 | Whirlpool GEW9250 Electric Dryer
Error code E2 A.C. AUX
Disply E2 error Coming
Jul 23, 2010 | Heating & Cooling
Mitsubishi VCR HS-U57 power supply questions
The closest model I have is HS-U61 it may be the same
D901,902,903 and 904 -are part of a bridge rectifier -standard B+ diodes DSA3A1 - 264P430030
D913,D914-(connected directly to R902 through transformer winding to D914) -1SS82 standard switch diode
D917- (connected to base of Q903 and D916) 1S2076 standard switch diode.
Check if they are located as described.
Oct 27, 2009 | Televison & Video
Getting E2 error flashing on vcr and can't rewind tape or anything.Don't have user manual to see what that error means.
E2 means: Loading motor locked in the unload direction. Usually(not always) happens with a going bad VCR tape on the rewind. Tape is becoming too difficult to rewind and/or VCR is getting tired. Eject tape. Discard tape as soon as practical, new tapes are cheap. To clear: Hold power on/off button for 8 seconds.
Aug 28, 2009 | Mitsubishi HS-U445 VHS VCR
E2 error
Something might've been broken in the forced tape removal. VCR tape carriage (the cassette unit) assemblies are rather delicate, easily broken, in contrast to the units in early VCRs (from the '80s or early '90s). Use of force in tape removal... can break stuff, or perhaps get the gear timing fouled up. Take the top cover off, look for broken pieces of this assembly. If this assembly has gears on the right side, this obviously means it is gear driven. Timing is set by lining up marks on the gears, in most cases. Setting this might be tricky- service literature will tell you how to set this, and in what mode the marks line up.
Apr 15, 2007 | Mitsubishi HS-U778 VHS VCR
Mitsubishi HS-U445 VHS VCR Logo
522 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
