Question about Casio CFX-9850G Plus Calculator
STAT DIST BINMAL - Casio CFX-9850G Plus Calculator
  • Casio Master
  • 8,016 Answers
Press MENU after turning the calculator ON
Use the navigation keys to highlight STAT and press ENTER/EXE
The TAB above the F4 key is DIST
Press [F4:Dist] to access the distributions
Press [F5:BINM]
You get the two binomial distributions that are available.
Select the one of interest to you and complete the command.
Posted on Jul 25, 2010
How do i adjust the engine timing on a 7.4 chevy 1998 fuel injected
Is the engine backfiring? If so and you had the distributor out you may have the firing order off by one half a tooth. But back to your question in order to set the engine time you would:
1. Mark the timing slot on the balancer with white chalk.
2, Loosen the bolt on the dist. just enough so you can move the dist.
3. Remove the single wire coming out of the dist.
4. Hook-up your timing light to #1 plug
5. Start the engine and see where the white mark is on the timing mark and see if you need to move the dist. to the proper timing degrees(It is on a label on the radiator support). Once this in the proper alignment tighten the bolt on the dist. you can turn off the engine just do not move the dist. before tightening the bolt for the dist. Then plug your wire back into the dist. and unhook you equipment.
Feb 17, 2015 | 1998 Chevy 3500 Pickup Truck All Chrome...
My heater doesnt blow as hot as it used to, temp gauge barely exceeds 100... all started after replacing dist cap, and started using different weight oil, could that hav anything to do with it?
No, the cap or oil would have no effect at all. It sounds like you have a problem with the thermostat and it's probably just a coincidence that they happened at the same time. Before replacing the t-stat, make sure that your coolant is full to capacity. If it is low, there will be low heat due to lack of flow through the heater core.
Dec 17, 2010 | 1993 Jeep Grand Cherokee
How do I look up chi square table on a casio fx-9750G plus?
Here is a sequence of screen captures to illustrate how to do it.
Turn calculator ON. Use arrow to highlight STAT and press EXE
Press F5 DIST
Then select F3 CHI
Choose Cpd or Ccd
If you choose Cpd : you must enter the Chi value you want, and press EXE, then the number of degrees of freedom (df) and press EXE. The Execute command is highlighted. This allows you to perform the actions
indicated by the Thumbnails at the bottom of the screen: calculate a value or Draw the distribution.
In the example above I took Chi=1, and df=3 and pressed the CALC menu.
If I press the DRAW menu instead, the distribution is displayed.
If you want the other distribution Ccd, press Ccd instead in screen capture 4.
Jun 21, 2010 | Casio FX-9750GPlus Calculator
Using the CFX9850G, how do you get to do normal distribution with lower,upper, mean and standard deviation? I can't find the menu to get to that function.
Press Menu to get the icons displayed. Highlight STAT and press EXE.
If you want to perform statistical calculations, press the F2:Calc key and choose the Type of stats :1-Var, 2-Var, and Regressions.
If you want to use the normal distribution, press F5:DIST then F1:NORM.
Feb 15, 2010 | Casio CFX-9850G Plus Calculator
1989 tbi chev. 5.7 missing or trying to flood with
Try your coolant temp sender, if it's bad the computer thinks it's running cold all the time, therefor giving it more gas.
Oct 26, 2009 | 1989 Chevrolet C1500
I was told that, to do binomial distributions on a ti-86, I would need to hit 2nd Math, then More, and I should see something that says STAT and go from there to get to DIST and Binomi. I see nothing...
Sorry, but you information is wrong, to find the binomial distribution use the PROB menu not the STAT menu. Its name is randBi
[2nd][MATH][F2:PROB] scroll right.
Hope it helps.
Oct 10, 2009 | Texas Instruments TI-86 Calculator
1990 K5 Blazer DIED(Electrical?)?
There may be no injector pulse if the computor does not see a RPM signal.
There will be no spark if the ignition module does not see a dist pulse from the dist pickup.......a RPM signal.
Because you do not have both ......I would suggest to check/change the dist pick up.
Follow the wires from the ignition module inside the dist to the pickup which is also inside the dist.
If it is just a bad dist pickup....keep all your old parts as good spares.
Also...is the dist turning? to provide a RPM signal?
You will have to remove the dist to change the pick-up.....mark your timing locations......"rotor position" and "dist body location"before removal.
A quick test before installing the "repaired dist" .....plug it in the the truck wiring and turn on the key....DO NOT CRANK THE ENGINE OR YOU WILL LOSE YOUR DIST ROTOR CORRECT POSITION......as you spin the dist by hand .....the injectors should spray.
Aug 23, 2009 | 1989 Chevrolet S-10 Blazer
Standard deviation
pulse F1(CALC), F1(1VAR) and it goes to 1-Variable Screen and shows the following:
x-(mean): 49.3333333
Sumx:296
Sumx^2:15066
xon:8.78761755
xon-1:9.62635271
n:6
I guess that you wanted the x- and xon
Also are available in RUN mode through VARS, F3(STAT), F1(X), F2(x-) and F5(xon)
Jun 03, 2009 | Casio CFX-9850G Plus Calculator
Casio CFX-9850G Plus Calculator Logo
95 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
