Question about Apex Digital AVL2776 27 in. HD-Ready LCD Television
When hooked directly to cable, I get a blue screen and sound. When hooked to Componet Video, S- Video, or Composit Video via a cable box, I get a picture and sound. Apex remote will not change sound or channel, but cable box remote will when hooked to any other video input other than the straight cable connector. Does this mean the straight cable tuner is bad? Any suggestions about repair?
  • 834 Answers
Your cable box rf pass through may be turned off if you can access the menu of the cable box by turning it off and hittiing th emenu button on the cable box with tv on an scroll down to rf out if you need hael call your local cable company
Posted on Nov 19, 2009
Wd65738 blue screen
blue screen means no video signal, if the source is on hdmi ensure the cable is rca or in simple audio video jacks which u will have to connect in the dvi input of the tv reason is hdmi means high definition interface and transmits by hdcp like the data of an internet meaning its digital platform which the tv can only process thru the dvi inputs or component y,p,b
Jul 17, 2013 | Televison & Video
I have Vizio I changed cable from Dish Network to a Local Co. now I can't get cable or sound, although the cable box is all lit up. I get a blue screen with no signal running across it and I have
check with whoever is your current signal provider---paying for service they will usually come out and make sure it is working either via the coax fitting or via the audio/video jacks
May 17, 2012 | Vizio Televison & Video
Hook up
Hi:
This type of hook up is only for television viewing, to view the DVD you might consider purchasing some componet cables, they are color coded so hooking up is a snap, on the back of the DVD player you will see three RCA type connections Red/Green/Blue. componet cables are also these colors, connect one end of the cables to it coorsponding color on the back of your DVD and the other in the same color connectors labeled componet 1 input on the back of your television. You will also need a red and white RCA connector also for the audio as this is sound, a total of 5 connections will complete the hook up. Or you can go the simple route and use RCA type cables that come as yellow/red/white but for the best picture use componet cables this will allow you to watch your movies in HD.
Apr 27, 2010 | Sylvania Dual Deck DVD/VCR
When i hook up dvd player to a insignia plasma tv i get a picture & sound but it is in black&white.how do i get to be color
if you connect composit video from your DVD player to the "Y" jack of the tv then you will get only a black and white picture .. the composit video out of your DVD has to be connected to the composit video input of the TV .. or if you have component outputs on your DVD then you can hook those up to the "three" component inputs of the tv .. (you have to have all three hooked up plus 2 audio cables ..
Oct 23, 2009 | Insignia 42" Flat-Panel Plasma HDTV
Snow no connection to cable box
the fact that you are seeing snow tells me that your tv in in the tuner mode .. your cable box is more likely hooked up to the AV input (composit video + 2 sound channels ..3 wires total) .. or it could be hooked up to component inputs (5 wires total) ... you will have to go to the menu of the TV and choose the proper input ... if your cable box is actually connected thru the tuner (coax cable to RF input .. one cable) then you have to select the same channel on the tv as what the cable box is set to .. that is usually chan 2 or 3 ... there is also an svideo input on your tv .. that can take the place of the composit input ..
here is a diagram of the back of your set so you can determine how its hooked up ..
http://www.fixya.com/support/p169436-zenith_p42w46x_42_in_edtv_plasma/manual-6443/page-8
lots of other good information there as well
Oct 03, 2009 | Zenith P42W46X 42 in. Plasma EDTV
My screen is completely black, but the sound is fine.
Hello:
I would start with the fact that you might not have any high voltage so your picture tubes are not lighting up, You can determine this by listening closely to your set with no noise in the immediate area when you turn on the set, you should hear a brief static sound from with in the set when u first turn on the set, if not them there is no high voltage, If you can't determine if you hear the sound or not, another way to determine is remove the lower front cover form the set and there should be a small wood or plastic panel behind it. Remove it also and look for a grey or black device with six adjusting knobs, this is the focus and screen block, It is labeled with three on top and three on bottom which is Screen focus, and Screen Bias for each individual tube one knob labeled R for red, G for Green, and B for Blue. Do not turn the ones that says focus as you will need a video picture to reset, since right now you have no video. The other three knobs are screen bias controls, turn either one ONLY! one slightly to the right while looking at the screen, considering which one you turn the screen should turn that color. If it does'nt then your problem is either no heater voltage or no High Voltage. I recommend you put a mark on the control before turning it so you can put it back to its orginal location. One final note worth exploring, if you are connected to a cable box check its connections especially if you are connect through Componet Video for HD, I have found that some times the Green Cable come out and this will produce no video also. Try hooking a dvd player of sort to an video input and use your remote to change to that Inpout and see if you have a picture if you do then Its more then likely your cable box is faulty not producing video or hooked up wrong, If you are connected by componet cables make sure they are connected green to green, red to red and blue to blue...
Hope this helps..
Sep 21, 2009 | Toshiba 50H82 50" Rear Projection...
When componet is hook up for hd
My first guess would be that the component connections are not matched. Check the component method and make sure that both the source and the TV are set the same. There are two methods:
1) RGB
2)Y,Pr,Pb
If the set is set for RGB and you are sending Y,Pr,Pb the picture will look a bit purple.
Dan
Jan 28, 2009 | RCA HD61W66 61" Projection HDTV
When i try to connect my xbox 360 to my Vizio hdtv it doesnt not recognize the connection. I have tried replacing the cord to no avail
I have a Vizio 37' tv with an Xbox 360 and it works fine. I am a Cable repair tech, hook up the xbox using the composit cable first RCA these are the red white and yellow cable to a non high def input on the tv, if that works check the settings in the xbox, there is a screen that will allow or enable HD quality pictures. Also check the Xbox cable itself. at the Y there is a small swiitch that goes from componet to composit you can only get HD if you use the Red Blue Green cables, then make sure you have the TV input set to that input other wise you will have only a blue screen. If that does not work, Hell, call the cable company if you are a customer, they should send someone out to show you how to connect it, and they might not even charge you, we don't, but I work for a smaller company, not ComCast or Cox, If you want to email me you can kml39@yahoo.com, good luck
Jan 10, 2009 | Vizio L37 Television
How to connect new HD cable box to receiver
HI:
You are using a new HD Cable box, that are using componet video cables for HD, Unfortunetly this receiver does not have componet inputs, so you will just have to run the audio from the televison directly to the receiver by connecting the video out and audio out from the television to the receiver's video Input one. This will require a normal RCA composite cables yellow,red,white. Connect one end of each of the cables to televisions output terminals, and the other to the input one on the receiver. Note: Your TV might have a seperate term called Monitor out, Connect the yellow here, and the red and white to audio out. You can do the same for the DVD but you have to use the same cables,Also the television will not display HD picture this way as this is not a HDTV Receiver. If you just want TV sound to the receiver then do not use the video(Yellow) cable just use the audio out terminals from the tv and connect to Input one on the receiver. you can do this with the cable box also but you have to use RCA type cables . If you want the full HD experience then a new up todate receiver is necessary.
Dec 06, 2008 | Sony HT-DDW740 System
Optical output, no sound!
Have you selected Optical output from the audio setup screen of the TV? That needs to be selected to transfer TV audio to the optical out of the TV.
Jul 28, 2017 | Sony KDS-60A2000 60" HDTV
Apex Digital AVL2776 27 in. HD-Ready LCD Television Logo
277 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
