Question about LG WM2277H Stainless Steel Front Load Washer
I HAVE A LG TROMM WM2277HB. It went into spin, then stopped and "OE" came on the timer. I tried the unplug, hold power button for 5 seconds. That worked through the first spin of a rinse & spin cycle. Then it stopped and is showing "OE" again. Thanks Pete
  • Peter Wood Nov 22, 2009
    That was it. We just washed bath mats that fell apart in the washer. Along with hair in the trap. Works great now. Thanks!!!
    Pete
  • 3,741 Answers
OE stands for drain error. The unit does not drain completely within the 10 minute time.
Please check the water pump filter for blockade.
You can bring down the drain hose for the water to come out. Most likely pump trap is clogged up. Access it behind small door at front. Drain water out through small hose that is there otherwise water will be all over the floor when you unscrew the trap.
-------- This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 19, 2009
  • jeff w Dec 20, 2011
    The pump filter was clean on our washer, so I used compressed air to back blow it from the back of the drain hose through the pump filter and that did the trick. A clump of carpet from the the new floor matt came out.Somehow it must have gotton around the filter which was clean when I had originally checked it.I hope this helps.
What is the issue with LG washer
LG WM2277HSW XL Front Load... Repair Questions - Fixya
www.fixya.com/.../p95436-lg_wm2277hsw_xl_front_load_stackable
Recent LG WM2277HSW XL Front Load Stackable Washing Machine questions, problems & answers. ... My frontloader washmachine will not turn on · LG ...
LG WM2277HSW XL Front Load Stackable Washing ... - Fixya
www.fixya.com/search/p95436-lg_wm2277hsw_xl_front_load.../open
LG WM2277HSW XL Front Load Stackable Washing Machine, open related issues. Get free ... Wait 5 secs after turning off door release should open. If this does not ... OE error message won't open door, won't spin out water What is filters & open it are my problemsDue to that I cann't ... Where is it sticking and how do I fix it?
LG Tromm WD 12270 RD washer and dryer 'LG ...
Dec 19, 2015 | LG WM2277HSW XL Front Load Stackable...
Washer was spinning out. It got unbalanced. And stopped before I could get to it. Now it won't start. Why?
try unplugging and plugging back in. if that does not work, try unplugging and then plugging back in while holding down the power button. good luck.
Mar 03, 2015 | LG 4925ER1015B 4924ER1010 Used Frontload...
Hello, I have a front load LG TROMM WM2277HB and yesterday it wouldn't spin anymoreand there was a noise coming from inside like 2 metal cylinders were rubbing on each other. I called SEARS Serv
if the machine fails to spin and makes noise there are thee things to check .if it fails to drain the water check if something is stuck on the drain pump no 2 turn the drum with your hand and check if the drum is moving freely if not something is stuck between the drum and the housing if the bearings are faulty the machine spins but makes alot of noise towards the end of the cycle i hope this will help you.
Jan 21, 2013 | LG 4775er2002a Door Hinges for Wm2277hb...
I have a lg tromm wm2277hb and it's not spinning. The le error code is coming on. I tried to unplug the unit and press and hold start button and then the power button for 5 seconds. Then tried the...
Hi
Error code LE indicates that either the motor is not turning or has locked up for some reason. It can also be due to Hall sensor which monitors direction and speed of the motor. If the sensor is faulty then also this error appears. Motor lock can be caused by several things from a loose connector, to a bad motor. To make sure it's not a locked motor, try turning the drum with your hand. And, if there is any resistance while turning the drum or the drum doesn't move freely then the motor is locked and you'll need to get it replaced. If the motor seems to be fine then you would need to replace the Hall Sensor. To replace the hall sensor, take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Hope this helps...
Daniel
Jun 17, 2011 | LG WM2277H Stainless Steel Front Load...
I have a problem with my LG Tromm front load washer. It will wash seemingly normally up to the point it gets to the spin cycle. Then a motor comes on and the machine does not spin or drain. The display...
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Sep 10, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My lg tromm washing machine has an error code LE
Empty Washer and unplug. Hold the start button (arrow with two lines) for 10 seconds. Plug back in and put on the Rinse and Spin cycle (right hand side) I went ahead and ran that cylce (31 minutes with some bleach) and all worked well.
If problem persists call CSR. 800-243-0000
Jul 14, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Trap clear on lg tromm. still no spinning and/or draining; pse ad
OE code should appear. I've been able to re-start after unplugging the machine for ten minutes and then re-plug and it did clear the code and spin out but I'm back to the same problem and unplugging isn't working anymore. I'm wondering now if the issue maybe the machine isn't level. Well, something I'm now going to check. Good luck.
Dec 27, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM2277H Stainless Steel Front Load Washer Logo
447 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
