Question about Microsoft Xbox 360 Console
When switched on only 1 red ring flashes and on the screen it says system error
    Scholar:
  • 60 Answers
1 red ring is a hardware failure. This can be one of the chips needing to be repaired (I've seen this when the GPU goes bad) or it can be some other hardware failure.
Microsoft recently expanded their warranty on the xbox's due to the high failure rate. If you go to support.xbox.com you can check for warranty status. If you are out of warranty, then I would advise performing the red ring of death fix first, there are plenty of instructional videos on YouTube
Posted on Nov 19, 2009
How to fix the red rings on your xbox 360
1 Red Light Error -
Your system indicates this error when only the bottom right part of the ring is flashing. When you have 1 red light on the Xbox 360, it is usually associated with an error code you see on the screen, such as the Xbox 360 error code E74.
Searching for this error code online or in the Microsoft support site will give you the description and solution. Usually the problem lies on the DVD drive whether it is the wrong firmware or lacks a chip.
It may also be a hard drive error which can be resolved by taking it out and putting it back in or it can be a voltage error which usually occurs if you have added accessories to it. It is best to research the error code so you know exactly what to do.
2 Red Lights Error - One of the most common is when two red lights are flashing. No need to panic if you see only see the Xbox 360 2 red lights. Its sole meaning is that the console is too hot and needs to cool down. Power down the system and try again in a few minutes or if possible after an hour or two.
After giving the system some rest and playing in a much cooler environment, you should be back to your gaming in better performance. If the problem persists however, you may need to have it serviced to have the cooling issue fixed.
3 Red Lights Error - f you see three flashing lights, you are experiencing the infamous three red lights problem that many other gamers are frustrated with. You may also know it as the Red Ring of Death.
At one point 1 out of every 3 Xbox 360 owners experienced this problem. This is the one error that you do not want to get. This highlights that there is a serious Xbox 360 hardware problem.
Your options are to send your console back to Microsoft for repair or to fix it yourself. Be prepared to spend a nice amount of money ($140 or so) if you are sending your system to Microsoft and you no longer have the warranty
4 Red Lights
If you have to get any flashing lights on your Xbox 360, pray that this is the one. If the entire ring flashes, it is a minor problem that indicates that the AV cable isn't connected properly or in rare instances, the cable is damaged. Make sure everything is properly connected and replace it if It still doesn't work.
Jul 21, 2011 | Microsoft Video Game Consoles & Games
Tip
XBOX 360 Error Codes
There are several error codes you can get with an XBOX 360, the first step to resolving any problem is finding the root cause. The fault codes are primarily shows on the "ring" on the front of your console (this is the ring split into 4 segments that shows when controllers are connected and what player position they are).
  • 1 SEGMENT FLASHING RED - Thisindicates a displayable error code, the specific error code will bebeing displayed on the TV you have it connected too.
  • 2 SEGMENTS FLASHING RED - The console has overheated.
  • 3 SEGMENTS FLASHING RED - This is the somewhat infamous RROD (Red Ring Of Death).
  • 4 SEGMENTS FLASHING RED - AV cable not detected.
If you have 1 segment flashing red indicating a displayable specific error code then you can identify the fault from the list below.
  • E45 - Update Error.
  • E64, E65, E66 - DVD Drive Error.
  • E67, E68, E69, E79 -Hard Drive Error.
  • E71 - Update Error.
  • E72 - Unknown.
  • E73 - General Hardware Error.
  • E74 -AV cable error.
  • E76 - Unknown.
This is a basic overview of all the fault codes for the XBOX 360, for more in depth information on the faults and how to repair them please see my other tips!
Thanks!
on Mar 25, 2010 | Video Game Consoles & Games
Everytime i turn my xbox360 on its flashing red like it the red ring of death
1 Red Light
2 Red Lights
3 Red Lights
If you see three flashing lights, you are experiencing the infamous Xbox three red lights problem that many other gamers are frustrated with. You may also know it as the Red Ring of Death.
Your options are to send your console back to Microsoft for repair or to fix it yourself. Be prepared to spend a nice amount of money ($140 or so) if you are sending your system to Microsoft and you no longer have the Xbox 360 warranty.
If you want to try to fix the problem yourself then you can see reviews of guides that we recommend to show you step by step how to perform the repair.
4 Red Lights
Mar 22, 2011 | Video Game Consoles & Games
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Flashing red light on the bottom right of the ring and an error code 73 picture on the screen
Hi,Turn on unit until the red light flashes and the error code(E 73) shows up on the screen. Next insert toothpicks in the back of the console(while unit is running) into the cooling fans, this is to suppose to overheat the console and start two red lights flashing. Turn off console when this happens(unplug all cords from console) and turn the system back on.
This solution will fix your problem for sure. Thank you!
May 12, 2010 | Microsoft Xbox 360 Console
What do i do when i get one red ring?
If you mean that all four quadrants of the ring are flashing red, check your A/V cable. Make sure all cables are nice and snug on both the Xbox and the Television.
If only 1 red light is showing, flashing or not, check any error messages listed on the screen and try Xbox support
May 02, 2010 | Microsoft Xbox Console
System error and flashes red when i start it up
Firstly check all cables are inserted correctly, the 360 will show a complete red ring if a cable is not connected securely. If all cables are secure, then it sounds like the onset of the red ring of death. easy enough to cure if you got the technical know how, if not give me an email and i'll try and help you out.
Mar 11, 2010 | Microsoft Xbox 360 Console
One flashing red light.
usually with 1 red light errors, there will also be an error that shows on the screen like e73, e74, e75, etc. You will need to first get your secondary error code.
then enter either the e-code from the screen or the secondary error code into the repair guide
Mar 06, 2009 | Microsoft Xbox Console
Switch computer on and the light is red but on the screen it says system error contact xbox customer support
SYMPTOMS loadTOCNode(1, 'symptoms'); You receive the following error message in multiple languages: System Error. Contact Xbox Customer Support. CAUSE loadTOCNode(1, 'cause'); Typically, this error message is caused by a hardware failure. THINGS TO TRY loadTOCNode(1, 'whattotry'); Note If you receive an error message and see one flashing red light on the front of the console, see the following article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/) Xbox 360: One red light flashes on the Ring of Light and you receive an error message 1. Turn off the console, disconnect and then reconnect all cables. Turn the console on again. 2. If an Xbox Hard Disk Drive is attached to the console, turn off the console, and then remove the Hard Disk.
For more information about how to remove the Hard Drive, click the following article number to view the article in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/) Xbox 360: How to attach or remove the Xbox 360 Hard Drive Turn on the console, and then test for the error message. If you do not receive the error message, turn off the console, and then reattach the Hard Disk. Alternate testing with the hard drive connected and removed to see whether the error message occurs only when the hard drive is attached. If the on-screen alpha-numeric error is E67 in the error message, see the following article in the Microsoft Knowledge Base: 917874 (http://support.microsoft.com/kb/917874/) Xbox 360: One red light flashes on the Ring of Light, and you receive error E67, E68, or E69 3. If an Xbox Memory Unit (MU) is plugged in to the console, turn off the console, and then remove the Memory Unit. Turn on the console again and test for the error message. If the error message does not reoccur, turn off the console, and then reinsert the MU. Alternate testing with the MU inserted and removed to see if the error message occurs only when the MU is inserted. 4. If you continue to experience this behavior, contact Xbox Customer Service.
Jul 17, 2008 | Video Game Consoles & Games
1 redlight flashes clearly red at bottom right hand side of the power ring,and 2 other dim red lights are flashing,only the 1 in the bottom right is bright though.it happened 2weeks ago but i tryed it...
Do you get an error message on your tv screen? 1 flashing red light means there is a hardware failure such as your DVD drive hard drive, dashboard error ect. Not much can be done about this issue besides having microsoft fix it.
Apr 23, 2008 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
35 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
