Question about HP FE696UA Pavilion DV9922US Entertainment 17? Notebook PC
How do take apart the bottom case of a HP pavilion dv9000 series laptop - I was changing the LCD and a screw got loose and fell into the lower case via the hinge - its rattling around between the battery area and the back of the computer. Anyone have diagrams, etc??
  • ssoszka
    ssoszka Nov 23, 2009
    That worked, thanks.
  • 10,515 Answers
The best i could do is to Offer a Service Manual for the same and i hope that would help you to fix the problem.
The download link is :-
http://h10032.www1.hp.com/ctg/Manual/c01311536.pdf
You need to have Acrobat Reader to View this.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 19, 2009
My hp dv600 when powered up looks normal but if i give it a few seconds the screen goes black and wont come back i shined a light and i do have picture but no light maybe ballast?
alejandro,
An LCD screen cannot produce enough light by itself. It needs an additional light source.
A Backlight is the additional light source.
A Backlight is a CCFL.
Cold Cathode Fluorescent Lamp.
Very similar to the Fluorescent lamps, (Bulbs), used in homes and businesses, but on a MUCH smaller scale.
HP Pavilion dv6000z series Notebook PC, is a general series designation. The EXACT model number is on the bottom of the laptop in a white Service Tag.
The HP Pavilion dv6000z series of Notebook PC's used either an LED or CCFL type of Backlighting.
Depends on which model it is.
http://www.screentekinc.com/backlight-ccfl-led-explained.shtml
As stated in the above information a Backlight is mounted in the back, or on the side of the LCD screen.
The LCD screen is composed of layers. These layers are held together by a metal frame which emulates a picture frame. If the Backlight is a side unit it will be held in place next to the layers, and inside the metal frame.
[Which means the LCD screen's metal frame, (LCD Panel Frame), needs to be opened on one side.
This will leave the layers which compose the LCD screen loose. The layers MUST be held in the proper placing when changing out the Backlight. Not an easy job to accomplish]
An Inverter is used to change the power coming from the laptop, to be used by the LCD screen, and Backlight.
90 percent of the time the problem is the Inverter.
The Inverter for the Pavilion dv6000z series of Notebook PC's is located inside the Display Assembly.
The Display Assembly is the
1) Display Enclosure Cover, (Plastic top of laptop),
2) LCD screen,
3) LCD Panel Frame, (Metal frame around LCD screen),
4) Display Bezel, (Thin plastic frame which surrounds the LCD screen in the front)
5) Camera Module
6) Inverter
7) Display Enclosure Cover Hinges (2)
8) Display Enclosure Cover Hinge Covers (2)
9) Wireless Antenna Transceivers and Antenna Cables
10) Microphone receivers and cables
11) Various mounting screws
[The Top Cover for a Pavilion dv6000z series Notebook PC is essentially the Palm Rest. The cover under the Keyboard]
With the Display Bezel removed the Inverter is located at the bottom.
(Display Assembly removed from laptop first)
HP Support > Pavilion dv6000z Notebook PC series> Manuals>Service Manual>
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=3224052&
One example of an Inverter for an HP Pavilion dv6000z series Notebook PC,
http://www.amazon.com/DV6000-DV9000-V6000-INVERTER-AS0231721C1/dp/B00480MXUS
Please post additional questions in a Comment.
Regards,
joecoolvette
Jun 11, 2011 | HP Pavilion dv6000z Notebook
I Have loose screen on hp pavilion 7000 series,
If the screen can not hold when you open the laptop, you need to change LCD display hinge. You can buy from here.
May 09, 2010 | HP Pavilion dv9000z Notebook
Can this HP Pavilion DV9000 laptop adapter fit for Compaq Presario V3000 laptop? I doult that HP Pavilion DV9000 laptop adapter on website:http://www.laptopbatteryshop.ca/hp-pavilion-dv9000-ac-adapter.htm...
Have a look at the label on the bottom of the V3000 laptop and check the voltage and amps power rating of the laptop.
If the DV9000 adapter has the same voltage and current rating (amps) or higher amp rating then it is suitable for the V3000 laptop, provided the power plug fits the V3000 power socket.
Jan 15, 2010 | Dell Inspiron 1525 Laptop
Can this HP Pavilion DV9000 adapter fit Presario V3000 laptop
just see it from http://www.udtek.com/hp-pavilion-dv9000-ac-adapter-90w-185v-49a-p-2970.html.may this is good for you.
Jan 15, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
I have a 3 year old hp pavilion dv9000. For 3
Quite often this is caused by someone changing the display type. There should be a function key control that allows you to view just your lcd display, an external display, or both. Try and change that setting and see if it will resolve your issue.
Jul 20, 2009 | HP Pavilion dv9000z Notebook
I have a hp pavilion dv9000. and i need the screw for it.
Check out page 86 for the display schematics. Page 120 outlines the dis-assembly. Page 154 actually describes the screws of which you speak. You may be able to purchase them locally.
Jun 06, 2009 | HP Pavilion dv9000t Notebook
My hp pavillion dv9000's hinge broke. But I was able to use it after. Then I tried to close it..and it just shut off and it will not come on. I want to know what I can do to fi it
HP *had* issued service alert 08112101 which covers the left display hinge failure.
HP Notebook Left Display Hinge Program
HP Pavilion Notebook
model series affected: dv9000, dv9100, dv9200, dv9400.
This program recently ended on May 31, 2009, but HP may still allow for a grace period.
Otherwise, you'll need the following:
Display panel back panel enclosure (single lamp) 432957-001
Display hinge kit (single lamp) 432963-001
LCD bezel w/ webcam (single lamp) 432955-001
Trained pro's should be able to do this in about 20mins, there is partial lower case disassembly and complete LCD housing dis/re-assembly.
-Sy
Jun 04, 2009 | HP Pavilion dv9000t 17" Notebook Laptop PC
Tightening HP Pavilion DV9000 17'' LCD Hinges
you may find the hinges parts from eBay which is cheaper price:
http://shop.ebay.ca/?_from=R40&_trksid=m38&_nkw=HP+Pavilion+DV9000+hinges&_sacat=See-All-Categories
how to replace your laptop hinges:
1) take out the screws at back of laptop under the hinges base
2) or take out the screw at side of laptop near the hinges base (if you find any screw there)
3) there are two cables connect between LCD lid and laptop base
you do not need disconnect those canbles. just careful them
4) take out all scews on the front of lid cover( the scews is covered by thin plastic cover), then take away front lid cover.
5) take out the screws at beside hinge base and side of LCD panel(2-4 scews at one side), you need check the back of lid cover can separate to LCD panel a little., be care replace only one at one time .
6) put back all screws step by step.
hope help you fix it, please take a rating let me know how much you are helped, thanks! any question please let me know!
May 18, 2009 | HP Pavilion dv6000z Notebook
Where to buy good hp laptop battery?
I would try Ebay....laptop batteries can be very expensive as you've probably noticed. I got one for my Mac very reasonably off Ebay.
Feb 14, 2009 | HP Computers & Internet
HP FE696UA Pavilion DV9922US Entertainment 17? Notebook PC Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
