Question about Brother MFC 7420 All-In-One Laser Printer
Battery problem MFC 7420
How to replace battery, because don't remember hour and date
  • infoel Jan 11, 2008
    helpful but in our case the battery department is COMPLETELY EMPTY :)
  • Brother Master
  • 1,113 Answers
Tis a long way down my friend, I've never had to change one, on any brother printer, but I've never encondered them knowing not the time either. I suggest you take it to the repair agent, or get a manual but for what its worth this is what I know
I've seen the battery when I've had the scanner unit off the base printer, comes off after all covers are removed and all the cables that attach them are disconnected, then theres clips on the sides and two(four?) locking screws on back(front?) from memory. and thats all a task in itself.
Heres the best pic i can find of the left base of your printer engine displaying battery position, hope this helps.
Cheers
Soulvisitor
Posted on Jan 11, 2008
6ya staff
SOURCE:
Brother MFC-7420; "Take Drum out; Slide blue tab..."
go online type in Brother MFC-7420 reset and follow details
Jan 30, 2013 | Brother MFC 7420 All-In-One Laser Printer
Brother mfc 7420 software won't install
First unplug the printer from the computer. Go into the device manager, under system in the control panel. You should see some devices listed as unknown device or it may have the printer name with a yellow exclamation mark by the name. Delete any of these that you see. Leave the printer unplugged and restart the computer. When it boots up reinstall the printer software and don't connect the printer until the software says to. It should go right through the install now.
I hope this helps, if so please rate my solution.
BuddyMc
Feb 10, 2012 | Brother MFC 7420 All-In-One Laser Printer
How do I change date and time on my fax printout?
If there is a power failure, you may have to reset the date and time.
1/ Press menu/set
2/ Enter the last 2 digits of the year. Press menu/set
3/ Enter 2 digits for the month. Press menu/set
(For example press 09 for September, or 10 for October.)
4/ Enter two digits for the day. Press menu/set
5/ Enter the time in 24 Hour format. Press menu/set
6/ Press stop/exit
The LCD now shows the date and time whenever the machine is idle in Fax mode.
Nov 30, 2010 | Brother MFC 7420 All-In-One Laser Printer
My MFC-7420 Printer wont scan
We are having problems on scanning documents with our MFC-7420 Printer to send to email?
Jun 23, 2009 | Brother MFC 7420 All-In-One Laser Printer
Is the Brother MFC 7420 discontinues? If so, what replaces it?
The Brother MFC 7420 is still being sold in major office supply stores. However, there newer version are available as well. The MFC 7440, 7840W, 7820N, 7340, and 7220 are comparable machines
Dec 28, 2008 | Brother MFC 7420 All-In-One Laser Printer
MFC 7420 fail to warm up message
you need to replace the fuser section. in the fuser section u have a heater lamp and a thermister, either of thease could be bad. i would generaly go for the lamp. how ever the lamp can only be purchased through a authorized service center
Dec 14, 2008 | Brother MFC 7420 All-In-One Laser Printer
Toner replacement on Brothers MFC 7420
Open the front cover and try to pull it out strongly.
then use the duster to clean the machine.
then you should able to replace your cartridge easily next time.
mightbe too dirty or you use ODM toner? if yes that's the problem issued from.
Nov 18, 2008 | Brother MFC-7420 Laser Printer
Problem with Brother software.
You need to get the uninstaller from Brother and then re-install most upto date software downloded from Brothers Website. I too had trouble with the software
Jul 14, 2008 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC-7420
I need to down load driver for Brother MFC-7420
Sep 03, 2007 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
159 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
