Question about Northern Tool 10,600 BTU Radiant Kerosene Heater
Extreme kerosene fumes when lighted. Unit not used much-. Not sure how old it is. The wick is $31.99 to replace. I have no guarentee that will solve the problem. Any ideas. I can purchase a new one for $109.
    President:
  • 3,433 Answers
You can pick up a ceramic heater heaper and not have to hassle kerosene, wicks or fumes, and ther last forever
Posted on Nov 20, 2009
RMC-KFA210WH-03 when running causes irritating fumes leading to waterring of eyes, burning chest discomfort
You may be using old kerosene or the tank had sludge in it when you added new fuel. Even the place where you purchased new fuel, may have an unknown problem their storage tank. In addition, if you didn't replace the wick this season, that also could be the culprit. In any event, it's now contaminated.
Frankly, the only real way to know what's happened is to start from scratch. Thoroughly, service the heater by safely emptying the fuel tank and proper disposing of the old fuel. Tank may need to be flushed and of course the wick will have to be replaced. This can be a nasty job, so wear rubber gloves. If you don't want to undertake it yourself, many independent hardware stores offer this service.
And don't forget, you will need to properly dispose of any kerosene you may still have in the storage can. Buy new kerosene from another provider, than the one you last used.
Feb 01, 2011 | Heating & Cooling
Tip
Wick won't light
I didn't realize how quickly condensation can enter the tank. Condensation will ruin the wick permanently, even a brand new wick.
To avoid condensation, do NOT empty the tank unless you are replacing the wick, or some other repair requires it. Likewise, do NOT burn the kerosene out, for the same reason: condensation.
When the tank is filled enough, condensation can still enter but the wick will be able to burn and you won't know the difference. But as soon as the kerosene is gone, all the wick has is water.
STORAGE:  When you burn out the kerosene to store it, condensation can enter and you will not be able to use the wick again. So unless it's necessary, don't burn out the kerosene.
If you have to store the heater in a place that requires the tank to be empty, dissassemble the heater before you use it again and make sure the tank is completely dry and contains no water BEFORE you use it again.
I think but I'm not sure, that the tank must have been designed to let some condensation fall to the sides, or somehow get out of the way. But I'm certain this doesn't last because condensatiion is inevitable and it will accumulate.
on Nov 10, 2008 | Corona 23-DK Compact Heater
WILL NOT START BURNING. REPLACED BATTERIES, GOOD SPARK. CLEANED. NO FIRE
When is the last time you cleaned your wick? A dirty wick will not light, wicks should be soft to the touch look burnt but not hard. Are you burning K1 kerosene? Other grades of kerosene have larger amounts of parafin in them this creates a crusty black hard carbon on the wick making it hard to light and also makes it smell like a semi truck running. I use an old tooth brush and clean the wick, let it set and soak for at least a half hour then try to light. Just a tip if you let your heater burn out every third tank this cleans your wick. Only burn it out in a well ventilated area as this stinks something bad never do this inside. Don't forget let the wick soak for at least a half hour. If your wick is over three years old replace it. Good luck hope this helps!
Dec 10, 2010 | Northern Tool 10,600 BTU Radiant Kerosene...
Where can I find an Owner's manual for an Everglow Kerosene Heater or in structions on how to install the wick and burner.
First you need to get the shell off the unit, and get down to the main burner area. There should be 4 wing nuts holding the wick tower down to the fuel tank. These must be removed, and the wick and the adjuster apparatus removed up and over the top of the center tower. Having a towel or old rag handy to set the unit on when you get it off is a good idea, so you can work on it. Remove the old wick, taking care to see how the fabric band on the cloth wick is positioned on the bottom edge of the wick carrier band. Install the new wick at the same level as the old one on the carrier and set it aside. Make sure you clean the tower, especially all the black carbon buildup around the center and near the top. I use a wire brush on a cordless drill to buff the stuff off, works great. Remove the old kerosene from the tank and clean the tank best you can, then put the new wick inside the carrier, down on the tower, being careful to get the bottom portion of the wick down into the tank area, (it should be quite loose down there once you get the rest of the carrier on the tower. Make sure the whole apparatus sets down evenly and fairly easily on the bottom tank part and screw it down with the four wing nuts. I use a paper cup to pour clear, K1 kerosene onto the new wick all the way around the tower, then make sure it moves easily up and down with the height adjuster knob and while it's in a down position, pour some more kero in on it. You can pour several cups of kero on the new wick and then when it's working up and down well, turn it up and lite it before you put the whole thing all back together. It's best to do this outside as sometimes you can get smoking, if you don't get the flame spreader cage on quickly enough. Once it's on and the flames come up and look good, then turn it off, let it all cool off and you can put it back together. Remember, don't use anything but absolutely clean, clear, K1 Kerosene in the unit and burn it completely dry at least once a week, if you use it a lot. It's called dry burning, and it's a wick cleaning function. If you do this, the wick can last years and years.
Feb 21, 2010 | Grilling
Is it true that if you use moth balls with the fuel in my kerosene heater it burns cleaner & there wont be any build up on the wick? I get alot of soot build up on the wick of my kerosene heater &...
I can't answer about moth balls cleaning the wick but off the top of my head I would not try it as I do not know just what gases your unit would give off. I use kerosene heaters and find that after about 5 tanks of fuel I put on a pair of household rubber gloves, remove the chimney and turn the wick all the way up. Then I roll the wick between my fingers and get the hard carbon off. Once I have the wick clean I use the shop vac to vacuum it all up. I have found that by doing this my wick is never dirty, I do not get any smoke and the wicks last more than 20 years. Probably a better idea than moth balls. Let me know how you make out.
hardrocko
Feb 09, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heater produces bad smell and fumes that make our eyes burn
Hi I hope I can help you with your heater. I own 3 of them. Once you light your heater, give it time to completely light around the ring. Once it does, adjust your burner so the flames are evenly around the ring. Make sure you are using 1K kerosene too. That makes a big difference in the use of your heater. If I can help you any other way please feel free to contact me.
Jan 29, 2009 | Corona 23-DK Compact Heater
Dyna-glo kerosene heater (rmc-55-r7 )
wicks won't light for usually one of 2 reasons. water in the kerosene, which means a new wick and new fuel. or build-up on the wick. check to see if the wick is hard. your wick should be soft. burning out the heater until all fuel is used either by running down all the fuel in the unit or removing the fuel can and lighting to burn off all fuel in the bottom will prevent the wick from getting hard.
Mar 09, 2008 | Heating & Cooling
Dyna glo RMC95C6 kero heater
I suggest you replace the wick and clean the wick feeder assembly. I did not own that model but did have one a number of years ago. The wicks can begin to dry out.
Jan 08, 2008 | Northern Tool 10,600 BTU Radiant Kerosene...
Why am I replacing wicks every 3 weeks
could be you got the flame a little too high so its burning off the top of the wick.
Dec 27, 2007 | Corona 23-DK Compact Heater
Change the wick
You must be very careful and follow the instructions exactly on these wicks. The pins must be inserted into the holes on the wick holder. It is also easy to install the wick holder upside down. Look for a small up arrow on the side.
You must soak your wick for at least 30 minutes, preferably 1 hour. I know it's tempting to light it right away, especially when you are freezing, but you must wait. Wicks work by using capillary action. The fuel must have time to soak in properly.
All wicks are NOT created equal. Buy good ones, under no circumstances should you buy the ones that Walmart sells. They **** and you will be changing it in a day or two. Home depot sells a decent one, but for the really good ones visit Miles Stair wick shop. He also has some good info to deal with condensation and moisture problems.
Also note these heaters will not work if they are dirty. They must be absolutely clean of all dirt and debris, every single part. Especially the parts that come in contact with the wick.
Regular maintenance, good wicks and good fuel will keep these heaters working.
Oct 13, 2007 | Corona 23-DK Compact Heater
Northern Tool 10,600 BTU Radiant Kerosene Heater Logo
176 people viewed this question
Top Northern Tool Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
Are you a Northern Tool Heating and Cooling Expert? Answer questions, earn points and help others
