Question about Westinghouse SK-19H210S Television
I have a sk19h210s westinghouse lcd tv on thepowersupply board location cn204 i have 2 prongs showing does something go there? did i lose something?
  • huggybearhil Nov 19, 2009
    i am the same guy that replaced with a 50v cap. so no it doesnt just noticed the 2 empty prongs when i took it back apart to view the other caps. the rest of caps look fine but do not know how to check
  • 834 Answers
Is the tv working?
Posted on Nov 19, 2009
I recently moved and lost the power cable for ny Westinghouse LCD Flarscreen TV. How can I get a replacement and the cost.
You can get one online for only a few bucks...look at the male plug on the set, there are 3 kinds of plugs used, one is like a computer monitor 3 prong plug, another is a 2 prong round on one side and square on the other and the 3rd is a 3 prong but its rounded on the ends, unfortunatly there are a few models that use a transformer hopefully yours isn't one like that...here is the most common one in Westinghouse....https://www.ebay.com/itm/AC-Power-Cord-Cable-for-Westinghouse-LCD-TV-10-Feet-10Ft-Extra-Long-/172208931835?epid=1970030091&hash=item281873c3fb:g:wb4AAOSwIzNXOfJD
Oct 19, 2017 | Westinghouse Televison & Video
I have a Westinghouse LCD tv and i lost the remote but in trying to run auto scan and it keeps telling me to press enter but I don't know how to
WESTINGHOUSE LCD-TV USER MANUAL Pdf Download.
www.manualslib.com > ... > Flat Panel TV > LCD-T
Westinghouse Digital 27'' Wide-Format LCD - TV User's Manual. ... the analog cable or TV antenna wire (not included) directly to this LCD-TV antenna input. ... a list of video sources using the SOURCE button located on top of the LCD-TV.
images for Westinghouse LCD tv enter button location
Sep 28, 2015 | Westinghouse Televison & Video
On 47-inch Westinghouse monitor, where is the T-con board located?
hi,
There will be a strip wire from the Mother boad to the display section, it will ends in the T Con board. Normaly in lcd monitors the T Con board will be shielded with aluminum sticker foil, in the lower middile section of the monitor.
ok
Jun 21, 2011 | Westinghouse VM47F140S LCD TV
Westinghouse LTV-37w2 loses picture
Hello, you are getting some signs that your inverter boards on this unit are going to go out. By the sounds of the problem you could have a loose cable in the master or the slave inverter, or it is just an indication that one of the two is about to give out with in the near future. You can find these parts by visiting www.shopjimmy.com.
Apr 19, 2010 | Westinghouse LTV-37w2 HDTV
I have a Westinghouse LCD TV that is 1.5 years old. When I turn on the TV the Westinghouse W shows up then the picture will show up for about 3 seconds then go to a black screen. The sound is normal.
I'm willing to bet it's the main board. Its the board that all the video and audio inputs. What is the model number I could find the part for you. You could change it out yourself, Its not that hard. Let me know.
Dec 15, 2009 | Westinghouse W4207 42 in. HD-Ready LCD TV
I have a Westinghouse 26" tv SK-26H730S sometimes the tv doesnt turn on sometimes. seems theres no power. i changed the power cord same results.
Hello, it seems like you need to replace the power board on this unit, you can find the part by sending a request to parts@wde.com, please make sure to include the model#, serial#, and TW#, all located on the back of the unit. You can also ask to have a technician give you a call so he can assist you a bit more on how to go about changing the power board.
Nov 21, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
Westinghouse 32'' LCD TV Static
while you have warranty on the parts you should be getting it to a servicer to get it corrected
do not wait on doing this its not a hazard but it could be a signal board and that could be 300 or better for that part alone so you want to get something done straight away
Oct 27, 2009 | Televison & Video
I have taken my Westinghouse LCD TV, model # SK19H210S,. apart now I need a book for dummies! I am attempting to replace the capacitor.Went to Digikey to try to figure out what part I needed and it gives...
Check the 2200 MFD capacitor on the power supply board. If the top of it is slightly domed up, it is bad. Check the top against the other capacitors on the board to see how the tops look. I got a 16 volt 2200 MFD capacitor at my local Radio Shack. It was in the assorted pack of capacitors 272-802 for $4.95. The package had 3 capacitors this size.
Sep 27, 2009 | Westinghouse SK-19H210S Television
Westinghouse sk19h210s won't power on. service
I just fixed a neighbor's by replacing the 2200MFD capacitor on the power supply board. Thanks for the help, worked great. If you replace it got for a 16V instead of the 10V and hopefully it won't fail that way again.
Just be careful and take notes when you're digging into it. And mark exactly where the card cage is before taking it loose.
Mar 05, 2009 | Westinghouse SK-19H210S Television
Televison & Video Logo
445 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
