Question about Brother MFC 490cw Color Inkjet Multi-Function Printer
Black ink is very faint cleaning not helping. All colors are fine only black. The test print square is scattered but solid in color? it happend with the origonal cartrige that came with it and the new refil one that is smaller in size. it was working fin then i stored it in the closet onit side for about 3 weeks.
    Problem Solver:
  • 6 Answers
Have you tryed to do head cleaning do it about 10 times and look sorry if this dose'nt help.
Posted on Nov 19, 2009
Black ink will not print but colors do
Most likely culprit is a dried up ink within the nozzles themselves. The best things for getting rid of dried ink in the nozzles is to use either a standard bathroom cleaner or rubbing alcohol. With the printer on open the door as if you were replacing ink. With the ink cartidges visable, unplug the printer so they stay put. Remove the cartridge and spray the cleaner in the where the ink is taking from the cartridge and clean it with whatever works. I really really good trick is if you have an old cartridge you can use a syringe to fill up the empty cartridge with your cleaning solution or rubbing alcohol. Insert the cartridge and run some test prints. This will for sure run the cleaner through the nozzle and hopefully dissolve the blockage.
Nov 29, 2011 | HP Photosmart C6180 All-In-One InkJet...
When you change the ink cartraige and clean printer and test the colours the quality of colour is not good on the test! what do you segested i try beacaue the machine has been on its 100th clean and...
    1. Print a Print Quality Check Sheet.
    2. Press the Ink or Ink Management key on the control panel.
    3. Press the up or down arrow key to choose Test Print and press OK.
    4. Press the up or down arrow key to choose Print Quality and press OK.
    5. Press Color (Colour) start. The machine begins printing the Print Quality Check Sheet.
    1. Closely examine the Print Quality Check Sheet. Each of the four colors is represented by a slanted square pattern made up of individual blocks. The colors should appear in the following order from left to right: Black - Yellow - Cyan - Magenta.
    2. Compare the print quality of the Check Sheet you just printed with the three examples listed below:
      (A) One or more complete blocks of colors are missing:
      (B) Most of the short diagonal lines are missing from one or more color blocks:
      (C)Some parts of the short diagonal lines are missing from one or more color blocks:
    3. The display will then ask you if the print quality is OK for black. Press the down arrow key or 2 or "-" to choose No for black with the problem.
    4. The display will then ask you if the print quality is OK for Color. Press the down arrow key or 2 or "-" to choose No for color with the problem.
    5. The display will then show Start Cleaning? Yes No.
      Press the up arrow key or 1 or "+" to choose Yes and the machine will start cleaning the color ink cartridges.
    6. When the machine completes cleaning the print head, press Color(Colour) Start. Another Print Quality Check Sheet will print.
    7. Repeat the cleaning and the quality check process following the Step 4-7.
    Jun 02, 2011 | Brother MFC 6490CW InkJet Printer
    My printer is not working properly. On the test page, not every line prints clearly.....faint and grey compared to other lines. Lines 1, 4, 8, ll, 14, etc. prints very light compared to the other lines. ...
    sounds like your heads are all gummed up with dried ink.Is this a older printer or previously used if so run the cleaner that should have come with your printer software. keep running it until clean or bring it to get cleaned.
    Feb 22, 2011 | Computers & Internet
    Canon iP90 only prints blank pages
    Did you try to wipe the cartridge.Maybe there's a clogs. inside.
    May 28, 2009 | Canon PIXMA iP90 InkJet Printer
    Lexmark z715. paper comes thru with no ink in it. cartridge is full and appears to be installed oorrectly..please help
    You may clean the cartridge by following the steps given below:
    1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "All Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
    2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
    The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
    If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
    1. Please open the "Solution center" again and go to the "Maintenance" Tab.
    2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
    3. Get a damp paper towel.
    4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
    5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
    6. Next dab the cartridge on the towel to make sure that the ink is flowing.
    7. Snap the cartridges back into the printer.
    8. On your computer, select "Old Cartridge install."
    9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
    Next, try this printer self-test by following the steps given below:
    1. Turn the power to the printer "off."
    2. Press and hold the "Paper Feed" button.
    3. Press the "Power" button once while continuing to hold the "Paper Feed" button.
    4. Keep holding the "Paper Feed" button until one sheet is cycled through.
    5. The test is continuous.
    The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
    If the self-test prints, but has lines or smudges or other print quality issues, let us know.
    May 05, 2009 | Lexmark Z715 InkJet Printer
    Very Faint Printouts
    I find the best way to clean the heads is buy some cleaning cartridges as they have cleaning fluid in them and use them to clean it will take about 10 or more times to clean the heads then put the color ones back in and try again.
    Just keep putting it on clean the head don't do a print out till at lest you have cleaned 10 or more times.
    Rgs
    The StickMan
    Dec 08, 2008 | Epson RX620 All-In-One InkJet Photo...
    Printer is not printing color only black and thats real faint. have cleaned printer heads and still no different. uninstalled printer and reinstalled still no change
    Greetings!
    Removed the colored ink cartridge, press the colored output (where the colored ink came out) to a tissue to test if the there is an ink inside the cartridge, if there is none appears the cartridge is now damage, have a new one.
    Thanks
    Nov 10, 2008 | Epson Stylus CX4800 All-In-One InkJet...
    Won't print except really faint color
    Finally - continued to do further print head cleaning (about 6 times, included 2nd level) and finally started printing black again.
    Aug 23, 2008 | HP Photosmart 8250 InkJet Printer
    Yellow Prints in the other colors
    Problem seems to be with your Ink Tank(s) or Printing Head. Replace both of them one by one and retry.
    Jun 06, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
    C88 / T060 cartridge refilling problem
    sounds lke your yellow nozzle not working properly...had same issue on lexmark printer, ended up geting this epson...learnt from my mistakes...perhaps it ran dry? or you left the yellow cartridge out longer than the rest....only you might know what happened
    Mar 22, 2008 | Epson Stylus C88 InkJet Photo Printer
    Brother MFC 490cw Color Inkjet Multi-Function Printer Logo
    143 people viewed this question
    CheckitRight
    CheckitRight
    James Cagle
    James Cagle
    Samyfam
    Samyfam
