Question about Acer Aspire One AOA150-1570 Notebook PC
Touchpad on Acer Aspire One Linux not working
I have an Acer Aspire One running on Linux and the touchpad has stopped working. I have an external mouse that I can use and I've tried using the recovery CD, but that doesn't fix it. Gsynaptics still doesn't work and the touchpad is still dead. How do I fix this?
  • zencadet Nov 19, 2009
    Should have noted that Fn + F7 (touchpad un/lock) does not fix anything.
SOURCE: acer aspire 5100 model bl51
u guys need the drivers for it, takes to secs to find not that hard
Posted on Jul 18, 2008
Pyrhyc
  • 2028 Answers
SOURCE: Dell Inspiron 6000 Alps Touchpad not working
Try unistalling the touchpad driver, and reboot. The machine will find the touchpad and reinstall the driver automatically. These have a tenancy to glitch when using an external mouse, and this should clear it up. Let me know.
Posted on Aug 28, 2008
  • 461 Answers
SOURCE: Dell Latitude D630 Touchpad/Pointer
Do not check the check box as leaving the touchpad enabled while using an external mouse will not cause any harm.
Posted on Dec 12, 2008
davepcrepair
  • 75 Answers
SOURCE: Acer aspire one touchpad right button not working
you can try using the function key ( fn ) and the touch pad key on my acer it is the F7 key hold the fn key and press and release the touch pad key that will turn the touch pad mouse off and on also goto control panel / mouse and try switch primary and secondary see if that will make the right button work if not its probly hardware related and your best bet is to keep the external mouse going rather than fixing that one
Posted on Mar 24, 2009
Push28
  • 102 Answers
SOURCE: EEE touchpad doesn't work until external mouse connected
try fn key + f7
Posted on Jul 08, 2009
Touch screen not working
The touchpad on the Acer Aspire is built into the notebook itself, which makes the device much harder to troubleshoot or replace. While you can connect a universal serial bus mouse to the notebook if the touchpad becomes unresponsive, attaching any external device reduces the notebook's portability. Although hardware failure can cause the touchpad to stop working, most device-related problems are due to software settings or other conflicts.
Hardware Conflict
Peripheral devices connected to the Aspire can interfere with the integrated touchpad. Disconnect all of the external devices, except for the power adapter, that are connected to the Aspire; then restart the computer. Test the touchpad after booting into Windows. If the touchpad responds, a hardware device is interfering with the pointing device. Reconnect each device one by one to the notebook, testing the touchpad throughout. If the pointing device stops responding after connecting a particular device, the component is interfering with the touchpad. Go to the device manufacturer's website and look up the product model. Check the bulletin board to see if the manufacturer has posted a notice or update addressing issues with device conflicts. If no such update is available, download the latest driver for the component and install it on the computer. b> Disabled Touchpad b> The Acer Aspire 5516 comes with a preset group of keyboard combinations, called hotkeys, that are used to enable or disable devices, configure sound volume and screen brightness, and control the notebook mode. The hotkeys "Fn" and "F7" turn the touchpad on and off. If the integrated mouse is unresponsive, hold down "Fn" and press "F7"; then test the touchpad to see if the device reactivates. If the touchpad still doesn't work, open Device Manager from within the Control Panel. Expand "Mice and Other Pointing Devices," then right-click the touchpad device. If the touchpad is disabled in Device Manager, you'll see the "Enable" option in the context menu. Click it to turn the touchpad back on; then restart the computer. Corrupt Driver b> Windows Vista talks to the touchpad through a program called a device driver. The driver enables Windows Vista to "see" the touchpad and send it instructions. Once the driver communicates these instructions to the touchpad, the touchpad informs the processor that it needs to perform a task, and a specific set of code is performed. If the driver for the touchpad is outdated or corrupt, or if the driver isn't compatible with the OS -- Acer offers touchpad drivers for Windows XP and Windows 7, but these drivers won't work with Windows Vista -- the touchpad becomes unresponsive. Expand the "Mouse and Other Pointing Devices" section from within Device Manager; if Windows detects a problem with the driver, it places a yellow exclamation point or red "X" next to the device. Double-click the touchpad driver to see the error message; then look up the message on the Microsoft Support website for further assistance. b> Touchpad Settings b> Mouse Properties, accessed through the Control Panel, contains several different configuration settings that can alter how the touchpad behaves on the Aspire 5516. On the "Device Settings" tab is the option "Disable Internal Pointing Device When External USB Pointing Device Is Attached." As the option states, if an external mouse is connected to the Aspire 5516, the touchpad will stop working; disable this option if you're using an external pointing device. Clicking the "Settings" button opens the "Properties for Synaptics Touchpad" window. On this screen are the "PalmCheck" and "Touch Sensitivity" options. If PalmCheck is set too high, or Touch Sensitivity too low, the touchpad won't respond to normal touch, making the device seem unresponsive. Hope this helps.
b>
Dec 31, 2012 | Acer Aspire Z3801 All-In-One Desktop Pc...
Acer laptop Aspire 5732Z touchpad not working...have been using mouse all along and touchpad was working now it isnt...did the fn f7 no help...checked the device manager all seems fine...tried to update...
I have the solution...
u see where the switch on button is ? next to it there are two buttons ...ones for stopping internet connection ...thats the one on the right. the one on the left is the one for locking the touchpad
if that button has a orange light blinking on it it means its locked ..
so just push the button and see if it works :) .
Jul 19, 2010 | Acer Aspire 5500 5570-2609 Laptop
Emachine E725 touchpad does not work
The eMachines E725 has a built in switch to toggle the touchpad on or off by the touch of a button. Look at the button to the left of the main power switch. You'll notice the icon looks like a hand touching a rectangle - or touchpad. if this button is lit up, the touchpad is turned off. simply press the button to toggle the touchpad back on. The light on the button should now be off.
It's that simple. I hope this helps.
Apr 14, 2010 | Acer Aspire 3000 Notebook
Dead keyboard and touchpad at login prompt
Try downloading ubuntu linux live cd. You can boot directly into linux without installing it. See if your keyboard and touchpad work in there. If not then it is a hardware problem. If it does work you may want to consider backing up your files and reinstalling windows.
Dec 04, 2009 | Acer Aspire 3050-1733 Notebook
Touch pad won't work on Aspire 5515.
If the touchpad has gone bad there's not much you can do, unless it just happens to have a loose connection. You can try disassembling the keyboard to get access to the touchpad cable and verify it but to be honest, that's an unlikely scenario.
Can you plugin a usb mouse? Or you could try an external touchpad like the Bamboo made by Wacom although that's a bit expensive. Again, it would need a usb connection though.
Oct 12, 2009 | Acer Aspire 5500 5570-2609 Laptop
Touchpad stopped working on my Acer Aspire 4730Z. What do I do?
Check the Acer site and download the latest driver for your touchpad. If you recently added a USB mouse check your settings and make sure that the mouse did not turn off your touchpad. That should take care of your problem.
Jul 26, 2009 | Computers & Internet
Can move the mouse but not clikc with the touchpad
if you installed an external mouse, it would over-ride the touchpad.
try removing the external mouse, and tap the touchpad twice as if you were double clicking it.
also you could try re-installing the touchpad device driver, usually synoptics or similar.
Mike @ compurepair.
Jun 11, 2009 | Acer Aspire 5610-4648 Notebook
Acer Extesa 6601 Keypad & Touchpad Problem
you need the drivers for the touchpad and keyboard, click on the drivers and utilities section, then allow active x when the pop up appears
http://support.acer-euro.com/drivers/notebook/ex_6600.html
Aug 23, 2008 | Acer Aspire 5100-5022 Notebook
Acer aspire 5610 touchpad stopped working
On my acer it is the fn and f7 button pushed together.. that turns the touchpad on and off
Nov 20, 2007 | Acer Aspire 5610-4648 Notebook
Open Questions:
See all Acer Aspire One AOA150-1570 Notebook PC Questions
Acer Aspire One AOA150-1570 Notebook PC Logo
895 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
