Question about SanDisk Sansa e200 MP3 Player
Sansa mp3 stop working after fall to ground
Hi !
 I have sansa mp3 player .It stops working after i had fall it to ground 2 times within 2 second . Pc detect drives but they can't open . When I check properties of both drives,they both are blanks and there is no space at all .It means no free space and no used space . What should I do to repair it ? What is problem ? Will I have to format it ? how ?
    Please suggest me solution .
  • 35 Answers
You cannot reformat a drive that is not recognize by your system. The drives are loosed, that's why it says " 0 bytes free, 0 bytes used. Bring it a service center to have its drive fixed.
A Simple Thank you is Good Enough
Posted on Feb 15, 2008
I was listening to my sandisk sansa mp3 player and it stopped working what to do wont turn on nothing
Try and reset.
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Part 2 - Make sure the player is fully charged.
1. Connect the player to the PC.
2. Make sure the computer detects the player.
NOTE: This part is important:, switch the player to MSC mode, then connect it to the PC.  3. Leave the player connected for approximately 2 hours to charge.
4. Disconnect the player from the PC.  5. Verify if you can turn on the player.  6. Reset the player if necessary one more time.
Jan 08, 2010 | SanDisk Sansa Clip MP3 Player
Sansa e250 won't connect
1.try formatting your sansa
2.try to copy again..
3.if it does not work tell me what sansa you are using
May 23, 2009 | SanDisk Sansa e260 MP3 Player
I was downloading music on my Sansa MP3 player and it stopped working, I can't get it to power back on?
Hi guys. I had the same problem. My Sansa clip would not come on at all and when I connected it to my computer, an malfunction error came up.
I found the solution on another forum which suggested sliding and holding the power button for about 15 seconds. This should reset the player. Try to turn it on again. It should work! It worked for me and all my music remained. Goodluck!
Jan 26, 2009 | SanDisk Sansa Clip MP3 Player
My sansa mp3 player wot turn on
Actually there's none so think about buying a new charger and if it's not working then re-write to me so that I can help you more.
Sep 18, 2008 | SanDisk Sansa Clip MP3 Player
I have a sansa sandisk mp3 player. when i bought it it was working excellent.but all of a sudden it stopped working.this mp3 has no reset button i do not know how to fix the problem. sansa sandisk...
1. Are you able to turn it on ?
If so, press the the "power on" button the second time to activate the menu.
Still no luck ! Try putting in a new battery and try again.
2. You cannot "reset" anything.
3. Open up "windows explorer"
4. Scroll down the left pane of the window till you see the "sansa" removable disk
5. Right click it and select "format"
6. After formatting, try adding your files back again.
7. Use the >= button on the player tp play the songs.
Hope this has been helpful to you.
Aug 29, 2008 | SanDisk Sansa m240 MP3 Player
Help me
I have a connected message when was disconected from the computer. I tried to shut it down but does not work.
Jul 31, 2008 | SanDisk Sansa MP3 Player
A problem with my sansa shaker
Hi again audreytagle. Please take your slip and take your sansa to the place you bought it and show them the problem they will probably give you a new one. before you do that try inserting new batteries into the sansa shaker and see if the product works. if not use the above mentioned solution.
Jul 30, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
Sansa media converter 2.0
Try reseting the player
To reset your Sansa, slide and hold the power button for 20 seconds.
If you need more asistance, let me know. Good luck.
Mar 27, 2008 | SanDisk Sansa e260 MP3 Player
Cannot fix MP3 player
Press and Hold The power button for 30 seconds.
Nov 07, 2007 | SanDisk Sansa e250 MP3 Player
Try a hard reset. Press and hold vol + and center select button for 20 seconds. Best of Luck.
Sep 30, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa e200 MP3 Player Logo
52 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
