Question about Braun 8585 Electric Shaver
The cleaning station for my 8995 goes through the motions of cleaning but the bristles are no longer flushed into the fluid reservoir as they used to - they remain inside the shaver and also in the cleaning trough. There seems to be a blockage - how do I clear this?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 65 Answers
You can make sure you have a nearly empty old cart in your shaver cleaner base, and then run some rubbing alchol into shaver or even some mixed with some soap to help break down the oils in the stubble crud. If you can put some also in a spray bottle and use it to clean with a little force, that will help some.
Posted on Dec 04, 2009
Bought Braun 790cc shaver. Came with the cleaning station.The cleaning station doesn't dry the shaver. Can i fix the problem myself or i have to take it to a service centre?
Doesn't it clean with an alcohol type solution? Once cleaning has finished and is no longer being pumped through the head, by the time your next shave is due the following day the residue will have evaporated from the shaving head
May 24, 2015 | Braun Health & Beauty
22:10 printer error
22:10 service station shutdown code
there is a cleaning wheel inside the service station which gets clogged up with dried ink, after a period of use the srvice station will gradually come to a stop and the motor will no longer be able to drive , thus throwing a 22:10 error
to repair - 1) order a new service station C7769-60374 and have it fitted - not forgetting the service staion calibration before using.
2) remove the current service station and strip and clear all waste ink- wash thoroughly and allow to dry- then refit, apply a thin layer if 3 in1 oil to the contact surface of the service station wheel. replace the unit and perform all service station calibrations,
if you would like a engineer for this job please call Belmonte on 0161 480 5556- we offer national uk cover and service plans as well as trade in's, trade up's and new sales.
Nov 26, 2013 | HP DesignJet 500ps InkJet Printer
Braun series 7 cleaning station has red lights even after I replaced the cleaning solution
When the razor is not regularly cleaned in the cleaning station and the hygiene indicator goes low, the cleaning station may lose its ability to sense the fluid level. I almost sent the cleaning station in for repair (mine is out of warranty) but was able to clear the faulty condition by resetting the razor's cutter replacement (holding the small recessed reset button below "Braun" logo on the razor) and unplugging/replugging the station then attempting a cleaning until it performed one completely successful cleaning cycle. After that the fluid level showed full. I also heard that the drain hole in the "cup" where the razor sits can get clogged - not sure what happens then but you want to keep that clean.
Update 2/2018: If you mix your own formula as others note, it is important to include some tap water for electrical conductivity for the fluid sensor to work.
Sep 15, 2013 | Braun 8585 Electric Shaver
I have a wweather station model no. CE0681The outdoor control no longer tranmits infromation on tempereture to the inside weather station. How do I solve this problem?
There are a couple of reasons that this can happen. First try replacing the batteries in the outdoor control. Also replace the batteries in the base (inside unit).
You may also need to resynch the two units. (For some models, this requires bringing the outdoor unit inside and removing the batteries. Then add the batteries and let the base station look for the outdoor unit.) With the Davis instruments weather station with the solar powered unit, clean the solar panel. You may need to replace the rechargeable battery.
Sometimes, lightning strikes near the weather station external unit causes a surge that damages the unit. In that case, the entire board may need to be replaced to fix the problem.
Please add a comment with the manufacturer for additional information.
I hope this helps.
Mar 18, 2013 | Measuring Tools & Sensors
Braun 8995 - YELLOW LIGHT STAYS ON!
I experienced the same symptoms on my 8995; solid yellow light (even though the cartridge was full), cleaning failed (red light on) after pressing either start button. After many failed attempts to clean the razor, unplugging the station and pushing start button, I decided to clean the razor under running water. I rinsed the razor under water and then turned it on allowing it to run in a pool of water (like it would in the station). After water cleaning, I returned the razor to the station, pressed the start button and it worked! Was able to do both the quick clean and auto clean.
Jan 06, 2013 | Braun 8995 Electric Shaver
21.13
For tech guys only :Open right side door, check any obstruction in service station while moving.Check service station connection, re-fix once again.. checkRemove service station, remove motors, clean entire service station with water, ensure that entire ink should be washed out allow it for dry, apply grease to the moving parts, fix it back, check...( cleaning service station is very dirty work be prepare for that). check.. Replace service station...
Dec 02, 2010 | HP Designjet T1100ps Printer
Brew station is extremely slow, suspect it needs cleaning.
You can run a cup of vinegar through the machine. Run it just as you would making coffee, except without the coffee. Run water through the cycle at least twice to remove sediment and the vinegar. Works like a charm.
Jun 16, 2010 | Hamilton Beach BrewStation Deluxe 47474...
Hi my play station is starting to not to load games
keep an restarting the console and clean the disc
Feb 16, 2010 | Sony PlayStation 2 (PS2) Console
Poor print quality -vertical lines in the print. cartridges replaced
you could try cleaning the print heads through the printer utility.
Also a little alcohol on a cotton bud to clean the print rollers could help but allow time for it to evaporate and dry before printing.
Feb 14, 2010 | HP DeskJet 920c InkJet Printer
USB port on docking station does not work
Power. You may find that the ower managment settings need to be changed or an external supply is needed.
May 28, 2009 | Motion Computing LE1600 Tablet PC
Braun 8585 Electric Shaver Logo
347 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
