Question about SanDisk Sansa c140 MP3 Player
Sansa c140 is not turning on
My mp3 player is not recognized by the pc and it is not turning on showing only black screen tried firmware also but its showing process fail, its shows fail to write data.
My brother had the same problem with the e250r after dropping it (do not know if u did) i opened it and fiddled with the wires and it popped to life just fiddle with the guts ans it should come rite back to life if ur looking for a quick fix.
Posted on Jan 24, 2008
My pc does not recognize my sansa at all whan i hook it up what do i do?
My MP3 Player is not responding and connect to my PC. Model c140.
Jun 15, 2009 | SanDisk Sansa c140 MP3 Player
Problem in C140 SANDISK
I am from India too ;)
Updating the firmware will return your device to factory setting, like new. It should work normally after that.
Download this file:
http://www.sendspace.com/file/0mc3km
This is the firmware update utility for Sanca c140 (c100 series) devices.
There is a howto.txt file included, follow the instructions.I am posting the instructions here for convenience.
1. Download the attached file and save it on the desktop.
(the player should not be attached to the computer at this point)
2. Double click the file to run it.
3. Accept the license agreement.
4. Remove the battery from the mp3 player.
5. Press and hold the center (select) button and connect it to the computer (keep holding the button, this is the firmware update mode).
6. If the New Hardware Wizard appears (now you can let go of the select button), do the following: (if asked, choose not to connect to the internet for updates), then choose to install the device automatically, then follow the prompts to finish the installation.
7. When the wizard comes up, or when the Update button becomes active (whichever happens first), you may release the select button.
8. Click the Update button, and then click OK to the message that comes up.
9. Wait until the upgrade finishes, then unplug the device.
10. Put the battery back in, and turn on the player.
11. Hopefully the update will be performed, then choose English for the language when prompted.
12. Check if the issue is resolved.
Jun 18, 2008 | SanDisk Sansa c140 MP3 Player
It won't turn on
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 16, 2008 | SanDisk Sansa c140 MP3 Player
SanDisk Sansa c140 MP3 stuck at one song - please help!!
You might have to hold the power button down for like 20-25 seconds and if that doesnt work what I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Apr 07, 2008 | SanDisk Sansa c140 MP3 Player
SANSA c140 not sychronizing
Reformat
-Tha Mp3 Doctor
Apr 05, 2008 | SanDisk Sansa c140 MP3 Player
Not able o view the contents
-Tha Mp3 Doctor
Mar 09, 2008 | SanDisk Sansa c140 MP3 Player
SanDisk sansa c140
You need to Have Windows XP / SP2, Wndows Media Player 10 or higher in order for the device to be recognized. If you have these components, try changing the mode on the device to MSC Mode. Settings>Mode>MSC. Best of Luck.
Sep 11, 2007 | SanDisk Sansa c140 MP3 Player
Sansa c140 won't turn on
Try to connect your Sansa c140 to another PC. If it continued to show that it isn't recognized then I'm sorry to tell you that your Sansa ROM has malfunctioned. Only people at Sandisk could fix it.
Jun 02, 2007 | SanDisk Sansa c140 MP3 Player
Fixing my C140 (has no lettering on screen)
For Sansa or Sandisk problems, contact http://www.sansacommunity.com/ This site is dedicated to Sandisk products and can help you. Good Luck
Jun 01, 2007 | SanDisk Sansa c140 MP3 Player
SanDisk Sansa c140 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
