Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
How to wire oil furnice protector relay
How to wire oil furnace protector relay for rheem
  • 308 Answers
3 Wire protectorelay
Black - Power in; White - all neutrals; Orange - Motor and igniter.
4 Wire - Igniter goes to Blue, all else the same
5 or more - Same as 4 wire and
Red - Always "hot"
Violet - Oil delay valve
Pink - Nozzle line heater
Hope this helps
Posted on Nov 19, 2009
FURNACE WILL NOT CUT OFF WITH THERMO PULL BRAKER THEN REINSERT BRAKER FURNICE WILL STAY OFF UNTIL THE THERMO IS RESET SAME THING HAPPENS AGAIN .WHAT PART IS BAD
If you have a programmable thermostat do the batteries need replacing? Test and re-insert. While there check for any loose wires on it, or at the furnace circuit board. Also make sure none of the wires are touching and metal parts and getting chaffed or shorted. If they are the shot will keep the unit from shutting off and/or cause short cycling.
Mar 01, 2015 | Intertherm 56000 Btu Gas Furnace
I have Carrier 38TKB036 3 ton A/C condensing unit and one 28CCA036 3 ton A-coil to provide A/C to home thru existing furnice. A/C was on and stopped working. Turned off/on, but will not come on. Any...
Is the furnace fan (indoor fan ) running. If not the problem is with the inside unit. It supplies the control power to operate the entire system and has a control fuse on the circuit board. If it is running but not the outside unit then the problem is outside.
Aug 08, 2011 | Carrier 38CKC042 Air Conditioner
Rheem RBHC-17J14SFA elec furnace fan won't stop
sonds like u have a bad safety switch they r round and have 2 wires on them usually and u can check them by taking the wires off of them and checking continuity thru them there might be one on the blower housing also either that or ur blower relay may be bad and stuck closed
Feb 18, 2010 | Heating & Cooling
My Rheem oil furnace is coupled with Rhuud heat pump. Oil furnace runs on emergency mode only and heat pump doesn't work at all!! Now the oil furnace will not even fire up even on emode.
Try and jump it out by taking the wire hooked to R and W terminals on your thermostat and connecting them. It could be you have a bad thermostat.
Feb 11, 2010 | Ruud UBHC Air Conditioner
RHEEM OIL FURNACE MODEL ROBD 067 LBEA BLOWER
You will likely need to install an isolation relay in the W circuit from the thermostat. Some thermostats rob a small current through the W circuit to power the thermostat. This small current can be enough to start the fan circuit timer. You can test this by disconnecting W at the furnace and allowing the timer to shut down. If the fan shuts off with the W disconnected you can install a simple relay.
The relay coil will be connected to Common on one side and the W from the thermostat to the other. Then you will run a wire from R on the furnace to the relay and from the N.O. Contacts to the W terminal on the furnace. This will kill that signal that is starting the timer and the W can steal it's power through the coil back to common.
Dec 23, 2009 | Honeywell Electronic Programmable...
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
24v wiring for RHEEM heat pump
Brown wire connect to com C on terminal block in your furnance (0VAC from 24VAC transformer)
Yellow turn on compresor (hot wire from 24VAC Transfrormer)
Blue switch Valve from AC to Heat (hot wire from 24VAC Transfrormer)
Purple prevent starting compressor in Heat pump and furnace in same time
Jul 02, 2009 | Ruud UBHC Air Conditioner
1970's Rheem electric furnace
no the older rheems had a sequencer for the heat that turned on the blower at the same time that the heat strios are energized. so the first thing that you need to do is figure out the sequencer that is keeping the fan running and get it replaced.
Jan 30, 2009 | Honeywell CT3200 5-2 Day Electronic...
I have a ruud oil forced air furnace, but the model # says it is a Rheem ROBC-130. My problem is that the blower motor runs all the time, the furnace will fire and run for about a minute then shut off it...
this is more than a fan control relay . it is a black relay that will appear to have several wires connected to it but those wires connect to the base ,it unplugs , if it is set up for ac it might have 2 relays one toward the front one toward the rear replace the front one first ,,, if on good replace one @ rear should fix if not let me know
Dec 27, 2008 | Water Heaters
FAN WILL NOT COME ON WITH THE FURNICE.
switch t-stat to on, for quick solution...still got problem with relay or something
Dec 08, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
298 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
