Question about Kenmore 22422 Top Load Washer
It processes most the load then it reads LD on the display. I just moved in Sat. and this is the type 580 kenmore elite oasis he. I tried it Sat. and it worked. I cannot find the manual online for the model 110.27062603
  • 15,935 Answers
"F21" (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump...
If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here's the information you need to check the drain pump:
Symptom: PUMP IS RUNNING, BUT NOT DRAINING PROPERLY.
1. Unplug the washer while servicing inside the unit.
2. Remove the Cabinet....
Disconnect your Kenmore Oasis washing machine from its power source. Make sure that your washer is unplugged before beginning to disassemble it.
Remove the screws that hold the control console to the top of your Oasis washer. In some Kenmore Oasis models, the two screws may be covered by plastic end caps. After removing the screws, set them aside until you are ready to replace them.
Flip the console up, back and out of the way.
Locate the cabinet clips on the top of your Kenmore Oasis washer. These clips are located toward the back of the washer top and would be hidden by the console if it were not currently flipped up.
5
Slide your screwdriver underneath the metal cabinet clips. Wiggle the screwdriver back and forth to gently pry the cabinet clips free.
6
Disconnect the group of colored wires that plug into the top of the washer from the control console. These wires control the lid switch on your Kenmore washing machine. To disconnect, grasp the white plastic clip and pull gently.
7
Remove the washing machine cabinet. Tilt the cabinet towards you, and then lift the entire cabinet up and off of its platform.
3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here's a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don't own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there's nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT - DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select the following on the operator console - DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). "C00" will show on the console display as the washer begins diagnostics mode.
10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
How do I unclog the long drain Kenmore elite oasis?
Honestly, we got rid of the machine and bought a Maytag Neptune. I was over trying to figure out all the codes the Oasis was flashing. We gave up on the first one that started having problems when a friend gave us one identical to ours and it has done a lot of the same things.
Apr 03, 2014 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite oasis top load error code Ld
Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 02, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have an kenmore elite oasis he and the washer has a code - LD. If i try to stop and start it, it just hums.
The LD means Long drain time...that error code coupled with the hum i believe something is stuck in the drain pump preventing it from turning and that is why its humming
GENE
Aug 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
I have a kenmore elite oasis washing machine, type 580. when starting cycle it stops with code F 50. Any suggestions?
It's telling you that it did not detect motor movement. This could be failed motor control or something else. It is probably an RPS or the maching/motor control board but there are a few other things that it could be. Not an easy problem for DIY.
Jun 07, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Ld error
Ld - Long drain - Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display.
Good Luck!!
Thanks
Jun 23, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Washing Machine LD Fault
mpratt, check to make sure there is no restriction in your pressure switch tube.it could also be kinked.
Oct 22, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Need diagnostic test for Kenmore Elite Oasis HE top load washer it is making beeping noises and has a mind of its own
pick any button but power or pause (spin works ok) pres and hold 3 sec release 3 sec hold 3 sec release 3 sec hold 3 sec this will put intio diagnostics usually if a fault code is stored this will show first press same button to step through post fault code if any asap and will try to help may to try several times to get into diagnostics
Jun 21, 2008 | Washing Machines
Kenmore 22422 Top Load Washer Logo
48 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
