Toshiba Satellite A205-S5812 Notebook Logo
Posted on Nov 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
A205-s5814 built in SD reader feature
My a205-s5814 Toshiba laptop has a plastic cover over the opening where an SD reader normally would be. Is it possible to add this feature on? I'm not sure what is behind the cover.
Chris
Level 2:
New Friend:
  • Expert 111 Answers
  • Posted on Nov 20, 2009
Chris
Expert
Level 2:
New Friend:
Answers
111
Questions
Helped
23669
Points
247
You should be able to add this feature if the manufacturer has left a spot for it.
Thanks
Cbz123
Toshiba satellite CD door will not open
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
2helpful
Replace cmos battery
Wow that's a bummer if it is soldered to the motherboard. Sounds like you will have to desolder the old one and resolder a new one. Good Luck
There's a slot for an SD card but there's nothing to connect the sd card to the computer
You insert the SD card into the slot. There should be nothing to connect. Usually there is a placeholder in the slot, and just push it in, and it will pop out.
3helpful
Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Finger print sensor not working with vista in toshiba M200
here is the link :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2211892&rpn=PSMC4U&modelFilter=M205-SP3018&selCategory=3&selFamily=1073768667&selModel=2211892|PSMC4U
Satellite A200-ST2041, A200-ST2043, A200-ST2042, A205-S4617, A205-S4618, A205-S4639, A205-S4638, A205-S4537, A205-S4557, A205-S5816, A205-S5814, A205-S5813, A205-S5812, A205-S5811, A205-S5810, A205-S5809, A205-S5806, A205-S5805, A205-S5851, A205-S5847, A205-S5843, A205-S5841, A205-S5835, A205-S5831, A205-S5825, A205-S6810, A205-S5823, A205-S5804, A205-S5803, A205-S5801, A205-S5800, A205-S7468, A205-S7466, A205-S7464, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S5863, A205-S5859, A205-S5855, A205-S5853, A205-S5852, A205-S6812, A205-S6808, A205-S5821, A205-S5819, A205-SP5822, A205-SP5821, A205-SP5820, A205-SP5818, A205-SP5817, A205-SP5816, A205-S5000, A205-S5866, A205-S5879, A205-S5878, A205-S5872, A205-S5871, A205-S5867, A205-S5880, A205-S5861, A205-S5833, A205-S5864, A205-S4629, A205-S4607, A205-S4597, A205-S4578, A205-S4587, A205-S4577, A205-S4567, A215-S4697, A215-SP5811, A215-SP5810, A215-S48171, A215-S4817, A215-S4807, A215-S4767, A215-S4757, A215-S4747, A215-S4717, A215-S4737, A215-S5839, A215-S5848, A215-S5837, A215-S5829, A215-S5828, A215-S5827, A215-S6820, A215-S6816, A215-S7472, M110-ST1161, M115-S3094, M115-S3104, M115-S3154, M115-S3144, M200-ST2001, M200-ST2002, M205-S3207, M205-S4804, M205-S4805, M205-S4806, M205-S7453, M205-S3217,
Seaching for audio driver for toshiba Satellite A205-S5814
Once in a blue moon, the driver that works in Vista will work in XP. Try a forced install. You can also Google the model of the sound card (motherboard if the sound is integrated) and see if there is a XP driver that way. Good luck.
Toshiba a205-s5814 Wireless driver for VISTA
there are 7 different WiFi drivers for this model, you find them here:
I hope you will find yours.
Happy New Year /Teise655beb.png
I have a toshiba a205-s5814 and a s5831. the laptop comes on but neither screen comes on.
Dear Muttt,
is any kind of beep is also coming from laptop? if not, then please contact to any authorised service provider of Toshiba.
Be Happy Always
Regards
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
