Question about Microwave Ovens
Some of the keypad numbers are not working. you can get them to work sometimes if you slam the door to the microwave
  • bnsf479 Nov 19, 2009
    Galaxy Micro wave, model number 721.80009401
  • 541 Answers
You need a new keypad. The keypads have tiny little traces that, over time, start lossing connection. Slaming the door causes them to make contact. There is not much more you can do. Let me know what the model number and brand is. Thanks for using fixya.
Posted on Nov 19, 2009
  • Rusty Campbell Nov 19, 2009
    Go to http://www.repairclinic.com/Home.aspx and put in you model number. I saw that they have 2 circuit boards for this model but one did not have a picture. You may have to call them to find out if they have the keypad or if it is even available. Other than that you can probably find it at Sears. I hope this helps. Thanks
Keypad works but turntable and fan do not. any ideas? Kenmore Microwave 405.72123310
This is likely a problem with the upper or lower door switch or its mount is loose, misaligned, or broken.
This is usually caused by opening the door while it's cooking (instead of hitting "stop" first) or slamming the door.
See my help file on door switches here.
More questions? Contact me directly here.*
* always include the full model number and FCC ID number from the label on / in your microwave (or a clear photo of the tag)
Jan 27, 2018 | Kenmore Microwave Ovens
Keypad Problems
Sometimes a keypad may not work because the door switches are faulty. When the door switches are working correctly it will allow the keypad to operate. They tell the microwave that the door is closed and the unit is dafe to use.
Many models have 3 door switches, it's wise to get all 3 replaced at once.
Mar 27, 2009 | Samsung Microwave Ovens
Microwave wont start
Assuming the Start pad on the keypad is good, I would strongly suspect the upper or lower door switch or the switch's mount, depending on your model number.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
It's usually more economical and safer to add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Jan 24, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The stop/clear and start/stop buttons fail to work on my microwave
Please reply back with your brand and model number so we can help you.
This is usually caused by either a bad door switch, a loose door switch mount, a failing keypad, or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Please write back with your brand and model number if you need further help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 15, 2008 | Microwave Ovens
Oven doesn't work
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 11, 2008 | Frigidaire GLMV168K Microwave Oven
I've replaced the computer on my kitchenaid kems378gss3 oven/microwave combo. I need the "codes" to key in on the keypad - to make the microwave actually "cook: things. Everything else works...
If you don't have the owner's manual you can download it here:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%204452300.pdf
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20(Micro)%20-%204452614.pdf
Some units will not allow time programming if the door is open - or if the microwave thinks it is due to a bad door switch or door switch mount, etc.
Switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Mar 07, 2008 | Microwave Ovens
Sharp R-204CW microwave,won't start at all
try to slam the door and try again. sometimes the micro switch at the door are getting sticky and would not latch correctly. if it work, open the housing and spray some wd-40 on the door latches.
Feb 17, 2008 | Microwave Ovens
Keypad only works
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
Dec 22, 2007 | Kenmore 62622 Microwave Oven
Have to Slam Door to get it to work - Advantium 120
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 26, 2007 | GE Advantium SCA1000H Convection /...
Microwave Ovens Logo
20 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
