Question about Cell Phones
I bought a new phone in May 2009. I can't seem to
I bought a new phone in May 2009. I can't seem to get it to hold a charge for very long. I took it back to Verizon. They asked me if I was using the Bluetooth feature, which I was. They told me it would eat up my battery by leaving it on because it was constantly searching for a signal. I have not had it on Bluetooth since then. However, the charge doesn't seem to last very long. I have to charge it every 2 days. My last phone only needed charging once a week. What is the problem? I heard something on the news about it but missed the story. Please advise.
My Samsung Comeback will not charge. When I plug it in and it's turned off, the bars go up, as if it's charging. But when I charge it for a long period of time ( longer than usual for it to be fully...
Hey! My Sister has the same problem. T-Mobile said that it is the battery. There was a defect with some phone batteries. You can buy the samsung battery from T-Mobile for like 48$ of go to cellphoneshop.net to get it cheaper. works great and is cheaper to replace than 48$ samsung battery!!
Aug 20, 2010 | Samsung Comeback Cell Phone
Battery problesm
There is a recall on this - I just took mine to the dealer and they took the gas tank off and had to replace a wire . Might want to check with your dealer..2009 legacy 250 owner..
Jul 05, 2010 | 2008 Qlink Legacy 250
Motorola Razor will not charge
turn the lights off in a room while the phone is on and see if you can see a light coming from the phone while it is closed and on.if you have a new battery did you let it fully charge before using.make sure the blue tooth is turned off.
May 13, 2010 | Motorola Mobility RAZR V3
Nokia n95 won't hold a charge
if you bought a new battery but it has made no difference so i think it may b something so you must repair yor mobile
Jul 17, 2009 | Nokia N95 Cellular Phone
AT&T E250 2.4Ghz Expansion Handset won't charge.
I posted the fix to you on 6/13/2009. The fix was to replace the transistor in the charging path inside of the telephone. I had another phone that I had dropped and the display didn't work. The charging circuit still functioned. I took the transistor off the broken phone and put on new non-charging phone. It fixed just fine. Although I already posted the fix to this site, here it is again:
Jun 13, 2009 | GE (DH27831) 2.4 GHz Twin Cordless...
I870 battery or phone problem???
you bought it off ebay --your battery probable at fault but also depending on what you have -running or downloaded apps-photos -music will drain battery in stand by mode even if you replace battery if your usage is high [dont have to be on phone ] from what you have on it battery drain can be the same
Apr 19, 2017 | Motorola Mobility i870 Cellular Phone
GPX MP3 PLAYER NOT WORKING RIGHT !!!
YOu said it at the beginning, don't ever buy electronics from fingerhut. Their kitchen stuff is pretty good. But that's about it. Sorry dude. I've never gotten anything replaced through them. They always forgot it.
Apr 30, 2009 | GPX MW3837 MP3 Player
My MOTOKRZR K1 battery/phone will not stay charged very long.
Let ur phone completely die. Don't charge it or anything when the low battery notice comes on. After it completely dies, put it on the charger only until it says charge complete. U might have to do it a few times to get ur battery performing as it should. If you charge ur battery too often, it causes ur battery to swell (weird I know) and your battery starts resisting charge. Hope this helps!! (I used to have the same phone and the same problem. I did this, and now my mom is using the phone and has an exceptional battery time)
Mar 21, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Battery not holding a charge
Hi try this I had a new Blackberry which required charging every single day, take out battery and press and hold the on button on the phone for a min, then put battery back in and try charging again! mine is perfect now again.
Somebody told me that it's to do with static or something that builds up and flattens the batt.
Mar 07, 2008 | Samsung SCH-u340 Cellular Phone
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
